Brother Mobile Printer 5ips 203dpi 1" to 3" wide print rec
IDEAL FOR MOBILE WORKERS!
Quicklinx: BWTCWS00 Mfr#: RJ3150Z1
Type: Printer
Functionality: Printer
Wireless Capability: Wired, Wireless
Technology: Thermal Ink-jet
Max Paper Size: Roll (8 cm)
£741.08 ex VAT
£889.29 inc VAT
Our RJ-3000 Series portable printers are smaller and lighter than ever before. They provide the perfect on-person device for mobile workers needing a 2" or 3" printing solution - from emergency services and field sales to delivery drivers, engineers and traffic wardens. And the RJ-3150 can print up to 3" receipts, quotes and labels on the spot with preview, thanks to the 3.3" colour LCD display.
Its thermal printing technology means users don't have to worry about ink or toner, while its IP54 certification-the toughest tests against dust and water-means you are assured of its continued reliability whatever the conditions. Plus ZPL compatibility also allows existing applications for label/receipt printers to work with the RJ device.
Brother RuggedJet RJ-3150 - label printer - monochrome - direct thermal
Printer Type
Label printer - direct thermal - monochrome
Portable
680 g
Max Media Size
Roll (8 cm)
Min Media Size (Custom)
25 mm
Max Media Size (Custom)
80 mm
Print Speed
Up to 127 mm/sec
Max Resolution (B&W)
203 dpi
USB 2.0, Wi-Fi(n), USB host, Bluetooth 2.1 EDR
RAM Installed (Max)
32 MB
Flash Memory Installed (Max)
32 MB
Language Simulation
EPSON ESC/P, ZPL II, EPSON ESC/P Raster, Comtec Printer Control Language (CPCL)
Barcodes
Code 39, GS1 DataBar, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Postnet, PDF417, Data Matrix, ITF, GS1 DataBar Expanded, GS1 DataBar Limited
Media Type
Receipt labels, die cut labels
Fonts
Helsinki, Letter Gothic Bold, Gothic
Gap sensor, transmissive media sensor, reflective media sensor, peeler
Print server
Required 1 Lithium Ion Included Qty 1
Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012, Android 2.3 or later, Apple iOS 5.0 or later, Microsoft Windows Server 2012 R2, Windows 8.1
3-year warranty
11.6 cm x 18.9 cm x 8.2 cm
Printer Type
Printer
Print Speed
Up to 127 mm/sec
Built-in Devices
Peeler
Wireless
203 dpi
Language Simulation
Fonts
Barcodes
RAM
RAM Installed (Max)
32 MB
Flash Memory
Flash Memory
32 MB
Media Handling
Media Type
Max Media Size
Roll (8 cm)
25 mm
80 mm
Media Sizes
Roll (8 cm), Roll (2.5 cm)
Max Printing Width
72 mm
Max Printing Length
1 m
Media Thickness Range
0.058 mm - 0.17 mm
Roll Maximum Outer Diameter
66 mm
Roll Core Diameter
25.4 mm, 12.7 mm
Media Feeders
1 x manual - 1 roll - Roll (8 cm)
Print server
1 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin mini-USB Type B
Belt clip
IP54
No power supply
Lithium Ion
Required Qty
1
Included
1
Run Time (Up To)
5300 pages
Limited warranty - 3 years
-10 °C
50 °C
10 - 90% (non-condensing)
11.6 cm
18.9 cm
8.2 cm
680 g
Type: Printer
Wireless Capability: Wireless
Brand: Brother
Price Range Ex VAT: 500 - 750
