MFC-L8900CDW
Designed business use the MFC-L8900CDWcombines the flexibility of offering a wide selection of paper inputs together with print speeds of up to 31ppm and 2-sided scan speeds of up to 56ipm in both mono and colour.
Key Features
- Fast Print speeds of up to 31ppm colour and mono
- Paper input of up to 300 sheets.
- Maximum paper input of up to 2380 sheets
- Automatic 2-Sided Printing
- 2-sided scan speed of 56ipm colour & mono
- Optional high-yield replacement cartridges 9000 black 6500 page cyan magenta and yellow toner cartridges
- High speed wired (10Base-T/100 Base- TX/1000Base-T) and wireless (IEEE 802.11b/g/n) network interfaces
- Integrated NFC card reader
- Intuitive 12.6cm Colour Touchscreen
Increase productivity levels
- Productivity is increased significantly thanks to the fast print speeds of up to 31ppm in colour and mono.
- Maximise your efficiency with built-in wireless IEEE 802.11b/g/n and ethernet 10Base-T/100Base-TX/1000Base-T.
- Easily print from your mobile device using Brother’s iPrint&Scan Android print service plug-in Google Cloud print 2.0 Mopria and AirPrint.
- Outstanding paper handling options with a standard paper capacity of up to 300 sheets expandable to 2380 sheets
Meeting security challenges
Modern businesses demand the highest levels of security. With Secure Function Lock 3.0 Internet Protocol Security (IPsec) 802.1x and Secure Print you can be confident that your documents are safe with near field communication (NFC) functionality
Flexible and low running costs
Designed for high volume printing environments the MFC-L8900CDW includes a 3000 page black and 1800 page cyan magenta and yellow toners and can take optional 9000 page black and 6500 page cyan magenta and yellow toners to lower your running costs even further.
Efficient connectivity
With a wide range of connectivity options including Gigabit Ethernet, NFC, USB 2.0, USB host, and Wi-Fi(n), the Brother MFC-L8900CDW ensures seamless integration into any work environment. Its support for mobile printing capabilities like Apple AirPrint and Google Cloud Print 2.0 allows for easy printing from smartphones and tablets. -
High-quality printing and copying
Achieve high-quality prints and copies with the Brother MFC-L8900CDW. It offers automatic duplexing, high resolution up to 2400 x 600 DPI for both black and white and color documents, and fast first print out times of 15 sec, ensuring your documents look sharp and are ready when you need them. -
Advanced security features
Keep your documents and data safe with the Brother MFC-L8900CDW's comprehensive security protocols, including 802.1x, ARP, IPsec, Kerberos, SSL, TLS, WEP, WPA-PSK, and WPA2-PSK. These features provide peace of mind and protect sensitive information from unauthorized access. -
Versatile media handling
The Brother MFC-L8900CDW is designed to handle a variety of media sizes and types, from envelopes and labels to thick and thin paper. With a maximum media size support of up to Legal (216 x 356 mm), a bypass feeder capacity of 50 sheets, and a standard media capacity of 300 sheets, it meets the needs of busy offices and workgroups. -
Comprehensive office solution
As a 4-in-1 device, the Brother MFC-L8900CDW serves as a printer, scanner, copier, and fax machine. It features a color touchscreen display for easy navigation, automatic duplex scanning, and a recommended monthly volume of 4000 pages, making it an ideal choice for businesses looking for a multifunctional office solution.
- Brother MFC-L8900CDW - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Localisation
- United Kingdom
- Printing Technology
- Laser (colour)
- Recommended Monthly Volume
- 4000 pages
- Max Copying Speed
- Up to 31 ppm (mono) / up to 31 ppm (colour)
- Max Copying Resolution
- Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
- Scanning
- 1200 x 2400 dpi
- Display
- 5"
- Original Size
- 215.9 x 355.6 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 70 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
- Standard Media Capacity
- 300 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, scan to e-mail, scan to USB host
- Power
- AC 230 V (50/60Hz)
- 49.5 cm x 52.6 cm x 54.9 cm
- 28.7 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 2-year warranty
- Fax Type
- Plain paper
- Laser - colour
- 4000 pages
- Display Diagonal Size
- 5"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- United Kingdom
- Standard Memory
- 512 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
Printing
- Printer Drivers / Emulations
- PCL 6, BR-Script 3, PDF 1.7, XPS
- First Print Out Time B/W
- 15 sec
- First Print Out Time Colour
- 15 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
- Scanning Resolution Details
- 1200 x 600 dpi - ADF , 1200 x 2400 dpi - flatbed
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Fax Resolutions
- Reception Memory Capacity
- Up to 500 pages
- Transmission Memory Capacity
- Up to 500 pages
- PC Faxing
Fax Machine Features
- Broadcast Transmission
- 350 stations
- Automatic redialing, group dialling
Document & Media Handling
- Max Original Size
- 215.9 x 355.6 mm
- Original Type
- Sheets
- 70 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 300 sheets
- 50 sheets
- 150 sheets
- ADF - 70 sheets size: 105 x 147.3 mm - 215.9 x 355.6 mm weight: 64 g/m² - 90 g/m² , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 50 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 31 ppm (A4) - B/W , Printing: up to 31 ppm (A4) - colour , Printing: up to 14 spm (A4) - B/W duplex , Printing: up to 14 spm (A4) - colour duplex , Scanning: up to 28 ppm - B/W , Scanning: up to 28 ppm - colour , Scanning: up to 56 ipm - B/W duplex , Scanning: up to 56 ipm - colour duplex , Printing: up to 33 ppm (Letter A) - B/W , Printing: up to 33 ppm (Letter A) - colour , Printing: up to 14 spm (Letter A) - B/W duplex , Printing: up to 14 spm (Letter A) - colour duplex , Copying: up to 31 ppm - B/W , Copying: up to 31 ppm - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Kerberos, LDAP, SSL, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, TKIP, AES, ARP, TTLS
- Operating System Support
- Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, Android, iOS, MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows Phone, Windows 10 (32/64-bits), Apple Mac OS X 10.11, macOS 10.12, MS Windows Server 2016
- Voltage Required
- 580 Watt
- Power Consumption Standby
- 70 Watt
- Power Consumption Sleep
- 10 Watt
- First Copy Out Time B/W
- 16 sec
- First Copy Out Time Colour
- 17 sec
- Included Accessories
- Phone cable
- Consumables Included
- 1 x toner cartridge (black) - up to 3000 pages , 1 x toner cartridge (cyan) - up to 1800 pages , 1 x toner cartridge (magenta) - up to 1800 pages , 1 x toner cartridge (yellow) - up to 1800 pages , 1 x drum - up to 50000 pages 3 pages per job , 1 x transfer unit - up to 130000 pages 3 pages per job , 1 x waste toner collector - up to 50000 pages - Brother WT320CL
- Nordic Swan
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 2 years , Limited warranty - 1 year - on-site
- 49.5 cm
- 52.6 cm
- 54.9 cm
- 28.7 kg
- Shipping Width
- 66.5 cm
- Shipping Depth
- 59.5 cm
- Shipping Height
- 65.4 cm
- Shipping Weight
- 35 kg
- Sound Emission
- 44 dBA (idle) / 49 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
Brother Waste Toner Pack | In Stock | £14.90 |
