The Brother MFC-1910W is stylishly designed and compact enough to fit onto a shelf or workstation. It produces outputs with the speed and quality you would expect from a more expensive machine.
Installation is very easy – connect using wireless or the USB cable, and you will be printing in no time. Plus innovative Anti-Jam technology allows you to print wirelessly with no hassle. You will also be able to print at speeds of up to 20 pages per minute (ppm), and your first page will come out in less than 10 seconds.
- Brother MFC-1910W - multifunction printer - B/W
- Multifunction printer
- Fax Type
- G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Max Copying Speed
- Up to 20 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 20 ppm
- Max Printing Resolution
- Up to 2400 x 600 dpi
- Max Fax Transmission Speed
- 14.4 Kbps
- Scanning
- 600 x 1200 dpi
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 10 sheets
- Media Size
- 148 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper, recycled paper
- Standard Media Capacity
- 150 sheets
- Output Trays Capacity
- 50 sheets
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- Office Machine Features
- AOSS
- Power
- AC 230 V (50/60Hz)
- 38.5 cm x 34 cm x 28.3 cm
- 8.2 kg
- Microsoft Certification
- Compatible with Windows 7
- Fax Type
- Plain paper
- Laser - monochrome
- Display
- 2 lines x 16 characters
- Interface
- USB 2.0, Wi-Fi(n)
- AOSS
- Standard Memory
- 32 MB
Copying
- Max Copying Speed
- Up to 20 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Up to 20 ppm
- Printer Drivers / Emulations
- Windows GDI driver
- Image Enhancement Technology
- Brother HQ1200
- First Print Out Time B/W
- 10 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 600 x 1200 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Compatibility
- G3
- Max Transmission Speed
- 14.4 Kbps
- Reception Memory Capacity
- Up to 400 pages
- Transmission Memory Capacity
- Up to 400 pages
Fax Machine Features
- Speed Dialing
- 99 station(s)
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 10 sheets
- Min Media Size
- 148 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 65 g/m²
- Max Media Weight
- 105 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Folio (216 x 330 mm), 148 x 148 mm
- 150 sheets
- 50 sheets
- Input tray - 150 sheets size: 148 x 148 mm - Legal (216 x 356 mm) weight: 65 g/m² - 105 g/m² , ADF - 10 sheets - Legal (216 x 356 mm) weight: 65 g/m² - 90 g/m² , Output tray - 50 sheets
- Speed Details
- Printing: up to 20 ppm (A4) - B/W , Printing: up to 21 ppm (Letter A) - B/W , Copying: up to 20 ppm
- 1 x USB 2.0 - 4 pin USB Type A
- WEP, WPA-PSK, WPA2-PSK, TKIP, AES, ARP
- Operating System Support
- MS Windows XP, Linux, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition, Android, iOS, Windows 8.1, Apple Mac OS X 10.9, Windows 8.1 64-bit, MS Windows Server 2012 R2 x64 Edition, Apple Mac OS X 10.10
- Voltage Required
- 390 Watt
- Power Consumption Standby
- 2.4 Watt
- Power Consumption Sleep
- 1.4 Watt
- First Copy Out Time B/W
- 16 sec
- Consumables Included
- 1 x Cartridge (black) - up to 700 pages
- IEC 60825-1:2007
- 38.5 cm
- 34 cm
- 28.3 cm
- 8.2 kg
- Shipping Width
- 48.1 cm
- Shipping Depth
- 43.6 cm
- Shipping Height
- 42.5 cm
- Shipping Weight
- 10.1 kg
- Sound Emission
- 32 dBA (idle) / 52 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
