Brother MFCL6900DW Mono Laser Printer
Quicklinx: C146WS00 Mfr#: MFCL6900DWZU1
Functionality: Fax, Scanner, Printer, Copier
Technology: Laser
£666.98 ex VAT
£800.37 inc VAT
Built to perform for longer. The MFC-L6900DW all-in-one has been designed with high output workgroups in mind. The 80 page auto document feeder enables fast scanning, copying alongside high speed 2-sided printing. Improved user interface helps make operation more intuitive. The all new optional ultra-high-yield toner cartridges considerably reduces your print spend, making this machine the ideal print partner for your workgroup.
Maximise Performance & Reduce Print Spend
Versatile paper handling, enables you to add multiple lower trays across the range. This provides maximum device uptime, as less time is spent replenishing paper trays. With the optional ultra high yield toner cartridges, productivity is enhanced, whilst reducing your overall printing costs.
Better reliability
Built to perform for longer and meet the demands of high output work environments, the L6000 Workgroup range has been totally remodelled with robust build quality that’s even more resilient and hardwearing.
Enhanced Workflow
The L6000 Workgroup range introduces an 80 page auto document feeder supporting automatic high speed scanning and copying. Combined with an intuitive and user-friendly interface, and support for multiple business cloud based services including Dropbox and Google Drive.
Tighter security
In today's business environment, we understand that organisations demand the highest levels of security. In order to address this, the L6000 Workgroup range is enabled with secure function lock 3.0, 802.1x and Internet Protocol Security (IPsec). The range also boasts Print Archive, Secure Reset, Certificate Management and Near field communication (NFC) functionality for secure user access and authentication.
Flexible print solutions from Brother
Our L6000 Workgroup range is designed to seamlessly integrate and meet your business requirements. Compatible with a range of print software and services, Brother Solutions enables you to maximise your print efficiency and minimise costs, specifically tailored to your requirements.
Eco-friendly
The L6000 Workgroup range is compliant with a number of environmental standards including German Blue Angel, Nordic Swan and Energy Star. As a result, not only does it help your business work more efficiently, it is also more energy efficient, reducing impact on the environment and lowering your costs at the same time.
Brother - multifunction printer
Fax Type
Plain paper
Original Type
Sheets
PC Connection Availability
Fax Type
Plain paper
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Scanning
Grey Scale Depth
8 bit
Fax Machine
PC Faxing
Document & Media Handling
Original Type
Sheets
Functionality: Fax
Functionality: Scanner
Functionality: Printer
Functionality: Copier
Technology: Laser
Brand: Brother
Price Range Ex VAT: £500 - £750
