Brother MFC-J6530DW A4 Inkjet Multifunctional Printer
Quicklinx: CLMWWS00 Mfr#: MFCJ6530DWZU1
£239.55 ex VAT
£287.46 inc VAT
Brother MFC-J6530DW with colour and ink-jet printing.
Brother MFC-J6530DW - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
United Kingdom
Printing Technology
Ink-jet (colour)
Inkjet Technology
4-ink
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
250 - 2000 pages
Max Copying Speed
Up to 12 ppm (mono) / up to 9 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 22 ppm (mono) / up to 20 ppm (colour)
Max Printing Resolution
Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
Scanning
1200 x 2400 dpi
Display
2.7"
Original Size
A3/Ledger (297 x 432 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
Media Type
Envelopes, plain paper, recycled paper, photo paper, coated paper, glossy paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB 2.0 host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive
AC 230 V (50/60Hz)
57.5 cm x 47.7 cm x 30.5 cm
19.6 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
30000 pages
250 - 2000 pages
Display Diagonal Size
2.7"
Display Features
Touch screen
AirPrint Enabled
United Kingdom
Standard Memory
128 MB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Nozzle Configuration
420 nozzles (black), 3 x 420 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
1.5 pl
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Reception Memory Capacity
Up to 200 pages
Transmission Memory Capacity
Up to 200 pages
PC Faxing
Fax Machine Features
One-Touch Dialing
6 station(s)
Speed Dialing
200 station(s)
Broadcast Transmission
250 stations
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Max Media Size
A3/Ledger
Min Media Weight
64 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), 100 x 150 mm, 130 x 180 mm, Folio (216 x 330 mm), 90 x 130 mm, 130 x 200 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
250 sheets
1 sheet
150 sheets
Input tray - 250 sheets - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 220 g/m² , Bypass tray - 1 sheet - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 220 g/m² , ADF - 50 sheets size: 105 x 148 mm - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 90 g/m² , Output tray - 50 sheets , Output tray - 100 sheets
Speed Details
Printing: up to 22 ppm - B/W (ISO/IEC 24734) , Printing: up to 20 ppm - colour (ISO/IEC 24734) , Copying: up to 12 ppm - B/W , Copying: up to 9 ppm - colour , Scanning: up to 18 ipm (A4) - B/W , Scanning: up to 18 ipm (A4) - colour , Printing: up to 12 ppm - B/W duplex (ISO/IEC 24734) , Printing: up to 11 ppm - colour duplex (ISO/IEC 24734) , Printing: up to 35 ppm (A4) - B/W , Printing: up to 27 ppm (A4) - colour , Scanning: up to 8 ipm (A3) - B/W , Scanning: up to 8 ipm (A3) - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
SSL, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, WPS, Wi-Fi Direct
Operating System Support
Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, Android, iOS, Apple Mac OS X 10.9, MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows Phone, Windows 10 (32/64-bits), Apple Mac OS X 10.11, macOS 10.12
AC 230 V (50/60Hz)
27 Watt
Power Consumption Standby
6 Watt
Power Consumption Sleep
1.6 Watt
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
Nordic Swan
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year
57.5 cm
47.7 cm
30.5 cm
19.6 kg
Shipping Width
68.1 cm
Shipping Depth
56.8 cm
Shipping Height
43 cm
Shipping Weight
23.9 kg
Sound Emission
50 dBA (operating)
10 °C
35 °C
20 - 80% (non-condensing)
Ink (9)
CLMW Brother Magenta Super High Yield Ink Cartridge In Stock £22.53
CLMW Brother Yellow Super High Yield Ink Cartridge In Stock £22.53
CLMW Brother Black Super High Yield Ink Cartridge In Stock £32.10
CLMW Brother Cyan Super High Yield Ink Cartridge In Stock £22.53
CLMW Brother Cyan Ink Cartridge In Stock £12.66
CLMW Brother LC3217BK Original Black Ink Cartridge In Stock £17.41
CLMW Brother Yello Ink Cartridge In Stock £12.66
CLMW Brother Magenta Ink Cartridge In Stock £12.66
CLMW Brother LC3219XLVAL Value Pack In Stock £72.32
Other bundles (1)
CLMW Brother A3 GLOSSY PAPER In Stock £16.55
Functionality: Scanner
Functionality: Copier
Functionality: Printer
Functionality: Fax
Max Paper Size: A3 (297 x 420 mm)
Max Paper Size: ANSI B (Ledger) (279 x 432 mm)
Brand: Brother
