Part of Brother's MW range of ultra-portable printers, the MW-145BT is an easy-to-operate solution for those who need to be able to quickly print A7 documents when they're out in the field.
Small and lightweight enough to slot right into your pocket, the MW-145BT offers Bluetooth interfaces so that you can stay connected. Software developer kits mean it's easy to integrate the printer with your other technology. And durable thermal printing means you'll get great results whatever the conditions.
Thanks to an interchangeable paper cassette system, this rechargeable machine works with a range of printing materials including a 2-ply carbon copy paper, ideal for receipt printing and ticket printing.
- Brother m-PRINT MW-145BT - printer - B/W - direct thermal
- Printer Type
- Personal printer - direct thermal - B/W
- Form Factor
- Portable
- 300 g
- Max Media Size
- A7 (74 x 105 mm)
- Print Speed
- Up to 4 ppm - A7 (74 x 105 mm)
- Max Resolution (B&W)
- 300 x 300 dpi
- Interface
- USB 2.0, Bluetooth 2.1 EDR
- Media Type
- Thermal paper
- Total Media Capacity
- 50 sheets
- Networking
- Network adapter
- Battery
- Lithium Ion Included Qty 1
- System Requirements
- Apple MacOS, Microsoft Windows 2000 Professional, Microsoft Windows XP, Microsoft Windows Mobile 5.0, Microsoft Windows Vista, BlackBerry OS, Microsoft Windows Mobile 6.x
- 1-year warranty
- 10 cm x 16 cm x 17.5 cm
- Printer Type
- Personal printer - direct thermal - monochrome
Printer
- Print Speed
- Up to 4 ppm - 300x300 dpi - A7 (74 x 105 mm)
- Connectivity Technology
- Wireless
- Interface
- 300 x 300 dpi
- Fonts Included
- 5 x bitmapped , 3 x outline , 11 x barcode
Media Handling
- Media Type
- Thermal paper
- Max Media Size
- A7 (74 x 105 mm)
- Media Sizes
- A7 (74 x 105 mm)
- Max Printing Width
- 69 mm
- Max Printing Length
- 100 mm
- 50 sheets
- Media Feeders
- 1 x automatic - 50 sheets - A7 (74 x 105 mm)
- Networking
- Network adapter
- Connections
- 1 x USB 2.0
- Included Accessories
- Paper cassette
- Cables Included
- 1 x USB cable
- Media Included
- 50 sheets of paper
- Power Device
- Power adapter - external
- Lithium Ion
- Included
- 1
- Run Time (Up To)
- 100 pages
- OS Required
- Limited warranty - 1 year
- 10 cm
- 16 cm
- 17.5 cm
- 300 g
