Brother Mobile Receipt Printer with Bluetooth and Wifi
Quicklinx: D67CWS00 Mfr#: RJ2150Z1
Type: Printer
Functionality: Printer
Wireless Capability: Wired, Wireless
Max Paper Size: Roll (5.8 cm)
  • Windows 8 (32/64 bits)
£537.82 ex VAT
£645.38 inc VAT
Print labels and receipts on-demand with the Wi-Fi and Bluetooth enabled Brother RJ-2150 mobile printer. Various SDK's for iOS, Android mobile devices and Windows OS PC's let you easily integrate the printer into your existing system. ZPL II, CPCL and Brother ESC/P emulations offer further integration options.
  • Rugged 2" mobile receipt and label printer with Bluetooth and Wi-Fi
    This compact, rugged high-speed printer is the ideal mobile label and receipt printer for your business. The RJ-2150 is the user friendly option thanks to an integrated backlit LCD and easy-to-load rolls.
  • Versatile printing whenever required
    Print pricing or markdown labels on demand at the point of labeling, or leave high-quality receipts with your customers. This lightweight printer is ideal for field service/sales, retail, public safety/emergency services, logistics, warehousing or manufacturing businesses.
  • Dependable printing
    The RJ-2150 has been designed for use in the toughest environments - developed and tested to withstand 2.5 meter drops, and with an IP54 rating against dust and moisture.
  • Bluetooth, Wi-Fi and USB connectivity
    Quickly and easily connect the RJ-2150 to your mobile device using Bluetooth. With support for Apple MFi, iPhones and iPads can now print using Bluetooth, in addition to Android mobile devices. Or alternatively connect the printer to your Wi-Fi network. A USB port is also included for when printing from a Windows based PC is required.
  • Incorporate label or receipt printing in your existing systems
    With support as standard for ZPL II and CPCL emulations, the RJ-2150 can be added to legacy system which use these printer languages. Or use the Brother ESC/P printer language to access, modify and print templates which were previously designed and uploaded from your PC into the flash memory of the printer.
  • SDK's for iOS, Android and Windows devices
    Easily add printing within your existing Apps and software by harnessing the power of one of the Brother SDK's (Software Development Kits) available. Use the Brother B-PAC SDK for Windows based programs, or one of the Brother Print SDK's for iPhone, iPad or Android devices.
Brother RuggedJet RJ-2150 - receipt printer - B/W - direct thermal
Printer Type
Receipt printer - direct thermal - B/W
Portable
545 g
Denmark, United Kingdom
Max Media Size
Roll (5.8 cm)
Min Media Size (Custom)
25.4 mm
Max Media Size (Custom)
58 mm
Print Speed
Up to 152 mm/sec
Max Resolution (B&W)
203 dpi
USB 2.0, Wi-Fi(n), Bluetooth 2.1 EDR
AirPrint Enabled
RAM Installed (Max)
32 MB
Flash Memory Installed (Max)
32 MB
Language Simulation
EPSON ESC/P, ZPL II, Comtec Printer Control Language (CPCL)
Media Type
Receipt labels
Fonts
Helsinki, Letter Gothic Bold, Gothic
Print server
Required 1 Lithium Ion Included Qty 1
Microsoft Windows Server 2008 R2, Android, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Apple iOS, Microsoft Windows Server 2012, Windows 8 (32/64 bits), Microsoft Windows Server 2012 R2, Windows 10 (32/64 bits)
3-year warranty
15.1 cm x 10 cm x 7.3 cm
Printer Type
Receipt printer - direct thermal - monochrome
Printer
Print Speed
Up to 152 mm/sec
Built-in Devices
Status LCD
Wireless
AirPrint Enabled
203 dpi
Language Simulation
Fonts
RAM
RAM Installed (Max)
32 MB
Flash Memory
Flash Memory
32 MB
Media Handling
Media Type
Receipt labels
Max Media Size
Roll (5.8 cm)
25.4 mm
58 mm
Media Sizes
Roll (5.8 cm), Roll (2.54 cm)
Max Printing Width
54 mm
Max Printing Length
1 m
Media Thickness Range
0.058 mm - 0.17 mm
Roll Maximum Outer Diameter
60 mm
Roll Core Diameter
10.2 mm
Media Feeders
1 x manual - 1 roll - Roll (5.8 cm)
Print server
1 x USB 2.0 - 4 pin mini-USB Type B
Belt clip
IP54
No power supply
Lithium Ion
Required Qty
1
Included
1
Run Time (Up To)
6400 pages
Software Included
Software Development Kit (SDK)
Limited warranty - 3 years
-10 °C
50 °C
10 - 90% (non-condensing)
15.1 cm
10 cm
7.3 cm
545 g
D67C Brother PA-CD-600CG Car Adaptor for RJ-4040 Rugged WiFi Mobile Printer In Stock £22.01
Type: Printer
Wireless Capability: Wireless
Brand: Brother
Price Range Ex VAT: £500 - £750
