Work smarter from anywhere at home or in the office with the easily connected Brother MFC-L2860DWE. Hosting a range of efficiency-boosting features, this multifunction mono laser printer saves you time with fast flawless printing and quick scan speeds, automatic 2-sided print, fax capability, a generous paper tray capacity and large automatic document feeder.
Effortless
Make your day easier and your printing effortless, with simple setup and fast Ethernet, 5 GHz Wi-Fi or USB connection. This efficient MFC-L2860DWE is a breeze to operate using the easy to navigate menu on the color touchscreen. Benefit from the ability to create custom shortcuts on the touchscreen for your most used functions. -
Print longer
The MFC-L2860DWE keeps your printing costs down using a separate drum and toner unit, and inbox toner supporting your higher print volume needs. -
The perfect partner
High-quality print technology ensures that your output is flawless and professional every time. The expertly designed MFC-L2860DWE has a high-capacity paper input and output tray allowing you to print for longer, while the compact and quiet form enables you to work without interruption in smaller workspaces. -
Secure by design
Brother's devices offer industry-standard security features to securely protect your data. Their security experts continuously research different enhancements to products, solutions and services to proactively ensure all their products are 'secure by design'. Your Brother mono laser A4 printer uses triple-layer security at a device, network and document level, adding peace of mind that the integrity of your data is maintained at every step.
- Brother MFC-L2860DWE - multifunction printer - B/W - with 4 months EcoPro subscription
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Bundled Services
- 4 months EcoPro subscription
- Printing Technology
- Laser (monochrome)
- Recommended Monthly Volume
- Up to 2500 pages
- Max Copying Speed
- Up to 34 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Copying Resolution Class
- Max Printing Speed
- Up to 34 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Printing Resolution Class
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 1200 dpi
- Original Size
- Letter A (216 x 279 mm)/A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - 215.9 x 355.6 mm (max)
- Media Type
- Plain paper, thin paper, recycled paper, thick paper, bond paper, labels, envelopes
- Standard Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 120 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- Office Machine Features
- Scan to e-mail, scan to OCR, scan to image, scan to folder, scan to network folder, scan to FTP, scan to e-mail server, scan to SharePoint
- 41 cm x 39.9 cm x 31.9 cm
- 11.6 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 3-year warranty
- Fax Type
- Plain paper
- Bundled Services
- Laser - monochrome
- Up to 2500 pages
- Display Colour Support
- Display Features
- Touch screen
- Interface
- Standard Memory
- 256 MB
Copying
- Max Copying Speed
- Up to 34 ppm
Printing
- Up to 34 ppm
- Printer Drivers / Emulations
- PCL 6, BR-Script 3, PDF 1.7
- First Print Out Time B/W
- 8.5 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 230 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), JIS B5 (182 x 257 mm), B5 (176 x 250 mm), A5 (148 x 210 mm), JIS B6 (128 x 182 mm), A6 (105 x 148 mm), Executive (184 x 267 mm), 195 x 270 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 250 sheets
- 1 sheet
- 120 sheets
- Input tray - 250 sheets - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , ADF - 50 sheets - 216 x 356 mm weight: 60 g/m² - 105 g/m² , Bypass tray - 1 sheet size: 76.2 x 127 mm - 215.9 x 355.6 mm weight: 60 g/m² - 230 g/m² , Output tray - 120 sheets
- Speed Details
- Printing: up to 34 ppm (A4) - B/W , Printing: up to 16 ppm (A4) - B/W duplex , Scanning: up to 22.5 ipm - B/W (ISO/IEC 17991) , Scanning: up to 7.5 ipm - colour (ISO/IEC 17991) , Copying: up to 34 ppm (A4) - B/W
- 1 x USB 2.0 , 1 x LAN
- Wi-Fi Direct, APOP, SMTP, SSL, TLS, SNMP 3, 802.1x, EAP-MD5, EAP-FAST, PEAP, EAP-TLS, EAP-TTLS, POP3, WEP, WPA-PSK, WPA2-PSK, WPA3-SAE, AES, TKIP, automatic intrusion detection, digitally-signed firmware, IP filtering, port-based network access control, restrict network protocols, secure function lock v3, secure key management, Secure Print, setting lock
- 490 Watt
- Power Consumption Standby
- 43 Watt
- Power Consumption Sleep
- 4.1 Watt
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages ISO/IEC 19752 , 1 x drum - up to 15000 pages 1 page per job - Brother DR2510
- Nordic Swan Ecolabel
- ENERGY STAR Certified
- Blue Angel Compliant
- 3-year warranty
- 41 cm
- 39.9 cm
- 31.9 cm
- 11.6 kg
- Shipping Width
- 58 cm
- Shipping Depth
- 51.7 cm
- Shipping Height
- 43.4 cm
- Shipping Weight
- 14.1 kg
- Sound Emission
- 30 dBA (idle) / 49 dBA (operating)
