Flexible connectivity to print from virtually anywhere
The built-in wireless interface offers easy connectivity so you may print from virtually anywhere without being tethered to a computer. Can also share on a network. -
Print Black/Red labels with DK-2251 labels
Brother QL-800 series is the only office category label printer to offer the technology that lets your print two colors over the entire label! -
Print labels wirelessly
Use the free Brother iPrint & Label App to print labels wirelessly from your Apple iPhone, iPad, and iPod touch or Android smartphone.
- Brother QL-810W - label printer - two-colour (monochrome) - direct thermal
- Printer Type
- Label printer - direct thermal - two-colour (monochrome)
- 1.12 kg
- Localisation
- Ireland
- Max Media Size
- Roll (6.2 cm)
- Max Media Size (Custom)
- 62 mm
- Print Speed
- Up to 110 labels/min , Up to 176 mm/sec
- Max Resolution (B&W)
- 300 x 600 dpi
- Cutter
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Barcodes
- Code 93, Code 39, GS1 DataBar, QR code, MaxiCode, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Postnet, PDF417, Data Matrix, ITF, Micro QR code, EAN-8, EAN-13, GS1-128
- Media Type
- Die cut labels, label continuous paper
- Compatible Tapes
- DK tape
- Fonts
- Brussels, Helsinki, San Diego, Letter Gothic Bold, Brougham
- Styles & Effects
- Bold, normal, vertical, shadow, italic, shadow light, surround, horizontal lines, invert
- Printer Features
- Auto Power Off
- Battery
- Required 1 Lithium Ion Included Qty 0
- System Requirements
- Linux, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Microsoft Windows Server 2012 R2, Apple MacOS X 10.10.x, Windows 10 (32/64 bits), Apple MacOS X 10.11.x, Apple macOS 10.12.x
- 1-year warranty
- 12.53 cm x 23.4 cm x 14.5 cm
- Printer Type
- Localisation
- Ireland
Printer
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- 300 x 600 dpi
- Fonts
- Styles & Effects
- Auto Cutter
- Barcodes
- Printer Features
- Auto Power Off
Media Handling
- Media Type
- Compatible Tapes
- DK tape
- Max Media Size
- Roll (6.2 cm)
- 62 mm
- Media Sizes
- Roll (2.9 cm), Roll (5.4 cm), Roll (1.2 cm), Roll (3.8 cm), Roll (6.2 cm), Roll (5 cm)
- Max Printing Width
- 58 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (6.2 cm)
- Connections
- 1 x USB 2.0
- Cables Included
- 1 x USB cable
- Media Included
- 62 mm x 5 m black/red paper tape, 29 x 90 mm black on white standart address labels (100 labels)
- Power Device
- Power adapter - external
- Frequency Required
- 50/60 Hz
- Lithium Ion
- Required Qty
- 1
- Included
- 0
- Software Included
- Software Development Kit (SDK)
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year
- 10 °C
- 35 °C
- 20 - 80%
- 12.53 cm
- 23.4 cm
- 14.5 cm
- 1.12 kg
Ink (8)
Brother CD/DVD 100 x 58mm Labels | In Stock | £13.09 |
Brother Large Address Labels | In Stock | £7.61 |
Brother DK Continuous White Labels | In Stock | £12.64 |
Brother Shipping 62 x 100mm 300 Labels | In Stock | £10.96 |
Brother P-TOUCH Yellow Paper- 62mm | In Stock | £13.32 |
Brother p-touch White Paper - 62mm | In Stock | £12.16 |
Brother Paper Roll (6.2 cm x 30.5 m) | In Stock | £10.29 |
Brother Non Adhesive Paper Tape 54mm | In Stock | £11.53 |
Other bundles (2)
Brother BROTHER DK-22212 TAPE 62MM WH. | In Stock | £32.57 |
Brother P-TOUCH TAPE PAPER 29MMX30.48M | In Stock | £6.33 |
