Brother MFC-J6940DW Professional A3 Inkjet Wireless All In One
Quicklinx: HWZXWS00 Mfr#: MFCJ6940DWZU1
£1,230.43 ex VAT
£1,476.51 inc VAT
Discover the Brother MFC-J6940DW, a versatile and powerful office machine designed to meet all your printing, scanning, copying, and faxing needs. With advanced connectivity options including LAN, NFC, USB 2.0, and Wi-Fi(n), this printer ensures easy integration into your existing network and enables printing from anywhere in your office. Mobile printing capabilities with Apple AirPrint and Wi-Fi Direct offer the convenience of printing from your smartphone or tablet. Security is a priority, and the MFC-J6940DW is equipped with comprehensive security protocols such as 802.1x, AES, and IPsec, ensuring your sensitive documents are kept safe. The printer also features automatic duplexing, allowing for paper savings by printing on both sides. With support for A3 size printing and a high capacity of 600 sheets, it's suitable for handling large documents and high-volume printing tasks. The Brother MFC-J6940DW is known for its high-resolution printing and scanning capabilities, making it suitable for producing crisp, clear documents and vibrant images. Whether you're printing reports, scanning contracts, or copying presentations, this printer delivers high-quality results every time.
  • Efficient connectivity
    With a wide range of connectivity options including LAN, NFC, USB 2.0, and Wi-Fi(n), alongside mobile printing capabilities like Apple AirPrint, this printer offers seamless integration into any workspace.
  • Advanced security
    Equipped with robust security protocols including 802.1x, AES, IPsec, and more, ensuring your documents remain secure during transmission.
  • High-quality copying
    Automatic duplexing and resolutions up to 600 x 600 DPI for both black and white and color, provide clear, sharp copies, making it suitable for professional presentations.
  • Versatile media handling
    Supports a variety of media sizes up to A3 and types, with a total capacity of 600 sheets, catering to all your printing needs.
  • Superior printing and scanning
    Offers high-resolution printing up to 1200 x 4800 DPI and scanning with an optical resolution of 1200 x 2400 DPI, delivering exceptional quality for all your documents and images.
Brother MFC-J6940DW - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
4-ink
Recommended Monthly Volume
2500 pages
Max Copying Speed
Up to 25 ppm (mono) / up to 16 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Copying Resolution Class
Max Printing Speed
Up to 28 ppm (mono) / up to 28 ppm (colour)
Max Printing Resolution
Up to 1200 x 4800 dpi (mono) / up to 1200 x 4800 dpi (colour)
Max Printing Resolution Class
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 2400 dpi
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
A3 (297 x 420 mm)/ANSI B (Ledger) (279 x 432 mm) (max)
Media Type
Plain paper, glossy paper, recycled paper
Standard Media Capacity
600 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB 2.0 host, NFC
AirPrint Enabled
Office Machine Features
Scan to image, scan to OCR, scan to network, scan to FTP, scan to e-mail, scan to e-mail server, scan to SharePoint, scan to PDF
57.6 cm x 47.7 cm x 37.5 cm
23.3 kg
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
2500 pages
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
256 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Automatic Duplexing
Printing
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Automatic Duplexing
First Print Out Time B/W
4.6 sec
Scanning
Scan Element
D-CIS
Optical Resolution
1200 x 2400 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
PC Faxing
Document & Media Handling
Original Type
Sheets
50 sheets
Max Media Size
A3/Ledger
Min Media Weight
64 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), ANSI B (Ledger) (279 x 432 mm), Folio (216 x 330 mm), A3 (297 x 420 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 200 mm, 90 x 130 mm, 130 x 180 mm
Supported Envelope Sizes
Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International DL (110 x 220 mm), Monarch (98.4 x 190.5 mm)
600 sheets
100 sheets
100 sheets
2 x input tray - 250 sheets , Multi-purpose tray - 100 sheets , ADF - 50 sheets , Output tray - 100 sheets
Speed Details
Printing: up to 28 ipm - B/W , Printing: up to 28 ipm - colour , Printing: up to 21 ipm - B/W duplex , Printing: up to 21 ipm - colour duplex , Copying: up to 16 ipm - colour , Copying: up to 25 ipm - B/W , Copying: up to 13 ipm - colour duplex , Copying: up to 18 ipm - B/W duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
Wi-Fi Direct, SSL, TLS, Kerberos, IPsec, WEP, WPA-PSK, WPA2-PSK, TKIP, AES, WPA3-SAE, 802.1x, SNMP 3
29 Watt
Power Consumption Standby
5.5 Watt
Power Consumption Sleep
0.9 Watt
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
Limited warranty - 1 year
57.6 cm
47.7 cm
37.5 cm
23.3 kg
Shipping Width
68.1 cm
Shipping Depth
56.1 cm
Shipping Height
49.3 cm
Shipping Weight
26.4 kg
Sound Emission
50 dBA (operating)
10 °C
35 °C
20 - 80%
HWZX Brother A3 GLOSSY PAPER In Stock £17.59
Functionality: Copier
Functionality: Printer
Functionality: Scanner
Functionality: Fax
Max Paper Size: A3 (297 x 420 mm)/ANSI B (Ledger) (279 x 432 mm)
Brand: Brother
Price Range Ex VAT: £1000 - £1500
