Brother MFC-J5330DW InkJet Multifunction Printer
Quicklinx: CLMLWS00 Mfr#: MFCJ5330DWZU1
17 in stock
£110.59 ex VAT
£132.70 inc VAT
Stay productive with fast print speeds, wired and wireless connectivity and professional quality printing.
  • New build design delivers a more robust and easy to operate device suited to a busy work environment
  • A new and improved print head increases machine life and ensures exceptional durability
  • Stay prepared with a 250-sheet capacity paper tray and a rear manual feed slot for printing on a wide range of media
  • Enjoy fast and hassle free scanning of multi-paged documents with the 50 sheet Automatic Document Feeder
  • Reduce print costs and paper usage with automatic 2-sided print
  • With new pigment based inks you can enjoy professional quality prints with sharp black text and vivid colour documents
  • Save time and money with optional high yield cartridges that deliver yields up to 3,000 mono and 1,500 colour pages
  • Stay connected with smartphone, tablet, laptop and desktop compatibility
  • With wireless and Wi-Fi Direct you don't need a router to connect
  • Scan to popular cloud apps directly from the large 6.8cm intuitive swipe touchscreen
  • Capture and convert documents with ease with our exclusive Brother Cloud Apps
Brother MFC-J5330DW - multifunction printer - colour
Multifunction printer
Fax Type
G3 - plain paper
Ireland
Printing Technology
Ink-jet (colour)
Inkjet Technology
4-ink
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
250 - 2000 pages
Max Copying Speed
Up to 12 ppm (mono) / up to 9 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 35 ppm (mono) / up to 27 ppm (colour)
Max Printing Resolution
Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
14.4 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
Scanning
1200 x 2400 dpi
Display
2.7"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
Media Type
Envelopes, plain paper, recycled paper, coated paper, glossy paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to SharePoint
AC 230 V (50/60Hz)
53 cm x 39.8 cm x 30.4 cm
16.9 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
30000 pages
250 - 2000 pages
Display Diagonal Size
2.7"
Display Features
Touch screen
AirPrint Enabled
Ireland
Standard Memory
128 MB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Nozzle Configuration
420 nozzles (black), 3 x 420 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
1.5 pl
Automatic Duplexing
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
16-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
G3
Max Transmission Speed
14.4 Kbps
Fax Resolutions
Reception Memory Capacity
Up to 200 pages
Transmission Memory Capacity
Up to 200 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Broadcast Transmission
250 stations
Automatic redialing
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Max Media Size
A3/Ledger
Min Media Weight
64 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), 100 x 150 mm, 130 x 180 mm, Folio (216 x 330 mm), 90 x 130 mm, 130 x 200 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
250 sheets
1 sheet
100 sheets
Input tray - 250 sheets - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 220 g/m² , ADF - 50 sheets size: 105 x 148 mm - Legal (216 x 356 mm) weight: 64 g/m² - 90 g/m² , Output tray - 100 sheets , Bypass tray - 1 sheet - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 220 g/m²
Speed Details
Printing: up to 35 ppm - B/W , Printing: up to 27 ppm - colour , Printing: up to 22 ipm - B/W (ISO/IEC 24734) , Printing: up to 20 ipm - color (ISO/IEC 24734) , Copying: up to 12 ipm - B/W , Copying: up to 9 ipm - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
Kerberos, SSL, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, TTLS, PEAP
Operating System Support
Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, Android, iOS, Apple Mac OS X 10.9, MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8.1 (32/64-bits), Windows Phone, Windows 10 (32/64-bits), Apple Mac OS X 10.11, macOS 10.12
AC 230 V (50/60Hz)
29 Watt
Power Consumption Standby
6.5 Watt
Power Consumption Sleep
1.6 Watt
Consumables Included
1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow)
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year
53 cm
39.8 cm
30.4 cm
16.9 kg
Shipping Width
63.7 cm
Shipping Depth
46.7 cm
Shipping Height
43.7 cm
Shipping Weight
20.5 kg
Sound Emission
50 dBA (operating)
10 °C
35 °C
20 - 80% (non-condensing)
Functionality: Copier
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Max Paper Size: A3 (297 x 420 mm)
Max Paper Size: ANSI B (Ledger) (279 x 432 mm)
Brand: Brother
Price Range Ex VAT: 100 - 150
