Brother MFC-L8690CDW Colour Laser Multifunction Printer
Quicklinx: CTP4WS00 Mfr#: MFCL8690CDWZU1
More than 50 In Stock
£313.50 ex VAT
£376.20 inc VAT
MFC-L8690CDW
High-resolution colour laser all-inone printer with outstanding print speeds of up to 31ppm and 2-sided scan speeds of up to 56ipm in both colour and mono. You can be confident that efficiency has been at the heart of the design.
Key Features
  • Fast print speeds of up to 31ppm colour and mono
  • Paper input of up to 300 Sheets
  • Maximum paper input of up to 1050 sheets
  • Automatic 2-Sided Printing
  • 2-sided scan speed of 56ipm colour & mono
  • Optional high-yield replacement cartridges 6500 black 4000 page cyan magenta and yellow toner cartridge
  • High speed wired (10Base-T/100 Base- TX/1000Base-T) and wireless (IEEE 802.11b/g/n) network interfaces
  • Intuitive 9.3cm Colour Touchscreen
Increase productivity levels
  • Productivity is increased significantly thanks to the fast print speeds of up to 31ppm and 2-sided scan speeds of up to 56ipm in colour and mono.
  • Maximise your efficiency with built-in wireless IEEE 802.11b/g/n and ethernet 10Base-T/100Base-TX/1000Base-T.
  • Easily print from your mobile device using Brother’s iPrint&Scan Brother print service plugin for Android Google Cloud Print 2.0 Mopria and AirPrint.
  • Outstanding paper handling options with a standard paper capacity of up to 300 sheets to 1050 sheets.
Meeting security challenges
Modern businesses demand the highest levels of security. With Secure Function Lock 3.0 Active Directory Authentication Internet Protocol Security (IPsec) 802.1x and Secure Print you can be confident that your documents are safe
Flexible and low running costs
Designed for high volume printing environments the MFC-L8690CDW includes a 3000 page black and 1800 page cyan magenta and yellow toners and can take optional 6500 page black and 4000 page cyan magenta and yellow toners to lower your running costs even further.
  • Efficient connectivity
    With a wide array of connectivity options including Gigabit Ethernet, USB 2.0, USB host, and Wi-Fi, alongside mobile printing capabilities like Apple AirPrint and Google Cloud Print 2.0, this device ensures seamless integration into any work environment.
  • Advanced security
    Equipped with robust security protocols such as 802.1x, AES, ARP, IPsec, Kerberos, LDAP, SSL, TKIP, TLS, TTLS, WEP, WPA-PSK, and WPA2-PSK, the MFC-L8690CDW safeguards sensitive information, making it ideal for confidential document handling.
  • High-quality printing and copying
    Achieve professional-grade prints and copies with up to 2400 x 600 DPI resolution for both color and B/W, automatic duplexing for efficient paper use, and fast print speeds of up to 31 ppm, ensuring productivity remains high.
  • Versatile media handling
    This multifunction printer supports a broad range of media sizes and types, including envelopes, labels, plain paper, recycled paper, thick paper, and thin paper, making it suitable for various printing needs.
  • Eco-friendly design
    With ENERGY STAR certification and Blue Angel compliance, the MFC-L8690CDW is recognized for its energy efficiency and eco-friendly design, contributing to lower energy costs and environmental impact.
Brother MFC-L8690CDW - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
United Kingdom
Printing Technology
Laser (colour)
Recommended Monthly Volume
3000 pages
Max Copying Speed
Up to 31 ppm (mono) / up to 31 ppm (colour)
Max Copying Resolution
Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
Scanning
1200 x 2400 dpi
Display
3.7"
Original Size
215.9 x 355.6 mm (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
Standard Media Capacity
300 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, scan to USB host
AC 230 V (50/60Hz)
43.5 cm x 52.6 cm x 53.9 cm
27.9 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Fax Type
Plain paper
Printing Technology
Laser - colour
3000 pages
Display Diagonal Size
3.7"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
United Kingdom
Standard Memory
512 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, BR-Script 3, PDF 1.7, XPS
Automatic Duplexing
First Print Out Time B/W
15 sec
First Print Out Time Colour
15 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Scanning Resolution Details
1200 x 600 dpi - ADF , 1200 x 2400 dpi - flatbed
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Reception Memory Capacity
Up to 500 pages
Transmission Memory Capacity
Up to 500 pages
PC Faxing
Fax Machine Features
Broadcast Transmission
350 stations
Automatic redialing, group dialling
Document & Media Handling
Max Original Size
215.9 x 355.6 mm
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
300 sheets
50 sheets
150 sheets
ADF - 50 sheets size: 105 x 147.3 mm - 215.9 x 355.6 mm weight: 64 g/m² - 90 g/m² , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 50 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 31 ppm (A4) - B/W , Printing: up to 31 ppm (A4) - colour , Printing: up to 14 spm (A4) - B/W duplex , Printing: up to 14 spm (A4) - colour duplex , Scanning: up to 28 ppm - B/W , Scanning: up to 28 ppm - colour , Scanning: up to 56 ipm - B/W duplex , Scanning: up to 56 ipm - colour duplex , Printing: up to 33 ppm (Letter A) - B/W , Printing: up to 33 ppm (Letter A) - colour , Printing: up to 14 spm (Letter A) - B/W duplex , Printing: up to 14 spm (Letter A) - colour duplex , Copying: up to 31 ppm - B/W , Copying: up to 31 ppm - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
Kerberos, LDAP, SSL, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, TKIP, AES, ARP, TTLS
Operating System Support
Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, Android, iOS, MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows Phone, Windows 10 (32/64-bits), Apple Mac OS X 10.11, macOS 10.12, MS Windows Server 2016
AC 230 V (50/60Hz)
580 Watt
Power Consumption Standby
70 Watt
Power Consumption Sleep
10 Watt
First Copy Out Time B/W
16 sec
First Copy Out Time Colour
17 sec
Phone cable
Consumables Included
1 x toner cartridge (black) - up to 3000 pages , 1 x toner cartridge (cyan) - up to 1800 pages , 1 x toner cartridge (magenta) - up to 1800 pages , 1 x toner cartridge (yellow) - up to 1800 pages , 1 x drum - up to 50000 pages 3 pages per job , 1 x transfer unit - up to 130000 pages 3 pages per job , 1 x waste toner collector - up to 50000 pages - Brother WT320CL
Nordic Swan
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 2 years , Limited warranty - 1 year - on-site
43.5 cm
52.6 cm
53.9 cm
27.9 kg
Shipping Width
66.3 cm
Shipping Depth
54.2 cm
Shipping Height
65.4 cm
Shipping Weight
33.7 kg
Sound Emission
44 dBA (idle) / 49 dBA (operating)
10 °C
32 °C
20 - 80% (non-condensing)
CTP4 Brother Waste Toner Pack In Stock £14.47
Functionality: Printer
Functionality: Copier
Functionality: Fax
Functionality: Scanner
Max Paper Size: A4 (210 x 297 mm)
Brand: Brother
