Brother MFC J6910DW Inkjet All-in-One
Quicklinx: 7CJXWS00 Mfr#: MFCJ6910DWZU1
Print on a variety of paper sizes with the versatility to print. Print two-sided documents in-house. Easy to set up wireless or Ethernet networking with embedded web server support. Two adjustable paper trays hold up to 500 sheets. Uses high or super high yield ink cartridges.
  • Print, copy, scan and fax
    Designed for high impact business documents.
  • Automatic duplex printing
    Save paper with duplex printing.
  • Built-in wireless & wired interfaces
    Easy to setup wireless or wired Ethernet networking.
  • Widescreen color LCD display
    Easily navigate through menus and preview faxes.
  • Versatile auto document feeder
    Unattended fax, scan or copy using the up to 35-sheet auto document feeder.
  • Single sheet bypass tray
    Allows convenient, straight-through, single sheet feeding, envelopes or thicker media.
Brother MFC-J6910DW - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
4-ink
Max Copying Speed
Up to 23 ppm (mono) / up to 20 ppm (colour)
Max Copying Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Printing Speed
Up to 35 ppm (mono) / up to 27 ppm (colour)
Max Printing Resolution
Up to 6000 x 1200 dpi (mono) / up to 6000 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 2400 dpi
Original Size
A3 (297 x 420 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
Media Type
Transparencies, envelopes, plain paper, photo paper
Standard Media Capacity
500 sheets
Output Trays Capacity
50 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network
54 cm x 48.9 cm x 33.1 cm
18.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1-year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
Display Features
Touch screen
Standard Memory
192 MB 192 MB
Supported Flash Memory
Memory Stick, SD Memory Card, MultiMediaCard, Memory Stick PRO, USB flash drive, MultiMediaCardplus, SDHC Memory Card
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Automatic Duplexing
Copying Features
2 on 1, 4 on 1
Printing
Max Printing Speed
Ink Cartridge Configuration
4 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Ink Type
Brother Innobella ink
Automatic Duplexing
Scanning
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 400 pages
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
100 station(s)
Telephone / Fax Switch
Broadcast Transmission
Distinctive Ring Pattern Detection (DRPD), automatic redialing, group dialling
Document & Media Handling
Max Original Size
A3 (297 x 420 mm)
Original Type
Sheets
35 sheets
Max Media Size
A3
Min Media Weight
64 g/m²
Max Media Weight
285 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 102 x 152 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), 127 x 178 mm, 89 x 127 mm
500 sheets
50 sheets
2 x input tray - 250 sheets - A3 (297 x 420 mm) weight: 64 g/m² - 220 g/m² , Output tray - 50 sheets , ADF - 35 sheets
Speed Details
Printing: up to 35 ppm - B/W , Printing: up to 27 ppm - colour , Copying: up to 20 ppm - colour , Copying: up to 23 ppm - B/W
1 x USB 2.0 , 1 x USB host , 1 x LAN
Security Protocols & Features
LEAP, WPA-PSK, WPA2-PSK
Operating System Support
Linux, Apple MacOS X 10.2.4 or later, MS Windows XP Professional x64 Edition, MS Windows Vista, MS Windows 2000 Professional, MS Windows XP Home Edition, MS Windows XP Professional
Software Included
Reallusion FaceFilter Studio
29 Watt
Power Consumption Standby
6 Watt
Power Consumption Sleep
4.5 Watt
Direct Printing Specifications
PictBridge
Phone cable
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year , Technical support - lifetime
54 cm
48.9 cm
33.1 cm
18.5 kg
Shipping Width
65.6 cm
Shipping Depth
59.7 cm
Shipping Height
44 cm
Shipping Weight
25.3 kg
Sound Emission
50 dBA (operating)
Ink (10)
7CJX Brother LC1240BK - Print cartridge - 1 x black - 600 pages In Stock £18.00
7CJX Brother LC1240C - Print cartridge - 1 x cyan - 600 pages In Stock £11.51
7CJX Brother LC1240M - Print cartridge - 1 x magenta - 600 pages In Stock £11.51
7CJX Brother LC1240Y - Print cartridge - 1 x yellow - 600 pages In Stock £14.00
7CJX Brother LC1280XLBK - Print cartridge - 1 x black - 2400 pages In Stock £25.92
7CJX Brother LC1280XLC - Print cartridge - 1 x cyan - 1200 pages In Stock £15.84
7CJX Brother LC1280XLM - Print cartridge - 1 x magenta - 1200 pages In Stock £15.84
7CJX Brother LC1280XLY - Print cartridge - 1 x yellow - 1200 pages In Stock £15.81
7CJX Brother LC1280 Inkjet Cartridge Value Pack In Stock £71.71
7CJX Brother LC1240 Black/Cyan/Magenta/Yellow Value Pack In Stock £51.49
Other bundles (1)
7CJX Brother A3 GLOSSY PAPER In Stock £16.93
