The new MFC-L8850CDW delivers the professional business colour print, copy, scan and fax performance that savvy business customers have come to expect from Brother. It also does it at a best-in-class 30ppm colour & mono print speed and includes a host of features designed for today's demanding work environment.
Not only that, but the MFC-L8850CDW also makes sharing a breeze thanks to full PC, tablet and mobile device connectivity via wireless and Wi-Fi direct. The cloud is just a few clicks away using the clear, easy-to-use 9.3cm touchscreen LCD, while back on earth environmental impact is reduced with high-yield toners and print features that can help reduce paper consumption by up to 75%.
High-quality color printing
With print speeds up to 32ppm in both color and black, you no longer have to wait for high-impact business documents. -
Advanced duplex capability
Two-sided printing to help save paper. Plus, scans both sides of the page in a single-pass for fast, two-sided copying, scanning, faxing. -
Flexible connectivity
Print, scan or PC fax over your wireless or Ethernet network or connect locally to a single computer via USB‡. -
4.85" color TouchScreen display
Offers intuitive menu navigation, shortcuts, and scanning to popular cloud services. -
Convenient mobile device printing & scanning
Print from your mobile device and wirelessly scan to your mobile device with the Brother iPrint&Scan app. -
Flexible paper handling
The MFC-L8850CDW features a 250-sheet capacity tray that is adjustable for letter or legal-size paper, plus a 50-sheet capacity multi-purpose tray. -
Advanced scanning capabilities
Supports a variety of "scan to" functions including: e-mail, file, USB, Network Folder and other. The product has advanced scanning features including base color (background) removal, ID Scan continuous scanning and blank page skip help ensure your scans come out right the first time. -
Legal-size document glass
Easily copy or color scan bound materials or up to legal-size documents.
- Brother MFC-L8850CDW - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 60000 pages
- Recommended Monthly Volume
- 750 - 4000 pages
- Max Copying Resolution
- Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
- Max Printing Speed
- Up to 30 ppm (mono) / up to 30 ppm (colour)
- Max Printing Resolution
- Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
- Scanning
- 1200 x 2400 dpi
- Display
- 4.85"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper, glossy paper
- Standard Media Capacity
- 300 sheets
- Max Media Capacity
- 800 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Power
- AC 230 V (50/60Hz)
- 49 cm x 52.6 cm x 53 cm
- 31 kg
- Microsoft Certification
- Compatible with Windows 7
- Fax Type
- Plain paper
- Laser - colour
- 60000 pages
- 750 - 4000 pages
- Display Diagonal Size
- 4.85"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 256 MB
- Max Supported Memory
- 512 MB
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PDF 1.7, XPS
- First Print Out Time B/W
- 15 sec
- First Print Out Time Colour
- 15 sec
Scanning
- Optical Resolution
- 1200 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Fax Resolutions
- Reception Memory Capacity
- Up to 500 pages
- Transmission Memory Capacity
- Up to 500 pages
Fax Machine Features
- Error Correction Mode (ECM)
- Telephone / Fax Switch
- Broadcast Transmission
- 350 stations
- Fax forwarding, automatic redialing, auto reduction, Distinctive Ring Detection (DRD), Duplex Fax
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm)
- 300 sheets
- 800 sheets
- 50 sheets
- 150 sheets
- Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , ADF - 50 sheets size: 147.3 x 147.3 mm - 215.9 x 355.6 mm , Bypass tray - 50 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 30 ppm (A4) - B/W , Printing: up to 30 ppm (A4) - colour , Printing: up to 14 spm (A4) - B/W duplex , Printing: up to 14 spm (A4) - colour duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Kerberos, SSL, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, WPS, ARP, Wi-Fi Direct
- Operating System Support
- MS Windows XP, Linux, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition, Windows 8.1, Apple Mac OS X 10.9, Windows 8.1 64-bit, MS Windows Server 2012 R2 x64 Edition
- Voltage Required
- 565 Watt
- Power Consumption Standby
- 65 Watt
- Power Consumption Sleep
- 10.5 Watt
- First Copy Out Time B/W
- 18 sec
- First Copy Out Time Colour
- 20 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 2500 pages , 1 x toner cartridge (cyan) - up to 1500 pages , 1 x toner cartridge (magenta) - up to 1500 pages , 1 x toner cartridge (yellow) - up to 1500 pages
- 49 cm
- 52.6 cm
- 53 cm
- 31 kg
- Shipping Width
- 66 cm
- Shipping Depth
- 62.5 cm
- Shipping Height
- 69.8 cm
- Shipping Weight
- 36.8 kg
- Sound Emission
- 28 dBA (idle) / 56 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
