Brother P-Touch GL-H105 Handheld Garden Labeller
Quicklinx: 9K2JWS00 Mfr#: GLH105U1
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: [N/A]
Technology: Thermal transfer
14 In Stock
£35.12 ex VAT
£42.14 inc VAT
Perfect for gardeners, the GL-H105 can help you to improve your efficiency and productivity by ensuring that your plants, pots and seed trays are clearly labelled and easy to identify.
Offering high-quality results that are long lasting and designed to withstand the demands of the great outdoors, the GL-H105 is lightweight and easy to use, with a handy range of symbols and different font styles to give your labels the professional touch.
Try taking it indoors too, as, this versatile label printer comes in equally handy around the house.
Brother P-Touch GL-H105 - labelmaker - B/W - thermal transfer
Printer Type
Labelmaker - thermal transfer - B/W
Portable
420 g
Max Media Size
Roll (1.2 cm)
Max Media Size (Custom)
9 mm
Print Speed
Up to 20 mm/sec
Max Resolution (B&W)
180 dpi
Cutter
Media Type
Laminated tape
Compatible Tapes
TZe tape
Fonts
Helsinki
Styles & Effects
Bold, italic bold, italic outline, italic shadow, normal, vertical, outline, shadow, italic
2 line printing
Display Resolution
1 line x 12 characters
Keyboard
ABCD / 54 keys
Required 6 x AAA type Included Qty 0
Enclosure Colour
Green
3-year warranty
11 cm x 20.7 cm x 5.9 cm
Printer Type
Labelmaker - thermal transfer - monochrome
Enclosure Colour
Green
Printer
Print Speed
Up to 20 mm/sec
Built-in Devices
Preview screen, character keyboard
180 dpi
Fonts
Helsinki
Styles & Effects
2 line printing
Display Resolution
Cutter
Keyboard
ABCD / 54 keys
Media Handling
Media Type
Laminated tape
Compatible Tapes
TZe tape
Max Media Size
Roll (1.2 cm)
9 mm
Media Sizes
Roll (0.6 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (0.35 cm)
Media Included
1 12 mm x 4 m black on white strong adhesive laminated tape (TZeS231)
No power supply
AAA type
Required Qty
6
Included
0
Limited warranty - 3 years
11 cm
20.7 cm
5.9 cm
420 g
Ink (12)
9K2J Brother TZES221 Black on White 9mm In Stock £6.58
9K2J Brother Laminated Tape 12mm Blk on Yel In Stock £8.97
9K2J Brother Tape Black on Yellow 6mm In Stock £7.20
9K2J Brother TZE-335 LAMINATED TAPE 12MM 8M In Stock £11.20
9K2J Brother Black On Clear Labelling Tape 12mm In Stock £8.13
9K2J Brother 12mm Black on White Tape In Stock £10.98
9K2J Brother Tape Black on Clear 9mm In Stock £7.27
9K2J Brother 12mm Matt Black on Red Laminated Tape In Stock £9.46
9K2J Brother 12mm Blue on White Tape In Stock £9.46
9K2J Brother P-touch TZe-211 (6mm x 8m) Black On White Label Tape In Stock £7.52
9K2J Brother TZE621 9MM GLOSS Black on Yellow Tape In Stock £8.12
9K2J Brother TZEFX-231 Black On White Flexi Tape In Stock £10.96
Other bundles (1)
9K2J Brother TZe 231 - laminated adhesive tape - 1 roll(s) In Stock £9.36
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (1.2 cm)
Brand: Brother
