The all-in-one that’s designed with the busy office in mind. Robust build quality combined with versatile paper handling options gives you outstanding results repeatedly. The new optional super-high-yield toner cartridges significantly reduces your print spend, making this machine the ideal print partner for your office.
Key Features
- Super-fast print speeds of up to 46ppm.
- Super-fast 2-sided scan speeds of up to 100ipm.
- Outstanding paper handling options with a standard paper capacity of 1,090 expandable to 1,610.
- 8,000 page inbox toner & optional super high yield 12,000 page toner cartridge.
- Intuitive 12.3cm touchscreen LCD display.
- Integrated NFC Reader, giving users better document security and improved user authentication for pull printing.
Maximise Performance & Reduce Print Spend
Versatile paper handling, enables you to add multiple lower trays across the range. This provides maximum device uptime, as less time is spent replenishing paper trays. With the optional high yield toner cartridges, productivity is enhanced, whilst reducing your overall printing costs.
Better reliability
Built to perform for longer and meet the demands of high output work environments, the L6000 range has been totally remodelled with robust build quality that’s even more resilient and hardwearing.
Enhanced Workflow
The L6000 range introduces an 80 page auto document feeder supporting automatic high speed scanning and copying. Combined with an intuitive and user-friendly interface, and support for multiple business cloud based services including Dropbox and Google Drive.
Tighter security
In today's business environment, we understand that organisations demand the highest levels of security. In order to address this, the L6000 range is enabled with secure function lock 3.0, 802.1x and Internet Protocol Security (IPsec). The range also boasts Print Archive, Secure Reset, Certificate Management and Near field communication (NFC) functionality for secure user access and authentication.
Flexible print solutions from Brother
The L6000 range is designed to seamlessly integrate and meet your business requirements. Compatible with a range of print software and services, Brother Solutions enables you to maximise your print efficiency and minimise costs, specifically tailored to your requirements.
Eco-friendly
The L6000 range is compliant with a number of environmental standards including German Blue Angel, Nordic Swan and Energy Star. As a result, not only does it help your business work more efficiently, it is also more energy efficient, reducing impact on the environment and lowering your costs at the same time
Maximize performance & reduce print spend
Versatile paper handling, enables you to add multiple lower trays across the range. This provides maximum device uptime, as less time is spent replenishing paper trays. With the optional high yield toner cartridges, productivity is enhanced, whilst reducing your overall printing costs. -
Better reliability
Built to perform for longer and meet the demands of high output work environments, the L6000 range has been totally remodeled with robust build quality that's even more resilient and hardwearing. -
Enhanced workflow
The L6000 range introduces an 80 page auto document feeder supporting automatic high speed scanning and copying. Combined with an intuitive and user-friendly interface, and support for multiple business cloud based services including Dropbox and Google Drive. -
The L6000 range is designed to seamlessly integrate and meet your business requirements. Compatible with a range of print software and services, Brother Solutions enables you to maximize your print efficiency and minimize costs, specifically tailored to your requirements. -
Eco-friendly
The L6000 range is compliant with a number of environmental standards including German Blue Angel, Nordic Swan and Energy Star. As a result, not only does it help your business work more efficiently, it is also more energy efficient, reducing impact on the environment and lowering your costs at the same time.
- Brother MFC-L6800DWT - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Recommended Monthly Volume
- 7500 pages
- Max Copying Resolution
- Up to 1200 x 600 dpi
- Max Printing Speed
- Up to 46 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 4.85"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 80 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
- Standard Media Capacity
- 1090 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to FTP, scan to SMB
- Power
- AC 230 V (50/60Hz)
- 49.5 cm x 42.7 cm x 65 cm
- 22.8 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 2-year warranty
- Fax Type
- Plain paper
- Laser - monochrome
- 7500 pages
- Display Diagonal Size
- 4.85"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 512 MB
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Up to 46 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, IBM Proprinter, PDF 1.7, XPS, EPSON FX
- First Print Out Time B/W
- 7.5 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Fax Resolutions
- Reception Memory Capacity
- Up to 500 pages
- Transmission Memory Capacity
- Up to 500 pages
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 300 station(s)
- Broadcast Transmission
- 350 stations
- Fax forwarding, automatic redialing, group dialling, Dual Access
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 80 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 200 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
- 1090 sheets
- 50 sheets
- 250 sheets
- 2 x input tray - 520 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , ADF - 80 sheets size: 105 x 147.3 mm - 215.9 x 355.6 mm weight: 64 g/m² - 90 g/m² , Bypass tray - 50 sheets size: 76.2 x 127 mm - 215.9 x 355.6 mm weight: 60 g/m² - 200 g/m² , Output tray - 250 sheets
- Speed Details
- Printing: up to 46 ppm - B/W , Printing: up to 24 spm - B/W duplex , Scanning: up to 50 ipm - B/W , Scanning: up to 100 ipm - B/W duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB host - 4 pin USB Type A
- SSL, WPA-PSK, TLS, IPsec, WPA2-PSK, TKIP, AES, ARP, Wi-Fi Direct
- Operating System Support
- Linux, MS Windows XP SP3, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.9, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11
- Voltage Required
- 745 Watt
- Power Consumption Standby
- 34 Watt
- Power Consumption Sleep
- 8 Watt
- First Copy Out Time B/W
- 9.5 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 8000 pages , 1 x drum - up to 50000 pages - Brother DR3400
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 2 years
- 49.5 cm
- 42.7 cm
- 65 cm
- 22.8 kg
- Shipping Width
- 59.2 cm
- Shipping Depth
- 54.5 cm
- Shipping Height
- 94.4 cm
- Shipping Weight
- 28.3 kg
- Sound Emission
- 35 dBA (idle) / 57 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
Ink (4)
Brother TN-3430 Black Standard Yield Toner | In Stock | £55.87 |
Brother TN-3480 Tonert 8000 Pages | In Stock | £95.97 |
Brother TN-3512 Black Super High Yield Toner | In Stock | £108.19 |
Brother HLL6400/MFCL6900DW/T Drum Unit 30K | In Stock | £112.54 |
Other bundles (1)
Brother LT6505 520 Sheet Optional Paper Tray | In Stock | £115.23 |
