Our best A3 inkjet yet
The MFC-J6920DW can help your team to work faster, smarter and more collaboratively.
Connect direct to the cloud and your mobile or tablet for faster results, plus near field communication means you can print instantly by simply holding your device up to the sensor.
With double-sided printing and XL ink cartridges that offer you better value, the MFC-J6920DW cannot only streamline your working processes, but your on-going print costs as well.
Scan, copy fax and print all in one, and take advantage of a range of intelligent features to print professional A3 documents that do your hard work justice.
Key Features
- Print, copy, scan and fax - all up to A3.
- Up to 22ipm mono / 20ipm colour print speeds
- Automatic 2-sided print, copy and scan
- Wired & wireless network ready + mobile/cloud compatible + NFC
- 6.8cm colour touchscreen
- Up to 500 sheet paper capacity
- Brother MFC-J6920DW - multifunction printer ( colour )
- Fax / copier / printer / scanner
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet ( colour )
- Inkjet Technology
- Epson Micro Piezo - 4-ink
- Max Copying Speed
- Up to 12 ppm (mono) / up to 9 ppm (colour)
- Max Copying Resolution
- Up to 1200 x 2400 dpi (mono) / up to 1200 x 2400 dpi (colour)
- Max Printing Speed
- Up to 35 ppm (mono) / up to 27 ppm (colour)
- Max Printing Resolution
- Up to 6000 x 1200 dpi (mono) / up to 6000 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
- Scanning
- 2400 x 2400 dpi
- Display
- 3.7"
- Original Size
- 148 x 148 mm (min) - A3/Ledger (297 x 432 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 89 x 127 mm (min) - A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
- Media Type
- Transparencies, plain paper, photo paper, glossy paper
- Standard Media Capacity
- 500 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 50 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- PC Connection Availability
- PC Connection
- USB 2.0, LAN, Wi-Fi(n), USB host, NFC
- AirPrint Enabled
- Office Machine Features
- Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, AOSS
- Power
- AC 230 V ( 50/60Hz )
- 55.3 cm x 43.3 cm x 31 cm
- 16.7 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified , Blue Angel
- 1 year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- Display Diagonal Size
- 3.7"
- Display Features
- Touch screen
- PC Connection
- AirPrint Enabled
- Standard Memory
- 256 MB
- Supported Flash Memory
- SD Memory Card, MultiMediaCard, Memory Stick Duo, USB flash drive, MultiMediaCardplus, Memory Stick PRO Duo, SDHC Memory Card, SDXC Memory Card
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 420 nozzles (black), 3 x 420 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 4 individual ink tanks
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Ink Type
- Brother Innobella ink
Scanning
- Scan Element
- CIS
- Optical Resolution
- 2400 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grey Scale Depth
- 8 bit
- Colour Depth
- 24 bit
- Colour Depth (Internal)
- 48 bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Reception Memory Capacity
- Up to 200 pages
- Transmission Memory Capacity
- Up to 200 pages
- PC Faxing
Fax Machine Features
- Broadcast Transmission
- 250 stations
- Automatic redialing
Document & Media Handling
- Min Original Size
- 148 x 148 mm
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 89 x 127 mm
- Max Media Size
- A3/Ledger
- Min Media Weight
- 64 g/m2
- Max Media Weight
- 220 g/m2
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), 100 x 150 mm, 130 x 180 mm, Folio (216 x 330 mm), 127 x 203 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 500 sheets
- 1 sheet
- 50 sheets
- Input tray - 250 sheets size: 210 x 279.4 mm - A3/Ledger (297 x 432 mm) , Input tray - 250 sheets size: 89 x 127 mm - A3/Ledger (297 x 432 mm) , Output tray - 50 sheets , ADF - 35 sheets size: 148 x 148 mm - A3/Ledger (297 x 432 mm) , Bypass tray - 1 sheet size: 89 x 127 mm - A3/Ledger (297 x 432 mm)
- Speed Details
- Printing : up to 35 ppm - B/W , Printing : up to 27 ppm - colour , Copying : up to 9 ppm - colour (ISO/IEC 24735) , Copying : up to 12 ppm - B/W (ISO/IEC 24735) , Printing : up to 22 ppm - B/W (ISO/IEC 24734) , Printing : up to 20 ppm - color (ISO/IEC 24734)
- 1 x USB 2.0 - 4 PIN USB Type B , 1 x USB host - 4 PIN USB Type A , 1 x LAN - RJ-45
- WEP, WPA-PSK, WPA2-PSK, WPS, Wi-Fi Direct
- Operating System Support
- MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, Apple Mac OS X 10.7.x, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 R2, MS Windows Server 2003 R2 x64 Edition, Apple Mac OS X 10.8.x, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.6.8
- Software Included
- Drivers & Utilities, Brother MFL-Pro Suite, Presto! PageManager 9 for Mac, Nuance PaperPort 12 SE
- Voltage Required
- 29 Watt
- Power Consumption Standby
- 5.5 Watt
- Power Consumption Sleep
- 1.5 Watt
- Direct Printing Specifications
- PictBridge
- Consumables Included
- 1 x Cartridge ( black ) - up to 390 pages , 1 x Cartridge ( cyan ) - up to 390 pages , 1 x Cartridge ( magenta ) - up to 390 pages , 1 x Cartridge ( yellow ) - up to 390 pages
- Blue Angel Compliant
- 1 year warranty
- Service & Support Details
- Limited warranty - 1 year - on-site
- 55.3 cm
- 43.3 cm
- 31 cm
- 16.7 kg
- Sound Emission
- 50 dBA (operating)
- 10 °C
- 35 °C
- 20 - 80% (non-condensing)
