Brother MFC 9120CN - multifunction ( fax / copier / printer / scanner ) - colour - laser
Quicklinx: 6B20WS00 Mfr#: MFC9120CNZU1
Functionality: Printer, Copier, Fax, Scanner
Output Type: Colour
Wireless Capability: Wired
Technology: LED
£199.50 ex VAT
£239.40 inc VAT
The MFC-9120CN is a compact and affordable digital color all-in-one solution which combines printing, copying, scanning and faxing into one powerful space-saving device. Delivering brilliant color output, you can produce impact presentations, flyers, brochures and other critical business documents. Enjoy the convenience of stand-alone copying and copy reduction or enlargement from 25-400%. With faxing, you have the flexibility of stand-alone faxing or sending faxes from your PC.
Brother MFC-9120CN - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
LED (colour)
Monthly Duty Cycle (max)
25000 impressions
Recommended Monthly Volume
1500 pages
Max Copying Speed
Up to 16 ppm (mono) / up to 16 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 600 x 2400 dpi (mono) / up to 600 x 2400 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG, JPEG
Scanning
1200 x 2400 dpi
Original Type
Sheets, books
Document Feeder Capacity
35 sheets
Media Size
76.2 x 116 mm (min) - 220 x 406.4 mm (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
Connection Availability
USB 2.0, LAN
Office Machine Features
Internet faxing, scan to e-mail, scan to folder
42.8 cm x 49.1 cm x 40.1 cm
22.9 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1-year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
LED - colour
25000 impressions
1500 pages
Display
2 lines x 16 characters
USB 2.0, LAN
Standard Memory
64 MB 64 MB
Max Supported Memory
576 MB 576 MB
Copying
Max Copying Speed
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
Toner Save, 2 on 1, Poster-16, Poster-4, Poster-9, 4 on 1, 9 on 1, 25 on 1, 16 on 1
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3
First Print Out Time B/W
15 sec
First Print Out Time Colour
16 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Max Battery Backup Time
60 hour(s)
Total Memory Capacity
Up to 500 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
One-Touch Dialing
8 station(s)
Speed Dialing
200 station(s)
Telephone / Fax Switch
Broadcast Transmission
258 stations
Delayed Transmission
50 stations
Remote Fax Retrieval (Polling)
Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing, answering machine interface
Document & Media Handling
Original Type
Sheets, books
35 sheets
Min Media Size
76.2 x 116 mm
Max Media Size
Other
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
250 sheets
1 sheet
100 sheets
ADF - 35 sheets , Bypass tray - 1 sheet size: 76.2 x 116 mm - 220 x 406.4 mm weight: 60 g/m² - 163 g/m² , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Output tray - 100 sheets
Speed Details
Copying: up to 16 ppm (A4) - B/W , Copying: up to 16 ppm (A4) - colour , Printing: up to 16 ppm (A4) - B/W , Printing: up to 16 ppm (A4) - colour
1 x USB 2.0 , 1 x LAN
Network Protocols
TCP/IP, NetBEUI, IPP, LPR/LPD, RAW IP (Port 9100)
Security Protocols & Features
Secure Print, SSL, TLS
Operating System Support
Linux, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows XP Professional x64 Edition, MS Windows Vista, MS Windows 2000 Professional, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, Apple MacOS X 10.3.9 or later, MS Windows Server 2008
Software Included
Drivers & Utilities, Brother BR-Admin Professional, ScanSoft PaperPort SE 11.0, Brother MFL-Pro Suite, Presto! PageManager 7, Brother BR-Admin Light for Linux & Macintosh
480 Watt
Power Consumption Standby
75 Watt
Power Consumption Sleep
11 Watt
Warm-Up Time
35 sec
First Copy Out Time B/W
19 sec
First Copy Out Time Colour
24 sec
Phone cable
Consumables Included
1 x toner cartridge (black) - up to 1000 pages , 1 x toner cartridge (cyan) - up to 1000 pages , 1 x toner cartridge (magenta) - up to 1000 pages , 1 x toner cartridge (yellow) - up to 1000 pages , 1 x drum - up to 15000 pages
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year - on-site
42.8 cm
49.1 cm
40.1 cm
22.9 kg
Shipping Width
73 cm
Shipping Depth
59 cm
Shipping Height
56.5 cm
Shipping Weight
29 kg
Sound Emission
30 dB (idle) / 53 dB (operating)
6B20 Brother HL3000 Black 2.2k Toner In Stock £54.68
6B20 Brother TN230C - Toner cartridge - 1 x cyan - 1400 pages In Stock £52.83
6B20 Brother TN230M - Toner cartridge - 1 x magenta - 1400 pages In Stock £52.83
6B20 Brother TN230Y - Toner cartridge - 1 x yellow - 1400 pages In Stock £52.83
6B20 Brother DR230CL DRUM In Stock £82.48
Functionality: Copier
Functionality: Fax
Functionality: Scanner
Output Type: Colour
Technology: LED
Max Print Speed: 16ppm
Max Paper Size: 220 x 406.4 mm
Brand: Brother
