Brother MFCL5750DW All-In-One Mono Laser Printer
Quicklinx: C2SFWS00 Mfr#: MFCL5750DWZU1
Functionality: Scanner, Copier, Printer, Fax
Output Type: Monochrome
Technology: Laser
Max Print Speed: 40ppm
£397.25 ex VAT
£476.70 inc VAT
Print, scan, copy and fax more efficiently with the MFC-L5750DW. With fast operating speeds and a large, user-friendly 12.3cm touchscreen display, this all-in-one mono laser device boasts optimum productivity and versatility to meet the needs of the most demanding business environment.
Maximise Performance & Reduce Print Spend
Versatile paper handling enables you to add multiple lower trays across the range. This provides maximum device uptime, as less time is spent replenishing paper trays. With the optional high yield toner cartridges, productivity is enhanced whilst reducing your overall printing costs.
Better reliability
Built to perform for longer and meet the demands of high output work environments, the L5000 range has been totally remodelled with robust build quality that’s even more resilient and hardwearing.
Tighter security
In today's business environment, we understand that organisations demand the highest levels of security. In order to address this, the L5000 range is enabled with secure function lock 3.0, 802.1x network security and Internet Protocol Security (IPsec). The range also boasts Print Archive, Secure Reset and Certificate Management.
Flexible print solutions from Brother
Our L5000 range is designed to seamlessly integrate and meet your business requirements. Compatible with a range of print software and services, Brother Solutions can be specifically tailored to your requirements and enables you to maximise your print efficiency and minimise costs.
Eco-friendly
The L5000 range is compliant with a number of environmental standards including German Blue Angel, Nordic Swan and Energy Star. As a result, not only does it help your business work more efficiently, it is also more energy efficient, reducing impact on the environment and lowering your costs at the same time.
Brother MFC-L5750DW - multifunction printer - B/W - with Brother PRINT AirBag for 200000 pages
Multifunction printer
Fax Type
Super G3 - plain paper
Bundled Services
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
3500 pages
Max Copying Resolution
Up to 1200 x 600 dpi
Max Printing Speed
Up to 40 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
Scanning
1200 x 1200 dpi
Display
4.85"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
Standard Media Capacity
300 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to FTP, scan to SMB
AC 230 V (50/60Hz)
43.5 cm x 48.6 cm x 42.7 cm
16.5 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
3-year warranty
Fax Type
Plain paper
Bundled Services
Printing Technology
Laser - monochrome
50000 pages
3500 pages
Display Diagonal Size
4.85"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
256 MB
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Max Printing Speed
Up to 40 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, IBM Proprinter, PDF 1.7, XPS, EPSON FX
Automatic Duplexing
First Print Out Time B/W
7.2 sec
Scanning
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Reception Memory Capacity
Up to 500 pages
Transmission Memory Capacity
Up to 500 pages
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
300 station(s)
Broadcast Transmission
350 stations
Fax forwarding, automatic redialing, group dialling, Dual Access
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
200 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
300 sheets
50 sheets
150 sheets
Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , ADF - 50 sheets size: 105 x 147.3 mm - 215.9 x 355.6 mm weight: 64 g/m² - 90 g/m² , Bypass tray - 50 sheets size: 76.2 x 127 mm - 215.9 x 355.6 mm weight: 60 g/m² - 200 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 40 ppm - B/W , Printing: up to 20 spm - B/W duplex , Scanning: up to 24 ipm - B/W , Scanning: up to 20 ipm - colour , Scanning: up to 48 ipm - B/W duplex , Scanning: up to 34 ipm - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Security Protocols & Features
SSL, WPA-PSK, TLS, IPsec, WPA2-PSK, TKIP, AES, ARP, Wi-Fi Direct
Operating System Support
Linux, MS Windows XP SP3, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.9, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11
AC 230 V (50/60Hz)
645 Watt
Power Consumption Standby
34 Watt
Power Consumption Sleep
8 Watt
First Copy Out Time B/W
9.2 sec
Consumables Included
1 x toner cartridge (black) - up to 2000 pages , 1 x drum (black) - up to 50000 pages - Brother DR3400
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 3 years
43.5 cm
48.6 cm
42.7 cm
16.5 kg
Sound Emission
35 dBA (idle) / 54 dBA (operating)
10 °C
32 °C
20 - 80% (non-condensing)
C2SF Brother TN-3430 Black Standard Yield Toner In Stock £60.29
C2SF Brother TN-3480 Tonert 8000 Pages In Stock £102.54
C2SF Brother HLL6400/MFCL6900DW/T Drum Unit 30K In Stock £121.44
Functionality: Copier
Functionality: Printer
Functionality: Fax
Technology: Laser
Max Paper Size: A4 (210 x 297 mm)
Brand: Brother
