Wherever the all-new MFC-L9550CDWT goes head-to-head against competitors in the small corporate market, you'll find it comes out on top.
Ideal for workgroups of up to 20 with a heavy print load, it offers professional quality colour combined with the reliability and performance of the undisputed number 1 brand in mono and AIO lasers.*
It also combines exceptional efficiency with our lowest ever total cost of ownership and embraces the 'Bring Your Own Device' revolution with quick & easy wireless connection to mobile devices. Meaning staff and visitors alike can print to and scan from the MFC-L9550CDWT using a wide range of smartphones and tablets.
*Jan-Dec 2013.
- Brother MFC-L9550CDWT - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 75000 pages
- Recommended Monthly Volume
- 1000 - 5000 pages
- Max Copying Resolution
- Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
- Max Printing Speed
- Up to 30 ppm (mono) / up to 30 ppm (colour)
- Max Printing Resolution
- Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 2400 dpi
- Original Size
- 215.9 x 355.6 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper, recycled paper, bond paper
- Standard Media Capacity
- 800 sheets
- Max Media Capacity
- 800 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network
- Power
- AC 230 V (50/60Hz)
- 49 cm x 53.5 cm x 66.2 cm
- 37.4 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Fax Type
- Plain paper
- Laser - colour
- 75000 pages
- 1000 - 5000 pages
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 256 MB
- Max Supported Memory
- 512 MB
Copying
Printing
- Printer Drivers / Emulations
- PCL 6, BR-Script 3
- First Print Out Time B/W
- 15 sec
- First Print Out Time Colour
- 15 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- PC Faxing
Fax Machine Features
- Duplex Fax
Document & Media Handling
- Max Original Size
- 215.9 x 355.6 mm
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), 76.2 x 127 mm, 215.9 x 355.6 mm
- 800 sheets
- 800 sheets
- 50 sheets
- 150 sheets
- Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , ADF - 50 sheets size: 147.3 x 147.3 mm - 215.9 x 355.6 mm weight: 64 g/m² - 90 g/m² , Bypass tray - 50 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets , Input tray - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m²
- Speed Details
- Printing: up to 30 ppm (A4) - B/W , Printing: up to 30 ppm (A4) - colour , Printing: up to 14 spm (A4) - B/W duplex , Printing: up to 14 spm (A4) - colour duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Kerberos, SSL, TLS, IPsec, 802.1x, EAP-TTLS, EAP-TLS, EAP-FAST
- Operating System Support
- Linux, MS Windows XP Professional x64 Edition, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2008 R2, Apple Mac OS X 10.8.x, MS Windows Server 2012, Windows 8, Windows 8 64-bit, MS Windows Server 2012 R2, Apple Mac OS X 10.7.5, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), Apple Mac OS X 10.9.x, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits)
- Voltage Required
- 565 Watt
- Power Consumption Standby
- 65 Watt
- Power Consumption Sleep
- 10.5 Watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x toner cartridge (black) - up to 6000 pages - Brother TN900BK , 1 x toner cartridge (cyan) - up to 6000 pages - Brother TN900C , 1 x toner cartridge (magenta) - up to 6000 pages - Brother TN900M , 1 x toner cartridge (yellow) - up to 6000 pages - Brother TN900Y , 1 x drum - up to 25000 pages - Brother DR321CL , 1 x belt - up to 50000 pages - Brother BU320CL , 1 x waste toner collector - up to 50000 pages - Brother WT320CL
- Nordic Swan, IEC 60825-1:2007
- ENERGY STAR Certified
- Blue Angel Compliant
- 49 cm
- 53.5 cm
- 66.2 cm
- 37.4 kg
- Shipping Width
- 66 cm
- Shipping Depth
- 62.5 cm
- Shipping Height
- 99.2 cm
- Shipping Weight
- 45.6 kg
- Sound Emission
- 28 dBA (idle) / 56 dBA (operating)
