Open up new business opportunities with this robust machine. Offering excellent paper handling options, super fast print speeds and the new optional ultra-high-yield toner cartridges significantly reduces your print spend, making this machine the ideal print partner for your business.
Key Features
- Super-fast print speeds of up to 50ppm.
- Outstanding paper handling options with a standard paper capacity of 570 sheets expandable to 2,650 sheets.
- 12,000 page inbox toner & optional ultra high yield 20,000 page toner cartridge.
- Intuitive 4.5cm touchscreen LCD display.
- Integrated NFC Reader, giving users better document security and improved user authentication for pull printing.
Maximise Performance & Reduce Print Spend
Versatile paper handling, enables you to add multiple lower trays, and mailbox options across the range. This provides maximum device uptime, as less time is spent replenishing paper trays and searching for your printed documents. With the optional ultra high yield toner cartridges, productivity is enhanced, whilst reducing your overall printing costs.
Better reliability
Built to perform for longer and meet the demands of high output work environments, the L6000 range has been totally remodelled with robust build quality that’s even more resilient and hardwearing.
Enhanced Workflow
The L6000 range introduces an intuitive and user-friendly interface, and support for multiple business cloud based services including Dropbox and Google Drive.
Tighter security
In today's business environment, we understand that organisations demand the highest levels of security. In order to address this, the L6000 range is enabled with secure function lock 3.0, 802.1x and Internet Protocol Security (IPsec). The range also boasts Print Archive, Secure Reset, Certificate Management and Near field communication (NFC) functionality for secure user access and authentication.
Flexible print solutions from Brother
Our L6000 range is designed to seamlessly integrate and meet your business requirements. Compatible with a range of print software and services, Brother Solutions enables you to maximise your print efficiency and minimise costs, specifically tailored to your requirements.
Eco-friendly
The L6000 range is compliant with a number of environmental standards including German Blue Angel, Nordic Swan and Energy Star. As a result, not only does it help your business work more efficiently, it is also more energy efficient, reducing impact on the environment and lowering your costs at the same time.
Maximize performance
Significantly increase your workgroup productivity thanks to super-fast print speeds. Maximize performance with high speed wired and wireless network interfaces. Streamline workflows and easily print with NFC technology. The incredible easy-to-use touchscreen user interface allows users to complete tasks with no hassle. -
Exceptionallly low running costs
It is not just equipped with features provided to turn heads. Designed for demanding high-volume print environments, the HL-L6400DW features a high-yield toner cartridge to lower your running costs even further.
- Brother HL-L6400DW - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 13.4 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 52 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 50 ppm - B/W - A4 (210 x 297 mm) , Up to 24 ppm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 24 ppm - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
- Preview Screen Size
- 1.8"
- Processor
- Cortex-A9 800 MHz
- RAM Installed (Max)
- 512 MB
- Language Simulation
- PostScript 3, PCL 6, XPS, IBM ProPrinter XL, EPSON FX-850, PDF 1.7
- Media Type
- Envelopes, labels, plain paper, bond paper, recycled paper, thick paper, thin paper
- Total Media Capacity
- 570 sheets
- Media Handling
- 50-sheet multipurpose tray, 520-sheet input tray
- Recommended Monthly Volume
- 10000 pages
- Networking
- Print server
- Power
- AC 230V
- System Requirements
- Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Microsoft Windows XP (32-bit) SP3, Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Microsoft Windows Server 2012 R2 x64 Edition, Apple MacOS X 10.10, Windows 10 (32/64 bits), Apple MacOS X 10.11
- 2-year warranty
- 40 cm x 28.8 cm x 39.6 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Touch screen
- 1.8"
- Connectivity Technology
- Wireless
- Interface
- 1200 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 7.5 sec
- Media Handling
- Processor
- Cortex-A9 800 MHz
RAM
- 512 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
- Media Weight
- 60 g/m² - 200 g/m²
- 570 sheets
- Media Feeders
- 1 x automatic - 520 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , 1 x automatic - 50 sheets - 215.9 x 355.6 mm weight: 60 g/m² - 200 g/m²
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 10000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, TFTP, IPPS
- Kerberos, SSL, TLS, IPsec, 802.1x, ARP, PEAP
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - up to 12000 pages
- Power Device
- Power supply - internal
- Voltage Required
- AC 230V
- Frequency Required
- 50/60 Hz
- 770 Watt
- Power Consumption Stand by
- 32 Watt
- Power Consumption Sleep
- 7.3 Watt
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- Limited warranty - 2 years
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
- Sound Emission (Idle)
- 35 dBA
- Sound Emission (Operating)
- 54 dBA
- Sound Emission (Quiet Mode)
- 50 dBA
- 40 cm
- 28.8 cm
- 39.6 cm
- 13.4 kg
- Width (Shipping)
- 49.7 cm
- Depth (Shipping)
- 49.2 cm
- Height (Shipping)
- 53.1 cm
- Weight (Shipping)
- 16 kg
Ink (3)
Brother TN-3430 Black Standard Yield Toner | In Stock | £65.84 |
Brother TN-3480 Tonert 8000 Pages | In Stock | £94.17 |
Brother TN-3512 Black Super High Yield Toner | In Stock | £107.03 |
Other bundles (2)
Brother LT5505 250 Sheet Optional Paper Tray | In Stock | £115.26 |
Brother LT6505 520 Sheet Optional Paper Tray | In Stock | £120.67 |
