Why bother with multiple machines when you can print, fax, copy and scan all in one with the versatile MFC-9460CDN?
Automatic double-sided printing and high-yield toners help to keep print costs to a minimum, while the low-energy consumption reduces your electric bill. And you can be confident that our high-level security settings will keep your sensitive documents safe.
Reliably delivering professional printouts at high speed (24ppm), the MFC-9460CDN also has added flexibility and paper capacity thanks to the expandable multi-purpose tray. You can even create A5 booklets at the touch of a button.
Fast color output
With a print speed up to 25ppm in both color and black, you no longer have to wait for brilliant color output. -
Easily print two-sided documents
Using the duplex printing feature, you can help reduce your printing costs and produce professional looking two-sided documents, presentations and brochures. -
Versatile paper handling
Use the 250-sheet capacity paper tray for letter or legal paper. Plus, a 50-sheet capacity multi-purpose tray for envelopes or thicker media. -
Automatic multi-page copying, scanning and faxing
Use the 35-page capacity auto document feeder for copying, scanning or faxing up to legal-size documents. -
High quality color scanning
Use the letter size document glass to scan a single page or the 35-page capacity auto document feeder to scan multiple pages at a time (up to legal-size). -
USB Direct interface
Print PDF and JPEG files directly from or scan to your USB flash memory drive without connecting to your PC. -
High-speed faxing
Send and receive faxes quickly in B&W or color using its high-speed 33.6Kbps fax modem.
- Brother MFC-9460CDN - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Max Copying Speed
- Up to 24 ppm (mono) / up to 24 ppm (colour)
- Max Copying Resolution
- Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
- Max Printing Resolution
- Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 2400 dpi
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 220 x 406.4 mm (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper
- Standard Media Capacity
- 300 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Connection Availability
- Interface
- USB 2.0, LAN, USB host
- Office Machine Features
- Scan to e-mail, scan to application
- 41 cm x 50.3 cm x 49.2 cm
- 27.8 kg
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- Copier Type
- Digital
- Fax Type
- Plain paper
- Laser - colour
- Display
- 2 lines x 16 characters
- Interface
- Standard Memory
- 128 MB 128 MB
Copying
- Max Copying Speed
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Copying Features
- 2 on 1, Poster-16, Poster-4, Poster-9, 4 on 1, Poster-25, 9 on 1, 25 on 1, 16 on 1
Printing
- Printer Drivers / Emulations
- PCL 6, BR-Script 3
- First Print Out Time B/W
- 16 sec
- First Print Out Time Colour
- 16 sec
Scanning
- Optical Resolution
- 1200 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
Fax Machine Features
- Error Correction Mode (ECM)
- One-Touch Dialing
- 16 station(s)
- Speed Dialing
- 300 station(s)
- Broadcast Transmission
- 258 stations
- Automatic redialing, colour faxing
Document & Media Handling
- Original Type
- Sheets
- 35 sheets
- Max Media Size
- Other
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), B6 (125 x 176 mm)
- 300 sheets
- 50 sheets
- 150 sheets
- Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , ADF - 35 sheets , Bypass tray - 50 sheets - 220 x 406.4 mm weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
- Speed Details
- Copying: up to 24 ppm - B/W , Copying: up to 24 ppm - colour , Printing: up to 24 ppm - B/W , Printing: up to 24 ppm - colour
- 1 x USB 2.0 , 1 x USB host , 1 x LAN
- Network Protocols
- TCP/IP, AppleTalk, IPP, LPR/LPD, RAW IP (Port 9100)
- Kerberos, Secure Print, SSL, TLS, 802.1x
- Operating System Support
- MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows XP Professional x64 Edition, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.4.11, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows 2000 Professional, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), Apple Mac OS X 10.5.x, MS Windows Server 2008
- 570 Watt
- Power Consumption Standby
- 70 Watt
- Power Consumption Sleep
- 1.7 Watt
- Warm-Up Time
- 31 sec
- First Copy Out Time Colour
- 21 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 2500 pages , 1 x toner cartridge (cyan) - up to 1500 pages , 1 x toner cartridge (magenta) - up to 1500 pages , 1 x toner cartridge (yellow) - up to 1500 pages
- Nordic Swan
- Limited warranty - 1 year
- 41 cm
- 50.3 cm
- 49.2 cm
- 27.8 kg
- Shipping Width
- 58.5 cm
- Shipping Depth
- 67.6 cm
- Shipping Height
- 66 cm
- Shipping Weight
- 33.5 kg
- Sound Emission
- 33 dBA (idle) / 57 dBA (operating)
Brother TN320BK Black Toner Cartridge 2.5K | In Stock | £46.57 |
Brother TN320C 1.5k Cyan Toner | In Stock | £63.69 |
Brother TN320M 1.5k Magenta Toner | In Stock | £63.69 |
Brother TN320Y 1.5k Yellow Toner | In Stock | £63.69 |
Brother TN325C - Toner cartridge - 1 x cyan - 3500 pages | In Stock | £112.49 |
Brother TN325m - Toner cartridge - 1 x magenta - 3500 pages | In Stock | £112.49 |
Brother TN325Y - Toner cartridge - 1 x yellow - 3500 pages | In Stock | £112.49 |
Brother DR-320CL DRUM UNIT C/M/Y/K | In Stock | £130.21 |
