The MFC-J5620DW is the perfect compact inkjet for business. Packed full of smart features, and with class-leading print speeds, this wired and wireless network-ready all-in-one offers ultra-efficient A4 print, copy, scan and fax with the added bonus of A3 print when important documents need extra standout.
Professional standard, high-quality print and scanning, is only a click or tap away. The 6,000 x 12,000dpi image resolution delivers perfect detail and a flawless finish for documents, charts, posters, plans and drawings as well as stunning full-colour marketing materials.
The machine has been designed specifically to ensure ease-of-use. Connecting devices and accessing apps is effortless, while navigation is made quick and simple with a huge 9.3cm colour LCD touchscreen.
Printing straight from your mobile device couldn't be easier, print and scan to and from the cloud with an extensive range of compatible apps such as our free
, AirPrint and Google Cloud Print, as well as cloud connectivity to platforms including Facebook, Google Drive and Dropbox. Digitising your documents, retrieving scans and copies and printing directly without the need for a PC can be easily achieved at the touch of a button.
Delivering impressive print speeds of 22/20ipm (mono/colour) you won't be left hanging around waiting for jobs to finish. And despite the model's compact size, the large 330 sheet paper capacity means fewer trips to the printer to refill the paper tray between jobs. For added efficiency the 35 sheet automatic document feeder makes scanning multiple documents simple and leaves you free to continue working while your scan jobs take care of themselves.
More than just saving you time, the Business Smart range delivers cost effective performance across all its functions. The lowest running costs in its class can also be supplemented with optional high-yield inks and individual ink cartridges, which means you only need to replace the empty ones. If you're a business concerned with maintaining your green credentials, the MFC-J5620DW's environmentally friendly features such as automatic 2-sided print can reduce unnecessary waste by up to 75%, while smart scanning capability means blank pages are skipped and only the information that you need is captured.
Intuitive touchscreen display
Easily navigate onscreen menus on a touchscreen display with swipe functionality. -
Multi-purpose tray
Multi-purpose tray offers convenient printing of specialty paper, larger formats, and envelopes. -
Outstanding print technology
Landscape print technology stores and feeds paper in a landscape orientation for a space saving design.
- Brother MFC-J5620DW - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- 4-ink
- Max Copying Speed
- Up to 12 ppm (mono) / up to 9 ppm (colour)
- Max Copying Resolution
- Up to 1200 x 2400 dpi (mono) / up to 1200 x 2400 dpi (colour)
- Max Printing Speed
- Up to 22 ppm (mono) / up to 20 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 6000 dpi (mono) / up to 1200 x 6000 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
- Scanning
- 2400 x 2400 dpi
- Display
- 3.7"
- Original Size
- 148 x 148 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 89 x 127 mm (min) - A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper, coated paper, glossy paper
- Standard Media Capacity
- 330 sheets
- Bypass Feeder Capacity
- 80 sheets
- Output Trays Capacity
- 50 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive, scan to network, AOSS
- Power
- AC 230 V (50/60Hz)
- 49 cm x 34.5 cm x 24 cm
- 11.7 kg
- Microsoft Certification
- Compatible with Windows 7
- Fax Type
- Plain paper
- Ink-jet - colour
- Display Diagonal Size
- 3.7"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 128 MB
- Supported Flash Memory
- SD Memory Card, MultiMediaCard, Memory Stick Duo, MultiMediaCardplus, Memory Stick PRO Duo, SDHC Memory Card, SDXC Memory Card
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Nozzle Configuration
- 420 nozzles (black), 3 x 420 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 4 individual ink tanks
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
Scanning
- Optical Resolution
- 2400 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Reception Memory Capacity
- Up to 200 pages
- Transmission Memory Capacity
- Up to 200 pages
- PC Faxing
Fax Machine Features
- Broadcast Transmission
- 250 stations
- Automatic redialing, colour faxing, group dialling
Document & Media Handling
- Min Original Size
- 148 x 148 mm
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 89 x 127 mm
- Max Media Size
- A3/Ledger
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), 100 x 150 mm, 130 x 180 mm, Folio (216 x 330 mm), 127 x 203 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), 89 x 127 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 330 sheets
- 80 sheets
- 50 sheets
- Input tray - 250 sheets size: 89 x 127 mm - A3/Ledger (297 x 432 mm) , Bypass tray - 80 sheets size: 89 x 127 mm - A3/Ledger (297 x 432 mm) , Bypass tray - 1 sheet size: 89 x 127 mm - A3/Ledger (297 x 432 mm) , ADF - 35 sheets size: 148 x 148 mm - Legal (216 x 356 mm) , Output tray - 50 sheets
- Speed Details
- Printing: up to 22 ppm - B/W (ISO/IEC 24734) , Printing: up to 20 ppm - colour (ISO/IEC 24734) , Copying: up to 12 ppm - B/W (ISO/IEC 24735) , Copying: up to 9 ppm - colour (ISO/IEC 24735) , Scanning: 3.37 sec (A4) - B/W , Scanning: 3.37 sec (A4) - colour
- 1 x USB 2.0 - 4 pin USB Type A , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
- WEP, WPA-PSK, WPA2-PSK
- Operating System Support
- MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2003 R2, Apple Mac OS X 10.8.x, MS Windows Server 2012, Windows 8, Windows 8.1, MS Windows Server 2012 R2, Apple Mac OS X 10.7.5, Apple Mac OS X 10.9.x
- Voltage Required
- 32 Watt
- Power Consumption Standby
- 5.5 Watt
- Power Consumption Sleep
- 1.8 Watt
- Direct Printing Specifications
- PictBridge
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- 49 cm
- 34.5 cm
- 24 cm
- 11.7 kg
- Sound Emission
- 50 dBA (operating)
- 10 °C
- 35 °C
- 20 - 80% (non-condensing)
