Wireless Ready All in One A3 Inkjet Printer
An all-round professional - that's the MFC-J6510DW! Its biggest feature is the affordable A3 printing, copying, scanning and faxing, alongside the handy A3 double-sided printing feature - ideal if you want to save paper or even create your own A4 brochures in-house! It's fast with 12/10 images per minute mono/colour print speed, plus with the XL ink cartridge option lasting up to an incredible 2400 pages, you'll save on running costs. It's also great for sharing, thanks to the enhanced connectivity of wireless N technology.
3.3" widescreen color LCD display
Easily navigate through menus and preview faxes. -
35-page ADF
For unattended fax, copy or scan using up to 35-page ADF. -
Single sheet bypass tray
Allow convenient, straight through, single sheet feeding for up to 11" x 17" paper, envelopes or thicker media.
- Brother MFC-J6510DW - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- 4-ink
- Max Copying Speed
- Up to 23 ppm (mono) / up to 20 ppm (colour)
- Max Copying Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Max Printing Speed
- Up to 12 ppm (mono) / up to 10 ppm (colour)
- Max Printing Resolution
- Up to 6000 x 1200 dpi (mono) / up to 6000 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 2400 dpi
- Original Size
- A3 (297 x 420 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- Media Type
- Transparencies, envelopes, plain paper, cards, photo paper
- Standard Media Capacity
- 250 sheets
- Output Trays Capacity
- 50 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- Office Machine Features
- Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network
- 54 cm x 48.9 cm x 25.7 cm
- 15.8 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Copier Type
- Digital
- Fax Type
- Plain paper
- Ink-jet - colour
- Display Features
- Touch screen
- Interface
- Standard Memory
- 64 MB 64 MB
- Supported Flash Memory
- Memory Stick, SD Memory Card, MultiMediaCard, Memory Stick PRO, USB flash drive, MultiMediaCardplus, SDHC Memory Card
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Copying Features
- 2 on 1, 4 on 1
Printing
- Ink Cartridge Configuration
- 4 individual ink tanks
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Ink Type
- Brother Innobella ink
Scanning
- Optical Resolution
- 1200 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Total Memory Capacity
- Up to 400 pages
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 100 station(s)
- Telephone / Fax Switch
- Broadcast Transmission
- Remote Fax Retrieval (Polling)
- Yes (black only)
- Distinctive Ring Pattern Detection (DRPD), automatic redialing, group dialling
Document & Media Handling
- Max Original Size
- A3 (297 x 420 mm)
- Original Type
- Sheets
- 35 sheets
- Max Media Size
- A3
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 102 x 152 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), 127 x 178 mm, 89 x 127 mm
- 250 sheets
- 50 sheets
- Input tray - 250 sheets , Output tray - 50 sheets , ADF - 35 sheets
- Speed Details
- Printing: up to 35 ppm - B/W draft , Printing: up to 27 ppm - colour draft , Copying: up to 23 ppm - colour , Copying: up to 20 ppm - B/W , Printing: up to 12 ipm - B/W (ISO/IEC 24734) , Printing: up to 10 ipm - colour (ISO/IEC 24734)
- 1 x USB 2.0 , 1 x USB host , 1 x LAN
- WPA-PSK, WPA2-PSK
- Operating System Support
- MS Windows XP, MS Windows 2000, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.4.11, MS Windows Vista, Apple Mac OS X 10.5.x
- Software Included
- Reallusion FaceFilter Studio
- 26 Watt
- Power Consumption Standby
- 7.5 Watt
- Power Consumption Sleep
- 0.3 Watt
- Direct Printing Specifications
- PictBridge
- Included Accessories
- Phone cable
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year
- 54 cm
- 48.9 cm
- 25.7 cm
- 15.8 kg
- Shipping Width
- 65.6 cm
- Shipping Depth
- 59.7 cm
- Shipping Height
- 37.8 cm
- Shipping Weight
- 22.4 kg
- Sound Emission
- 50 dBA (operating)
Brother LC1240BK - Print cartridge - 1 x black - 600 pages | In Stock | £18.60 |
Brother LC1240C - Print cartridge - 1 x cyan - 600 pages | In Stock | £11.90 |
Brother LC1240M - Print cartridge - 1 x magenta - 600 pages | In Stock | £11.46 |
Brother LC1240Y - Print cartridge - 1 x yellow - 600 pages | In Stock | £14.00 |
Brother LC1280XLBK - Print cartridge - 1 x black - 2400 pages | In Stock | £26.79 |
Brother LC1280XLC - Print cartridge - 1 x cyan - 1200 pages | In Stock | £15.77 |
Brother LC1280XLM - Print cartridge - 1 x magenta - 1200 pages | In Stock | £16.38 |
Brother LC1280XLY - Print cartridge - 1 x yellow - 1200 pages | In Stock | £15.77 |
