Brother MFCL6900DW All-In-One Mono Laser Printer with Extra Lower Tray
Quicklinx: C147WS00 Mfr#: MFC6900DWTZU1
£746.26 ex VAT
£895.51 inc VAT
Built for business, this all-in-one is designed with high print volume workgroups in mind. Robust build quality, combined with excellent paper handling gives true workgroup performance.
Maximise Performance & Reduce Print Spend
Versatile paper handling, enables you to add multiple lower trays across the range. This provides maximum device uptime, as less time is spent replenishing paper trays. With the optional ultra high yield toner cartridges, productivity is enhanced, whilst reducing your overall printing costs.
Better reliability
Built to perform for longer and meet the demands of high output work environments, the L6000 Workgroup range has been totally remodelled with robust build quality that’s even more resilient and hardwearing.
Enhanced Workflow
The L6000 Workgroup range introduces an 80 page auto document feeder supporting automatic high speed scanning and copying. Combined with an intuitive and user-friendly interface, and support for multiple business cloud based services including Dropbox and Google Drive.
Tighter security
In today's business environment, we understand that organisations demand the highest levels of security. In order to address this, the L6000 Workgroup range is enabled with secure function lock 3.0, 802.1x and Internet Protocol Security (IPsec). The range also boasts Print Archive, Secure Reset, Certificate Management and Near field communication (NFC) functionality for secure user access and authentication.
Flexible print solutions from Brother
Our L6000 Workgroup range is designed to seamlessly integrate and meet your business requirements. Compatible with a range of print software and services, Brother Solutions enables you to maximise your print efficiency and minimise costs, specifically tailored to your requirements.
Eco-friendly
The L6000 Workgroup range is compliant with a number of environmental standards including German Blue Angel, Nordic Swan and Energy Star. As a result, not only does it help your business work more efficiently, it is also more energy efficient, reducing impact on the environment and lowering your costs at the same time.
  • Super-fast print speeds of up to 50ppm
  • Super-fast 2-sided scan speeds of up to 100ipm
  • Outstanding paper handling options with a standard paper capacity of 1,090 expandable to 1,610
  • 12,000 page inbox toner & optional ultra high yield 20,000 page toner cartridge
  • Intuitive 12.3cm touchscreen LCD display
  • Integrated NFC, giving users better document security and improved user authentication for pull printing without expensive card readers.
  • Maximize performance
    Significantly increase your workgroup productivity thanks to superfast print and scan speeds of 50 ppm / 100 ipm. Maximize performance with high-speed wired (10Base-T/100Base-TX/1000Base-T) and wireless (IEEE 802.11b/g/n) network interfaces. Streamline workflows and easily print with NFC technology. The incredibly easy-to-use touchscreen user interface allows users to customize their screens.
  • Complete peace of mind
    Advanced build technology gives complete reliability enabling you to print plenty of pages per month. It features 80 page automatic document feeder and high-speed scanning for seamless document management.
  • Meeting your IT challenges
    The device gives you high levels of security, featuring Secure Function lock 3.0, Active directory connectivity and Internet Protocol Security (IPsec). Plus, it also features Print Archive, Secure Reset and Certificat Management and near field communication (NFC) functionality.
Brother MFC-L6900DWT - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Max Copying Resolution
Up to 1200 x 600 dpi
Max Printing Speed
Up to 50 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
Scanning
1200 x 1200 dpi
Display
4.85"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
80 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
Standard Media Capacity
1090 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to FTP, scan to SMB
AC 230 V (50/60Hz)
49.5 cm x 42.7 cm x 65 cm
22.9 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Fax Type
Plain paper
Printing Technology
Laser - monochrome
Display Diagonal Size
4.85"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1 GB
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Max Printing Speed
Up to 50 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, IBM Proprinter, PDF 1.7, XPS, EPSON FX
Automatic Duplexing
First Print Out Time B/W
7.5 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Reception Memory Capacity
Up to 500 pages
Transmission Memory Capacity
Up to 500 pages
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
300 station(s)
Broadcast Transmission
350 stations
Fax forwarding, automatic redialing, group dialling, Dual Access
Document & Media Handling
Max Original Size
Original Type
Sheets
80 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
200 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
1090 sheets
50 sheets
250 sheets
2 x input tray - 520 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , ADF - 80 sheets size: 105 x 147.3 mm - 215.9 x 355.6 mm weight: 64 g/m² - 90 g/m² , Bypass tray - 50 sheets size: 76.2 x 127 mm - 215.9 x 355.6 mm weight: 60 g/m² - 200 g/m² , Output tray - 250 sheets
Speed Details
Printing: up to 50 ppm - B/W , Printing: up to 24 spm - B/W duplex , Scanning: up to 50 ipm - B/W , Scanning: up to 20 ipm - colour , Scanning: up to 100 ipm - B/W duplex , Scanning: up to 34 ipm - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB host - 4 pin USB Type A
Security Protocols & Features
SSL, WPA-PSK, TLS, IPsec, WPA2-PSK, TKIP, AES, ARP, Wi-Fi Direct
Operating System Support
Linux, MS Windows XP SP3, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.9, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11
AC 230 V (50/60Hz)
805 Watt
Power Consumption Standby
34 Watt
Power Consumption Sleep
8 Watt
First Copy Out Time B/W
9.5 sec
Nordic Swan
ENERGY STAR Certified
Blue Angel Compliant
49.5 cm
42.7 cm
65 cm
22.9 kg
Shipping Width
59.9 cm
Shipping Depth
52.6 cm
Shipping Height
104.7 cm
Shipping Weight
29.2 kg
Sound Emission
35 dBA (idle) / 57 dBA (operating)
10 °C
32 °C
20 - 80% (non-condensing)
C147 Brother TN-3430 Black Standard Yield Toner In Stock £55.87
C147 Brother TN-3480 Tonert 8000 Pages In Stock £95.97
C147 Brother TN-3512 Black Super High Yield Toner In Stock £108.19
C147 Brother HLL6400/MFCL6900DW/T Drum Unit 30K In Stock £112.54
Functionality: Printer
Functionality: Fax
Functionality: Scanner
Functionality: Copier
Technology: Laser
Max Paper Size: A4 (210 x 297 mm)
Brand: Brother
Price Range Ex VAT: £500 - £750
