Brother P-Touch 1005BTS - Labelmaker - B/W - thermal transfer - Roll (1.2 cm)
Quicklinx: 7NMRWS00 Mfr#: PT1005BTSZU1
Brother P-Touch 1005BTS is easy to use, versatile and can produce all the durable, self-adhesive labels you may need around the home, school or even garden.
Quickly and easily print your own labels with Brother P-Touch 1005BTS. Produce labels for a variety uses, including fabric labels for school uniforms and PE kits, durable labels for labeling frozen food. And, in the garden you can even label your plants and seedlings.
Brother P-Touch PT-1005BTS - labelmaker - B/W - thermal transfer
Printer Type
Labelmaker - thermal transfer - B/W
Portable
365 g
Max Media Size
Roll (1.2 cm)
Max Media Size (Custom)
12 mm
Max Resolution (B&W)
180 dpi
Cutter
Media Type
Non-laminated tape, laminated labels
Compatible Tapes
TZ tape
Fonts
Helsinki
Character Sizes
9 points, 6 points, 24 points, 18 points, 12 points
Display Resolution
1 line x 12 characters
Keyboard
ABCD
Required 6 x AAA type Alkaline
1-year warranty
10.7 cm x 20.3 cm x 5.7 cm
Printer Type
Labelmaker - thermal transfer - monochrome
Printer
Built-in Devices
Preview screen, character keyboard
180 dpi
Fonts
Helsinki
Character Sizes
Display Resolution
Cutter
Keyboard
ABCD
Media Handling
Media Type
Compatible Tapes
TZ tape
Max Media Size
Roll (1.2 cm)
12 mm
Media Sizes
Roll (0.6 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (0.35 cm)
Media Included
1 12 mm x 4 m black on white TZ tape cassette
AAA type - Alkaline
Required Qty
6
Limited warranty - 1 year
10.7 cm
20.3 cm
5.7 cm
365 g
