Brother MFC-J4410DW Ultra compact A4 Inkjet All-in-One
Quicklinx: 8L72WS00 Mfr#: MFCJ4410DWZU1
Print, scan, copy and fax from the compact and stylish MFC-J4410DW.
Direct printer access to the cloud and mobile device connectivity cuts out the middle man so that both sending your documents and accessing your finished work couldn't be easier. Plus the ability to occasionally print up to A3 when required comes in handy when you need to make a real impact.
With double-sided printing function, optional high-yield cartridges, automatic document feeder and impressive print speeds, the multifunction MFC-J4410DW helps keep your office ticking over by delivering the great results you need, fast.
  • Easy-to-use
    1.8" touch screen display plus touch panel. Touch panel only shows you the keys you need.
  • Low cost printing
    Help save more print more with super high yield ink cartridges.
  • 11" x 17" printing
    Print high-impact easy-to-read documents up to 11" x 17" in a compact design.
  • Mobile device printing
    Wireless printing from your mobile device via: AirPrint, Google Cloud Print, Brother iPrint&Scan, Cortado Workplace and Wi-Fi Direct.
  • Landscape Print technology
    This unique technology delivers the ultimate combination of features in a machine with a compact and sleek design. Allows paper to be stored and fed in the machine in landscape orientation.
  • Wireless capabilities
    Easy to set-up wireless (802.11 b/g/n)and Ethernet network.
Brother MFC-J4410DW - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
4-ink
Max Copying Speed
Up to 12 ppm (mono) / up to 9 ppm (colour)
Max Copying Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Printing Speed
Up to 18 ppm (mono) / up to 16 ppm (colour)
Max Printing Resolution
Up to 6000 x 1200 dpi (mono) / up to 6000 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
Scanning
2400 x 2400 dpi
Display
1.8"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
20 sheets
Media Size
A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
Media Type
Transparencies, envelopes, plain paper, photo paper, coated paper
Standard Media Capacity
150 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
50 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from memory card, save to memory card, save to USB flash drive, scan to e-mail, AOSS
AC 230 V (50/60Hz)
48 cm x 29 cm x 18.6 cm
9.2 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
Display Diagonal Size
1.8"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
128 MB 128 MB
Supported Flash Memory
SD Memory Card, MultiMediaCard, Memory Stick Duo, USB flash drive, MultiMediaCardplus, Memory Stick PRO Duo, SDHC Memory Card, SDXC Memory Card
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Nozzle Configuration
420 nozzles (black), 3 x 420 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
1.5 pl
Ink Type
Brother Innobella ink
Automatic Duplexing
Scanning
Optical Resolution
2400 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Reception Memory Capacity
Up to 200 pages
Transmission Memory Capacity
Up to 200 pages
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
200 station(s)
Broadcast Transmission
200 stations
Fax forwarding, automatic redialing, group dialling, Dual Access, auto reduction, Distinctive Ring Detection (DRD)
Document & Media Handling
Max Original Size
Original Type
Sheets
20 sheets
Max Media Size
A3/Ledger
Min Media Weight
64 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), 100 x 150 mm, 130 x 180 mm, 127 x 203 mm, 89 x 127 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), 100 x 150 mm, 130 x 180 mm, 89 x 127 mm
150 sheets
1 sheet
50 sheets
Input tray - 150 sheets size: 89 x 127 mm - Letter A (216 x 279 mm)/A4 (210 x 297 mm) , ADF - 20 sheets size: 148 x 148 mm - Legal (216 x 356 mm) , Output tray - 50 sheets , Bypass tray - 1 sheet size: 89 x 127 mm - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 220 g/m²
Speed Details
Printing: up to 33 ppm - B/W fast , Printing: up to 25 ppm - colour fast , Printing: up to 18 ipm - B/W (ISO/IEC 24734) , Printing: up to 16 ipm - colour (ISO/IEC 24734) , Copying: up to 12 ipm - B/W (ISO/IEC 24735) , Copying: up to 9 ipm - colour (ISO/IEC 24735)
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK, WPS, Wi-Fi Direct
Operating System Support
MS Windows Server 2003, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.5.8, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.7.x, MS Windows Server 2003 R2, Windows 8
AC 230 V (50/60Hz)
21 Watt
Power Consumption Standby
6 Watt
Power Consumption Sleep
1.5 Watt
Direct Printing Specifications
PictBridge
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year
48 cm
29 cm
18.6 cm
9.2 kg
Shipping Width
56.4 cm
Shipping Depth
26.6 cm
Shipping Height
41.6 cm
Shipping Weight
11.5 kg
Sound Emission
50 dBA (operating)
10 °C
35 °C
20 - 80% (non-condensing)
8L72 Brother LC125XLY Yellow Ink Cartridge In Stock £15.43
