Brother MFC 7360N Mono Laser Multifunction Printer
Quicklinx: 7GD2WS00 Mfr#: MFC7360NU1
The MFC-7360N offers a huge amount in a surprisingly small package - making it ideal if space is at a premium. Speedy mono printing and copying are made even easier by the auto document feeder with a large paper capacity meaning less time is spent refilling. There's fast faxing too, and high resolution color network scanning. Add the fact that everyone on your network can share the printer and what more could you ask for?
Brother MFC-7360N - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
Fax Type
G3 - plain paper
Printing Technology
Laser (monochrome)
Max Copying Speed
Up to 24 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 24 ppm
Max Printing Resolution
Up to 2400 x 600 dpi
Max Fax Transmission Speed
14.4 Kbps
Data Compression System
MH, MR, MMR
Scanning
600 x 2400 dpi
Original Size
216 x 356 mm (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
216 x 406.4 mm (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
Connection Availability
USB 2.0, LAN
Office Machine Features
Scan to e-mail
AC 230 V (50/60Hz)
40.5 cm x 39.9 cm x 31.6 cm
11.6 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
Display
2 lines x 16 characters
USB 2.0, LAN
Scan to e-mail
Standard Memory
32 MB 32 MB
Copying
Max Copying Speed
Up to 24 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
Sort
Printing
Max Printing Speed
Up to 24 ppm
Printer Drivers / Emulations
PCL 6
Image Enhancement Technology
Brother HQ1200
First Print Out Time B/W
8.5 sec
Scanning
Optical Resolution
600 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
G3
Max Transmission Speed
14.4 Kbps
MH, MR, MMR
Reception Memory Capacity
Up to 400 pages
Transmission Memory Capacity
Up to 400 pages
Fax Machine Features
One-Touch Dialing
8 station(s)
Speed Dialing
200 station(s)
Broadcast Transmission
258 stations
Automatic redialing, group dialling
Document & Media Handling
Max Original Size
216 x 356 mm
Original Type
Sheets
35 sheets
Max Media Size
Other
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), JIS B5 (182 x 257 mm), B6 (125 x 176 mm)
250 sheets
1 sheet
100 sheets
Input tray - 250 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , ADF - 35 sheets - 216 x 356 mm weight: 64 g/m² - 90 g/m² , Output tray - 100 sheets , Bypass tray - 1 sheet size: 76.2 x 116 mm - 216 x 406.4 mm weight: 60 g/m² - 163 g/m²
Speed Details
Copying: up to 24 ppm - B/W , Printing: up to 24 ppm - B/W
1 x USB 2.0 , 1 x LAN
Network Protocols
TCP/IP, LPR/LPD, RAW IP (Port 9100)
Operating System Support
Linux, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows 2000 Professional, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), Apple Mac OS X 10.4.11 or later, MS Windows Server 2008, MS Windows Server 2008 R2
AC 230 V (50/60Hz)
495 Watt
Power Consumption Standby
65 Watt
Power Consumption Sleep
0.9 Watt
Warm-Up Time
7 sec
First Copy Out Time B/W
11 sec
Consumables Included
1 x toner cartridge (black) - up to 700 pages - Brother TN2210 , 1 x drum - Brother DR2200
ENERGY STAR Certified
Limited warranty - 1 year , Technical support - phone consulting - lifetime
40.5 cm
39.9 cm
31.6 cm
11.6 kg
Shipping Width
52.7 cm
Shipping Depth
51 cm
Shipping Height
49.3 cm
Shipping Weight
14.8 kg
Sound Emission
30 dBA (idle) / 53 dBA (operating)
7GD2 Brother TN2220 - Toner cartridge - 1 - 2600 pages In Stock £52.71
7GD2 Brother BRO DR2200 DRUM HL2240/2240D/ In Stock £59.83
7GD2 Brother TN2210 - Toner cartridge - 1 - 1200 pages In Stock £34.11
