Our RJ-3000 Series portable printers are smaller and lighter than ever before. They provide the perfect on-person device for mobile workers needing a 2" or 3" printing solution - from emergency services and field sales to delivery drivers, engineers and traffic wardens. And the RJ-3150 can print up to 3" receipts, quotes and labels on the spot with preview, thanks to the 3.3" colour LCD display.
Its thermal printing technology means users don't have to worry about ink or toner, while its IP54 certification-the toughest tests against dust and water-means you are assured of its continued reliability whatever the conditions. Plus ZPL compatibility also allows existing applications for label/receipt printers to work with the RJ device.
- Brother RuggedJet RJ-3150 - receipt printer - B/W - direct thermal
- Printer Type
- Receipt printer - direct thermal - B/W
- Form Factor
- Portable
- 680 g
- Max Media Size
- Roll (8 cm)
- Min Media Size (Custom)
- 25 mm
- Max Media Size (Custom)
- 80 mm
- Print Speed
- Up to 127 mm/sec
- Max Resolution (B&W)
- 203 dpi
- Interface
- USB 2.0, Wi-Fi(n), USB host, Bluetooth 2.1 EDR
- RAM Installed (Max)
- 32 MB
- Flash Memory Installed (Max)
- 32 MB
- Language Simulation
- EPSON ESC/P, ZPL II, EPSON ESC/P Raster, Comtec Printer Control Language (CPCL)
- Barcodes
- Code 39, GS1 DataBar, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Postnet, PDF417, Data Matrix, ITF, GS1 DataBar Expanded, GS1 DataBar Limited
- Media Type
- Receipt labels, die cut labels
- Fonts
- Helsinki, Letter Gothic Bold, Gothic
- Gap sensor, transmissive media sensor, reflective media sensor, peeler
- Networking
- Print server
- Battery
- Required 1 Lithium Ion Included Qty 1
- System Requirements
- Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012, Android 2.3 or later, Apple iOS 5.0 or later, Microsoft Windows Server 2012 R2, Windows 8.1
- 3-year warranty
- 11.6 cm x 18.9 cm x 8.2 cm
- Printer Type
- Receipt printer - direct thermal - monochrome
Printer
- Print Speed
- Up to 127 mm/sec
- Built-in Devices
- Peeler
- Connectivity Technology
- Wireless
- Interface
- 203 dpi
- Fonts
- Barcodes
RAM
- 32 MB
Flash Memory
- Flash Memory
- 32 MB
Media Handling
- Media Type
- Max Media Size
- Roll (8 cm)
- 25 mm
- 80 mm
- Media Sizes
- Roll (8 cm), Roll (2.5 cm)
- Max Printing Width
- 72 mm
- Max Printing Length
- 1 m
- Media Thickness Range
- 0.058 mm - 0.17 mm
- Roll Maximum Outer Diameter
- 66 mm
- Roll Core Diameter
- 25.4 mm, 12.7 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (8 cm)
- Networking
- Print server
- Connections
- 1 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin mini-USB Type B
- Included Accessories
- Belt clip
- IP54
- Power Device
- No power supply
- Lithium Ion
- Required Qty
- 1
- Included
- 1
- Run Time (Up To)
- 5300 pages
- OS Required
- Limited warranty - 3 years
- -10 °C
- 50 °C
- 10 - 90% (non-condensing)
- 11.6 cm
- 18.9 cm
- 8.2 cm
- 680 g
