Brother MFC-L3740CDWE Colourful and Connected LED All-in-One
Quicklinx: HX0PWS00 Mfr#: MFCL3740CDWEZU1
10 In Stock
£305.47 ex VAT
£366.56 inc VAT
  • Advanced connectivity
    Equipped with Gigabit Ethernet, USB 2.0, and Wi-Fi(n) interfaces, this multifunction device ensures seamless integration into any office network, offering flexible connection options for a streamlined workflow.
  • Robust security features
    Featuring a comprehensive suite of security protocols including AES, SSL, and WPA3-SAE, alongside advanced functions like secure function lock v3 and automatic intrusion detection, the MFC-L3740CDWE prioritizes data integrity and privacy in every operation.
  • Efficient document handling
    With an automatic document feeder (ADF) capable of handling 50 sheets, and a standard media capacity of 250 sheets, this device supports a variety of media sizes and types, from envelopes to thick paper, enhancing office productivity.
  • High-quality printing and copying
    Achieve professional color and B/W documents with 600 x 600 DPI resolution. Automatic duplexing and speeds of up to 18 ppm for both color and B/W printing make this device ideal for fast-paced office environments.
  • Eco-friendly design
    Certified by ENERGY STAR and Blue Angel, the MFC-L3740CDWE is designed for energy efficiency, reducing environmental impact while also cutting down on operational costs.
Brother MFC-L3740CDWE - multifunction printer - colour - with 4 months EcoPro subscription
Multifunction printer
Fax Type
Super G3 - plain paper
Bundled Services
Printing Technology
LED (colour)
Recommended Monthly Volume
Up to 3000 pages
Max Copying Speed
Up to 18 ppm (mono) / up to 18 ppm (colour)
Max Copying Resolution
600 x 600 dpi (colour)
Max Copying Resolution Class
Max Printing Speed
Max Printing Resolution
Up to 600 x 2400 dpi (mono) / up to 600 x 2400 dpi (colour)
Max Printing Resolution Class
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 1200 dpi
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 116 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, thin paper, thick paper, recycled paper, bond paper, labels, glossy paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n)
Office Machine Features
Scan to e-mail, scan to OCR, scan to image, scan to network folder, scan to SMB, scan to FTP, scan to e-mail server, scan to SharePoint, scan to folder
41 cm x 44.4 cm x 40.1 cm
20 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Fax Type
Plain paper
Bundled Services
Printing Technology
LED - colour
Up to 3000 pages
Display Colour Support
Display Features
Touch screen
Standard Memory
512 MB
Copying
Max Copying Speed
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 5e, PCL 5c, BR-Script 3, PDF 1.7, PCL 6 (XL 3.0)
Automatic Duplexing
First Print Out Time B/W
15 sec
First Print Out Time Colour
15 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Document & Media Handling
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 116 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), B5 (176 x 250 mm), JIS B6 (128 x 182 mm), Folio (203 x 330 mm), 195 x 270 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
250 sheets
1 sheet
150 sheets
Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 1 sheet size: 76.2 x 116 mm - 216 x 355.6 mm weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets , ADF - 50 sheets size: 105 x 147.3 mm - 215.9 x 355.6 mm weight: 60 g/m² - 105 g/m²
Speed Details
Printing: up to 18 ppm (A4) - B/W , Printing: up to 18 ppm (A4) - colour , Printing: up to 7 spm (A4) - duplex normal , Copying: up to 18 ppm (A4) - B/W , Copying: up to 18 ppm (A4) - colour , Scanning: up to 21 ipm - colour (ISO/IEC 17991) , Scanning: up to 27 ipm - B/W (ISO/IEC 17991)
1 x USB 2.0 , 1 x Gigabit LAN
Security Protocols & Features
Wi-Fi Direct, APOP, SMTP, SSL, TLS, SNMP 3, 802.1x, EAP-MD5, EAP-FAST, PEAP, EAP-TLS, EAP-TTLS, Kerberos, IPsec, automatic intrusion detection, digitally-signed firmware, IP filtering, port-based network access control, restrict network protocols, secure function lock v3, Secure Print, setting lock, syslog reporting, store print log, WEP, WPA-PSK, WPA2-PSK, WPA3-SAE, AES, TKIP, LDAP, active directory
460 Watt
Power Consumption Standby
70 Watt
Power Consumption Sleep
10 Watt
Consumables Included
1 x toner cartridge (black) - up to 500 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 500 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 500 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 500 pages ISO/IEC 19798 , 1 x drum - up to 20000 pages 1 page per job - Brother DR248CL , 1 x belt - up to 50000 pages 2 pages per job - Brother BU229CL , 1 x waste toner collector - up to 50000 pages 5 pages per job - Brother WT229CL
Nordic Swan Ecolabel
ENERGY STAR Certified
Blue Angel Compliant
41 cm
44.4 cm
40.1 cm
20 kg
Shipping Width
49.7 cm
Shipping Depth
53.6 cm
Shipping Height
53.3 cm
Shipping Weight
23.3 kg
Sound Emission
46 dBA (operating)
Functionality: Copier
Functionality: Printer
Functionality: Scanner
Functionality: Fax
Max Paper Size: A4 (210 x 297 mm)
Brand: Brother
