Brother MFC-L2860DWE Your Efficient All-in-One A4 Mono Laser Printer
Quicklinx: HWZPWS00 Mfr#: MFCL2860DWEZU1
15 In Stock
£211.82 ex VAT
£254.18 inc VAT
Work smarter from anywhere at home or in the office with the easily connected Brother MFC-L2860DWE. Hosting a range of efficiency-boosting features, this multifunction mono laser printer saves you time with fast flawless printing and quick scan speeds, automatic 2-sided print, fax capability, a generous paper tray capacity and large automatic document feeder.
  • Effortless
    Make your day easier and your printing effortless, with simple setup and fast Ethernet, 5 GHz Wi-Fi or USB connection. This efficient MFC-L2860DWE is a breeze to operate using the easy to navigate menu on the color touchscreen. Benefit from the ability to create custom shortcuts on the touchscreen for your most used functions.
  • Print longer
    The MFC-L2860DWE keeps your printing costs down using a separate drum and toner unit, and inbox toner supporting your higher print volume needs.
  • The perfect partner
    High-quality print technology ensures that your output is flawless and professional every time. The expertly designed MFC-L2860DWE has a high-capacity paper input and output tray allowing you to print for longer, while the compact and quiet form enables you to work without interruption in smaller workspaces.
  • Secure by design
    Brother's devices offer industry-standard security features to securely protect your data. Their security experts continuously research different enhancements to products, solutions and services to proactively ensure all their products are 'secure by design'. Your Brother mono laser A4 printer uses triple-layer security at a device, network and document level, adding peace of mind that the integrity of your data is maintained at every step.
Brother MFC-L2860DWE - multifunction printer - B/W - with 4 months EcoPro subscription
Multifunction printer
Fax Type
Super G3 - plain paper
Bundled Services
Printing Technology
Laser (monochrome)
Recommended Monthly Volume
Up to 2500 pages
Max Copying Speed
Up to 34 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Copying Resolution Class
Up to 600 x 600 dpi
Max Printing Speed
Up to 34 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Printing Resolution Class
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 1200 dpi
Original Size
Letter A (216 x 279 mm)/A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - 215.9 x 355.6 mm (max)
Media Type
Plain paper, thin paper, recycled paper, thick paper, bond paper, labels, envelopes
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
120 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n)
Office Machine Features
Scan to e-mail, scan to OCR, scan to image, scan to folder, scan to network folder, scan to FTP, scan to e-mail server, scan to SharePoint
41 cm x 39.9 cm x 31.9 cm
11.6 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
3-year warranty
Fax Type
Plain paper
Bundled Services
Printing Technology
Laser - monochrome
Up to 2500 pages
Display Colour Support
Display Features
Touch screen
Standard Memory
256 MB
Copying
Max Copying Speed
Up to 34 ppm
Up to 600 x 600 dpi
Up to 600 x 600 dpi
Printing
Max Printing Speed
Up to 34 ppm
Printer Drivers / Emulations
PCL 6, BR-Script 3, PDF 1.7
Automatic Duplexing
First Print Out Time B/W
8.5 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4
Min Media Weight
60 g/m²
Max Media Weight
230 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), JIS B5 (182 x 257 mm), B5 (176 x 250 mm), A5 (148 x 210 mm), JIS B6 (128 x 182 mm), A6 (105 x 148 mm), Executive (184 x 267 mm), 195 x 270 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
250 sheets
1 sheet
120 sheets
Input tray - 250 sheets - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , ADF - 50 sheets - 216 x 356 mm weight: 60 g/m² - 105 g/m² , Bypass tray - 1 sheet size: 76.2 x 127 mm - 215.9 x 355.6 mm weight: 60 g/m² - 230 g/m² , Output tray - 120 sheets
Speed Details
Printing: up to 34 ppm (A4) - B/W , Printing: up to 16 ppm (A4) - B/W duplex , Scanning: up to 22.5 ipm - B/W (ISO/IEC 17991) , Scanning: up to 7.5 ipm - colour (ISO/IEC 17991) , Copying: up to 34 ppm (A4) - B/W
1 x USB 2.0 , 1 x LAN
Security Protocols & Features
Wi-Fi Direct, APOP, SMTP, SSL, TLS, SNMP 3, 802.1x, EAP-MD5, EAP-FAST, PEAP, EAP-TLS, EAP-TTLS, POP3, WEP, WPA-PSK, WPA2-PSK, WPA3-SAE, AES, TKIP, automatic intrusion detection, digitally-signed firmware, IP filtering, port-based network access control, restrict network protocols, secure function lock v3, secure key management, Secure Print, setting lock
490 Watt
Power Consumption Standby
43 Watt
Power Consumption Sleep
4.1 Watt
Consumables Included
1 x toner cartridge (black) - up to 700 pages ISO/IEC 19752 , 1 x drum - up to 15000 pages 1 page per job - Brother DR2510
Nordic Swan Ecolabel
ENERGY STAR Certified
Blue Angel Compliant
3-year warranty
41 cm
39.9 cm
31.9 cm
11.6 kg
Shipping Width
58 cm
Shipping Depth
51.7 cm
Shipping Height
43.4 cm
Shipping Weight
14.1 kg
Sound Emission
30 dBA (idle) / 49 dBA (operating)
Functionality: Copier
Functionality: Printer
Functionality: Fax
Functionality: Scanner
Max Paper Size: 215.9 x 355.6 mm
Brand: Brother
