Compact and connected the MFC-L2720DW offers mono print, fax, copy and scan direct to the cloud. Wi-Fi and Wired Network connectivity ensures that all your Small Office print, scan, copy and fax needs can be met with the simplest of steps and least hassle.
Including a 6.8cm colour touchscreen for easy menu navigation and with print speeds of up to 30ppm, this mono laser is perfect for quick printing and variable workloads. The 250 sheet paper tray and 35 sheet Automatic Document Feeder mean that you can keep working on the things that matter, while even the biggest printing jobs take care of themselves.
This is a truly connected device, allowing users to print and scan from anywhere using the Brother iPrint&Scan app, Google Cloud Print, Apple AirPrint and Wi-Fi Direct, as well as scan and print capability to and from cloud services such as Dropbox, evernote and onedrive.
With the 1200 page inbox toner, double-sided printing as standard and cost-effective, high-yield toner cartridges available, you can simultaneously reduce unnecessary waste and make genuine long-term cost savings too.
- Brother MFC-L2720DW - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 30 ppm
- Max Printing Resolution
- Up to 2400 x 600 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
- Scanning
- 600 x 2400 dpi
- Display
- 2.7"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
- Standard Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- Office Machine Features
- AOSS
- Power
- AC 230 V (50/60Hz)
- 40.9 cm x 39.85 cm x 31.65 cm
- 11.6 kg
- Microsoft Certification
- Compatible with Windows 7
- Fax Type
- Plain paper
- Laser - monochrome
- Display Diagonal Size
- 2.7"
- Display Features
- Touch screen
- Interface
- AOSS
- Standard Memory
- 64 MB
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Up to 30 ppm
- Image Enhancement Technology
- Brother HQ1200
- First Print Out Time B/W
- 8.5 sec
Scanning
- Optical Resolution
- 600 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 30-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Fax Resolutions
- Reception Memory Capacity
- Up to 500 pages
- Transmission Memory Capacity
- Up to 500 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- One-Touch Dialing
- 8 station(s)
- Speed Dialing
- 200 station(s)
- Telephone / Fax Switch
- Broadcast Transmission
- 250 stations
- Automatic redialing, group dialling
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 76.2 x 127 mm, 215.9 x 355.6 mm
- 250 sheets
- 1 sheet
- 100 sheets
- Input tray - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , ADF - 35 sheets size: 147.3 x 147.3 mm - 215.9 x 355.6 mm , Bypass tray - 1 sheet size: 76.2 x 127 mm - 215.9 x 355.6 mm weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 30 ppm (A4) - B/W , Printing: up to 15 spm (A4) - B/W duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- WPA-PSK, WPA2-PSK, TKIP, AES, ARP
- Operating System Support
- MS Windows Server 2003, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.8.x, MS Windows Server 2012, Windows 8, Windows 8.1, MS Windows Server 2012 R2, Apple Mac OS X 10.7.5, Apple Mac OS X 10.9.x
- Voltage Required
- 510 Watt
- Power Consumption Standby
- 60 Watt
- Power Consumption Sleep
- 1.2 Watt
- First Copy Out Time B/W
- 10 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1200 pages , 1 x drum - up to 12000 pages
- IEC 60825-1:2007
- 40.9 cm
- 39.85 cm
- 31.65 cm
- 11.6 kg
- Shipping Width
- 56.7 cm
- Shipping Depth
- 51.7 cm
- Shipping Height
- 43.5 cm
- Shipping Weight
- 14.6 kg
- Sound Emission
- 33 dBA (idle) / 50 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
