Brother MFC-L8900CDW Colour Laser Multifunction Printer
Quicklinx: CTP5WS00 Mfr#: MFCL8900CDWZU1
More than 50 In Stock
£624.79 ex VAT
£749.74 inc VAT
MFC-L8900CDW
Designed business use the MFC-L8900CDWcombines the flexibility of offering a wide selection of paper inputs together with print speeds of up to 31ppm and 2-sided scan speeds of up to 56ipm in both mono and colour.
Key Features
  • Fast Print speeds of up to 31ppm colour and mono
  • Paper input of up to 300 sheets.
  • Maximum paper input of up to 2380 sheets
  • Automatic 2-Sided Printing
  • 2-sided scan speed of 56ipm colour & mono
  • Optional high-yield replacement cartridges 9000 black 6500 page cyan magenta and yellow toner cartridges
  • High speed wired (10Base-T/100 Base- TX/1000Base-T) and wireless (IEEE 802.11b/g/n) network interfaces
  • Integrated NFC card reader
  • Intuitive 12.6cm Colour Touchscreen
Increase productivity levels
  • Productivity is increased significantly thanks to the fast print speeds of up to 31ppm in colour and mono.
  • Maximise your efficiency with built-in wireless IEEE 802.11b/g/n and ethernet 10Base-T/100Base-TX/1000Base-T.
  • Easily print from your mobile device using Brother’s iPrint&Scan Android print service plug-in Google Cloud print 2.0 Mopria and AirPrint.
  • Outstanding paper handling options with a standard paper capacity of up to 300 sheets expandable to 2380 sheets
Meeting security challenges
Modern businesses demand the highest levels of security. With Secure Function Lock 3.0 Internet Protocol Security (IPsec) 802.1x and Secure Print you can be confident that your documents are safe with near field communication (NFC) functionality
Flexible and low running costs
Designed for high volume printing environments the MFC-L8900CDW includes a 3000 page black and 1800 page cyan magenta and yellow toners and can take optional 9000 page black and 6500 page cyan magenta and yellow toners to lower your running costs even further.
  • Efficient connectivity
    With a wide range of connectivity options including Gigabit Ethernet, NFC, USB 2.0, USB host, and Wi-Fi(n), the Brother MFC-L8900CDW ensures seamless integration into any work environment. Its support for mobile printing capabilities like Apple AirPrint and Google Cloud Print 2.0 allows for easy printing from smartphones and tablets.
  • High-quality printing and copying
    Achieve high-quality prints and copies with the Brother MFC-L8900CDW. It offers automatic duplexing, high resolution up to 2400 x 600 DPI for both black and white and color documents, and fast first print out times of 15 sec, ensuring your documents look sharp and are ready when you need them.
  • Advanced security features
    Keep your documents and data safe with the Brother MFC-L8900CDW's comprehensive security protocols, including 802.1x, ARP, IPsec, Kerberos, SSL, TLS, WEP, WPA-PSK, and WPA2-PSK. These features provide peace of mind and protect sensitive information from unauthorized access.
  • Versatile media handling
    The Brother MFC-L8900CDW is designed to handle a variety of media sizes and types, from envelopes and labels to thick and thin paper. With a maximum media size support of up to Legal (216 x 356 mm), a bypass feeder capacity of 50 sheets, and a standard media capacity of 300 sheets, it meets the needs of busy offices and workgroups.
  • Comprehensive office solution
    As a 4-in-1 device, the Brother MFC-L8900CDW serves as a printer, scanner, copier, and fax machine. It features a color touchscreen display for easy navigation, automatic duplex scanning, and a recommended monthly volume of 4000 pages, making it an ideal choice for businesses looking for a multifunctional office solution.
Brother MFC-L8900CDW - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
United Kingdom
Printing Technology
Laser (colour)
Recommended Monthly Volume
4000 pages
Max Copying Speed
Up to 31 ppm (mono) / up to 31 ppm (colour)
Max Copying Resolution
Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
Scanning
1200 x 2400 dpi
Display
5"
Original Size
215.9 x 355.6 mm (max)
Original Type
Sheets
Document Feeder Capacity
70 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
Standard Media Capacity
300 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, scan to USB host
AC 230 V (50/60Hz)
49.5 cm x 52.6 cm x 54.9 cm
28.7 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Fax Type
Plain paper
Printing Technology
Laser - colour
4000 pages
Display Diagonal Size
5"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
United Kingdom
Standard Memory
512 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, BR-Script 3, PDF 1.7, XPS
Automatic Duplexing
First Print Out Time B/W
15 sec
First Print Out Time Colour
15 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Scanning Resolution Details
1200 x 600 dpi - ADF , 1200 x 2400 dpi - flatbed
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Reception Memory Capacity
Up to 500 pages
Transmission Memory Capacity
Up to 500 pages
PC Faxing
Fax Machine Features
Broadcast Transmission
350 stations
Automatic redialing, group dialling
Document & Media Handling
Max Original Size
215.9 x 355.6 mm
Original Type
Sheets
70 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
300 sheets
50 sheets
150 sheets
ADF - 70 sheets size: 105 x 147.3 mm - 215.9 x 355.6 mm weight: 64 g/m² - 90 g/m² , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 50 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 31 ppm (A4) - B/W , Printing: up to 31 ppm (A4) - colour , Printing: up to 14 spm (A4) - B/W duplex , Printing: up to 14 spm (A4) - colour duplex , Scanning: up to 28 ppm - B/W , Scanning: up to 28 ppm - colour , Scanning: up to 56 ipm - B/W duplex , Scanning: up to 56 ipm - colour duplex , Printing: up to 33 ppm (Letter A) - B/W , Printing: up to 33 ppm (Letter A) - colour , Printing: up to 14 spm (Letter A) - B/W duplex , Printing: up to 14 spm (Letter A) - colour duplex , Copying: up to 31 ppm - B/W , Copying: up to 31 ppm - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
Kerberos, LDAP, SSL, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, TKIP, AES, ARP, TTLS
Operating System Support
Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, Android, iOS, MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows Phone, Windows 10 (32/64-bits), Apple Mac OS X 10.11, macOS 10.12, MS Windows Server 2016
AC 230 V (50/60Hz)
580 Watt
Power Consumption Standby
70 Watt
Power Consumption Sleep
10 Watt
First Copy Out Time B/W
16 sec
First Copy Out Time Colour
17 sec
Phone cable
Consumables Included
1 x toner cartridge (black) - up to 3000 pages , 1 x toner cartridge (cyan) - up to 1800 pages , 1 x toner cartridge (magenta) - up to 1800 pages , 1 x toner cartridge (yellow) - up to 1800 pages , 1 x drum - up to 50000 pages 3 pages per job , 1 x transfer unit - up to 130000 pages 3 pages per job , 1 x waste toner collector - up to 50000 pages - Brother WT320CL
Nordic Swan
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 2 years , Limited warranty - 1 year - on-site
49.5 cm
52.6 cm
54.9 cm
28.7 kg
Shipping Width
66.5 cm
Shipping Depth
59.5 cm
Shipping Height
65.4 cm
Shipping Weight
35 kg
Sound Emission
44 dBA (idle) / 49 dBA (operating)
10 °C
32 °C
20 - 80% (non-condensing)
CTP5 Brother Waste Toner Pack In Stock £14.36
Functionality: Printer
Functionality: Copier
Functionality: Fax
Functionality: Scanner
Max Paper Size: A4 (210 x 297 mm)
Brand: Brother
Price Range Ex VAT: £500 - £750
