Perfect for gardeners, the GL-H105 can help you to improve your efficiency and productivity by ensuring that your plants, pots and seed trays are clearly labelled and easy to identify.
Offering high-quality results that are long lasting and designed to withstand the demands of the great outdoors, the GL-H105 is lightweight and easy to use, with a handy range of symbols and different font styles to give your labels the professional touch.
Try taking it indoors too, as, this versatile label printer comes in equally handy around the house.
- Brother P-Touch GL-H105 - labelmaker - B/W - thermal transfer
- Printer Type
- Labelmaker - thermal transfer - B/W
- Form Factor
- Portable
- 420 g
- Max Media Size
- Roll (1.2 cm)
- Max Media Size (Custom)
- 9 mm
- Print Speed
- Up to 20 mm/sec
- Max Resolution (B&W)
- 180 dpi
- Cutter
- Media Type
- Laminated tape
- Compatible Tapes
- TZe tape
- Fonts
- Helsinki
- Styles & Effects
- Bold, italic bold, italic outline, italic shadow, normal, vertical, outline, shadow, italic
- 2 line printing
- Display Resolution
- 1 line x 12 characters
- Keyboard
- ABCD / 54 keys
- Battery
- Required 6 x AAA type Included Qty 0
- Enclosure Colour
- Green
- 3-year warranty
- 11 cm x 20.7 cm x 5.9 cm
- Printer Type
- Labelmaker - thermal transfer - monochrome
- Enclosure Colour
- Green
Printer
- Print Speed
- Up to 20 mm/sec
- Built-in Devices
- Preview screen, character keyboard
- 180 dpi
- Fonts
- Helsinki
- Styles & Effects
- 2 line printing
- Cutter
- Keyboard
- ABCD / 54 keys
Media Handling
- Media Type
- Laminated tape
- Compatible Tapes
- TZe tape
- Max Media Size
- Roll (1.2 cm)
- 9 mm
- Media Sizes
- Roll (0.6 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (0.35 cm)
- Media Included
- 1 12 mm x 4 m black on white strong adhesive laminated tape (TZeS231)
- Power Device
- No power supply
- AAA type
- Required Qty
- 6
- Included
- 0
- Limited warranty - 3 years
- 11 cm
- 20.7 cm
- 5.9 cm
- 420 g
Ink (14)
Brother TZES221 Black on White 9mm | In Stock | £8.47 |
Brother TZe-S211 - laminated tape - 1 cassette(s) - Roll (0.6 cm x 8 m) | In Stock | £9.53 |
Brother Laminated Tape 12mm Blk on Yel | In Stock | £9.31 |
Brother Tape Black on Yellow 6mm | In Stock | £7.48 |
Brother TZE-335 LAMINATED TAPE 12MM 8M | In Stock | £11.17 |
Brother Tape Black on Yellow 12mm | In Stock | £11.52 |
Brother Black On Clear Labelling Tape 12mm | In Stock | £8.42 |
Brother 12mm Black on White Tape | In Stock | £11.94 |
Brother Tape Black on Clear 9mm | In Stock | £7.54 |
Brother 12mm Matt Black on Red Laminated Tape | In Stock | £9.95 |
Brother 12mm Blue on White Tape | In Stock | £9.86 |
Brother P-touch TZe-211 (6mm x 8m) Black On White Label Tape | In Stock | £7.27 |
Brother TZE621 9MM GLOSS Black on Yellow Tape | In Stock | £8.42 |
Brother TZEFX-231 Black On White Flexi Tape | In Stock | £11.41 |
Other bundles (2)
Brother TZe 231 - laminated adhesive tape - 1 roll(s) | In Stock | £9.31 |
Brother Mains Adapter for PTouch Label Printers | In Stock | £11.73 |
