Brother MFC-L3710CW Colour Laser Multifunction Printer
Quicklinx: F7K3WS00 Mfr#: MFCL3710CWZU1
The Brother MFC-L3710CW digital color all-in-one printer is a great option for home and small offices looking for laser printer performance that need print, copy, scan and fax functionality. Offers flexible connection options plus wireless printing from mobile devices (1). Use the 50-sheet automatic document feeder for multi-page copy, scan and fax and the manual feed slot for varied paper types and sizes. Create custom shortcuts on the 3.7" color touchscreen plus print-from and scan-to popular cloud apps.
  • Fast printing and scanning keeps you moving
    Delivering increased efficiency with quick print speeds of up to 19 pages per minute and scan speeds up to 29ipm black and 22ipm color.
  • Print professional documents in black and color
    Print high-quality business documents in sharp black and rich, vivid color.
  • Engineered to deliver efficiency and help increase productivity
    The 250-sheet capacity paper tray adjusts for letter or legal paper to help minimize paper refills while the up to 50-sheet automatic document feeder helps save time with multi-page copy, scan & fax.
  • Flexible printing options
    The manual feed slot offers flexible paper handling for a variety of papers and sizes, including card stock, envelopes and more to accommodate varied printing needs.
  • Printing as mobile as you are
    Print wirelessly from your desktop, laptop, smartphone and tablet.
  • Intuitive connection to the Cloud
    Print-from and scan-to popular cloud apps directly from the 3.7" color touchscreen including Dropbox, Google Drive, Evernote,
  • Connect your way
    Versatile connection options with built-in wireless, and Wi-Fi Direct or connect locally to a single computer via USB interface.
  • Dependable, durable and compact design
    Sturdy and robust construction ensures your printer works as hard as you do; compact design is ideal for smaller spaces.
Brother MFC-L3710CW - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
United Kingdom
Printing Technology
LED (colour)
Recommended Monthly Volume
300 - 1500 pages
Max Copying Speed
Up to 18 ppm (mono) / up to 18 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Copying Resolution Class
Max Printing Speed
Max Printing Resolution
Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
Max Printing Resolution Class
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
Scanning
1200 x 2400 dpi
Display
3.7"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 116 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper, glossy paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
150 sheets
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to FTP, scan to SharePoint, scan to OCR, scan to image
AC 230 V (50/60Hz)
41 cm x 47.5 cm x 41.4 cm
22.5 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
LED - colour
300 - 1500 pages
Display Diagonal Size
3.7"
Display Colour Support
Display Features
Touch screen
USB 2.0, Wi-Fi(n)
AirPrint Enabled
United Kingdom
Standard Memory
512 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
Sort
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, BR-Script 3, PDF 1.7, XPS 1.0
First Print Out Time B/W
15.5 sec
First Print Out Time Colour
15.5 sec
Colour Management Features
Mopria
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Scanning Resolution Details
1200 x 2400 dpi - flatbed , 600 x 600 dpi - ADF
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Reception Memory Capacity
Up to 500 pages
Transmission Memory Capacity
Up to 500 pages
PC Faxing
Fax Machine Features
Speed Dialing
200 station(s)
Broadcast Transmission
250 stations
Automatic redialing, group dialling
Document & Media Handling
Max Original Size
Supported Original Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), 215.9 x 300 mm
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 116 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
250 sheets
1 sheet
150 sheets
Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , ADF - 50 sheets size: 105 x 147.3 mm - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 1 sheet size: 76.2 x 116 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 18 ppm (A4) - B/W , Printing: up to 19 ppm (Letter A) - B/W , Printing: up to 18 ppm (A4) - colour , Printing: up to 19 ppm (Letter A) - colour , Copying: up to 18 ppm - B/W , Copying: up to 18 ppm - colour , Scanning: up to 27 ipm - B/W , Scanning: up to 21 ipm - colour
1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
Kerberos, SSL, LEAP, WEP, WPA-PSK, TLS, 802.1x, WPA2-PSK, WPS, ARP, PEAP, SNMP 3
Operating System Support
Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, Android, iOS, MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows Phone, Windows 10 (32/64-bits), Apple Mac OS X 10.11, macOS 10.12, MS Windows Server 2016, macOS 10.13, Windows 10 in S mode, macOS 10.14
AC 230 V (50/60Hz)
400 Watt
Power Consumption Standby
80 Watt
Power Consumption Sleep
9.7 Watt
First Copy Out Time B/W
17.5 sec
First Copy Out Time Colour
17.5 sec
Consumables Included
1 x toner cartridge (black) - up to 1000 pages ISO/IEC 19752 , 1 x toner cartridge (cyan) - up to 1000 pages ISO/IEC 19752 , 1 x toner cartridge (magenta) - up to 1000 pages ISO/IEC 19752 , 1 x toner cartridge (yellow) - up to 1000 pages ISO/IEC 19752 , 1 x drum - up to 18000 pages - Brother DR243CL , 1 x transfer unit - up to 50000 pages - Brother BU223CL , 1 x waste toner collector - up to 50000 pages - Brother WT223CL
ENERGY STAR Certified
Limited warranty - 2 years , Limited warranty - 1 year - on-site
41 cm
47.5 cm
41.4 cm
22.5 kg
Shipping Width
58.9 cm
Shipping Depth
52.3 cm
Shipping Height
56.8 cm
Shipping Weight
26.7 kg
Sound Emission
43 dBA (idle) / 45 dBA (operating)
10 °C
32 °C
20 - 80% (non-condensing)
F7K3 Brother TN243BK Toner Black In Stock £40.46
