Speed is everything in a competitive marketplace and the MFC-L8650CDW delivers print that's not only faster, but also more productive, smarter and more economical. Best-in-class print speeds of up to 28ppm - colour or mono - keep productivity up, while high yield toners and automatic 2-sided printing keep running costs down.
With a 9.3cm touchscreen LCD screen, all users can quickly select this multifunction printer's many easy-to-use features and settings. And if they're tied up elsewhere, they can still take advantage of its comprehensive mobile connectivity to scan, print and share from their smartphones and tablets using Brother's specialist apps.
- Brother MFC-L8650CDW - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 40000 pages
- Recommended Monthly Volume
- 500 - 3000 pages
- Max Copying Resolution
- Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
- Max Printing Speed
- Up to 28 ppm (mono) / up to 28 ppm (colour)
- Max Printing Resolution
- Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
- Scanning
- 1200 x 2400 dpi
- Display
- 3.7"
- Original Size
- 215.9 x 355.6 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper, glossy paper
- Standard Media Capacity
- 300 sheets
- Max Media Capacity
- 800 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, AOSS
- Power
- AC 230 V (50/60Hz)
- 41 cm x 50.3 cm x 49.2 cm
- 30.4 kg
- Microsoft Certification
- Compatible with Windows 7
- Fax Type
- Plain paper
- Laser - colour
- 40000 pages
- 500 - 3000 pages
- Display Diagonal Size
- 3.7"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 256 MB
- Max Supported Memory
- 512 MB
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3
- First Print Out Time B/W
- 15 sec
- First Print Out Time Colour
- 15 sec
Scanning
- Optical Resolution
- 1200 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Fax Resolutions
- Reception Memory Capacity
- Up to 500 pages
- Transmission Memory Capacity
- Up to 500 pages
Fax Machine Features
- Broadcast Transmission
- 350 stations
- Group dialling
Document & Media Handling
- Max Original Size
- 215.9 x 355.6 mm
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm)
- 300 sheets
- 800 sheets
- 50 sheets
- 150 sheets
- Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , ADF - 35 sheets size: 147.3 x 147.3 mm - 215.9 x 355.6 mm weight: 64 g/m² - 90 g/m² , Bypass tray - 50 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 28 ppm (A4) - B/W , Printing: up to 28 ppm (A4) - colour , Printing: up to 14 spm (A4) - B/W duplex , Printing: up to 14 spm (A4) - colour duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Kerberos, SSL, WEP, WPA-PSK, TLS, 802.1x, WPA2-PSK, WPS, ARP, Wi-Fi Direct
- Operating System Support
- MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8.x, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.9, Apple Mac OS X 10.7.5, MS Windows Server 2012 R2 x64 Edition
- Voltage Required
- 565 Watt
- Power Consumption Standby
- 65 Watt
- Power Consumption Sleep
- 9.5 Watt
- First Copy Out Time B/W
- 18 sec
- First Copy Out Time Colour
- 20 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 2500 pages - Brother TN321BK , 1 x toner cartridge (cyan) - up to 1500 pages - Brother TN321C , 1 x toner cartridge (magenta) - up to 1500 pages - Brother TN321M , 1 x toner cartridge (yellow) - up to 1500 pages - Brother TN321Y
- 41 cm
- 50.3 cm
- 49.2 cm
- 30.4 kg
- Sound Emission
- 28 dBA (idle) / 55 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
