Brother HLL5200DW Mono Laser Printer
Quicklinx: C2S6WS00 Mfr#: HLL5200DWZU1
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wireless, Wired
Technology: Laser
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
£230.91 ex VAT
£277.09 inc VAT
The Brother HL-L5200DW monochrome laser printer is perfect for offices and small workgroups looking for quality and reliability. It delivers cost-efficient, two-sided output thanks to a high-yield replacement toner cartridge. Plus, it quickly prints high-quality business documents up to 42ppm. Use the 250-sheet capacity paper tray for letter or legal-size documents, and print on envelopes and alternative media types from the 50-sheet capacity multi-purpose tray. For fewer refills, you can expand the paper capacity to 1,340 sheets with optional add-on trays. Easily share the printer on your wireless or Ethernet network and print with ease from a wide range of mobile devices‡. Advanced security features help protect your documents and device from unauthorized access.
Fast, high-quality printing
With a print speed of up to 42 pages per minute, this printer is ideal for busy offices. Plus, it offers up to 1200 x 1200 dpi resolution for crisp, clear text and excellent graphics.
Cost-efficient output
Help lower your operating costs via a high-yield 8,000-page‡ replacement toner cartridge.
Flexible paper handling
Easily handle your large print jobs via an adjustable 250-sheet capacity paper tray and 50-sheet capacity multi-purpose tray. For additional capacity, add up to two 520-sheet capacity or two 250-sheet capacity paper trays for a total input capacity 1,340 sheets.
Automatic two-sided printing
Use the duplex feature to produce professional brochures, documents and booklets. This feature can help save money and cut your paper usage by up to 50%.
Restrict unauthorized printing and help protect sensitive documents with a wide-range of security features including: Secure Print, Secure Function Lock, Enterprise Security (802.1x), IPSec, SSL/TLS and more.
  • Fast, high-quality printing
    With a print speed of up to 40 pages per minute (based on one-sided printing, change from default setting required), this printer is ideal for busy offices. Plus, it offers up to 1200x1200 dpi resolution for crisp, clear text and excellent graphics.
  • Flexible connectivity
    Built-in wireless 802.11b/g/n and Ethernet network interfaces allow you to share the HL-L5200DW with multiple users on your network.
  • Automatic two-sided printing
    Use the duplex feature to produce professional brochures, documents and booklets. This feature can help save money and cut your paper usage.
  • Advanced security features
Brother HL-L5200DW - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
10.7 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 42 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 40 ppm - B/W - A4 (210 x 297 mm) , Up to 20 ppm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 20 ppm - B/W duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, LAN, Wi-Fi(n)
Cortex-A9 800 MHz
RAM Installed (Max)
256 MB
Language Simulation
PCL 6, XPS, BR-Script3, IBM ProPrinter XL, EPSON FX-850, PDF 1.7
Media Type
Envelopes, labels, plain paper, bond paper, recycled paper, thick paper, thin paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Print server
Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Microsoft Windows XP (32-bit) SP3, Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Microsoft Windows Server 2012 R2 x64 Edition, Apple MacOS X 10.10, Windows 10 (32/64 bits), Apple MacOS X 10.11
37.3 cm x 38.8 cm x 25.5 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Status LCD
Wireless
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
7.2 sec
Language Simulation
Media Handling
Cortex-A9 800 MHz
RAM
RAM Installed (Max)
256 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
Media Weight
60 g/m² - 200 g/m²
300 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , 1 x automatic - 50 sheets - 215.9 x 355.6 mm weight: 60 g/m² - 200 g/m²
Output Trays Capacity
150 sheets
Print server
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, TFTP, IPPS
Security Protocols & Features
Kerberos, SSL, TLS, IPsec, 802.1x, ARP, PEAP
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Nordic Swan
Power supply - internal
Frequency Required
50/60 Hz
640 Watt
Power Consumption Stand by
32 Watt
Power Consumption Sleep
6.5 Watt
Environmental Standards
Blue Angel
ENERGY STAR
10 °C
32 °C
20 - 80% (non-condensing)
Sound Emission (Idle)
34 dBA
Sound Emission (Operating)
52 dBA
Sound Emission (Quiet Mode)
50 dBA
37.3 cm
38.8 cm
25.5 cm
10.7 kg
Width (Shipping)
48.5 cm
Depth (Shipping)
45 cm
Height (Shipping)
37.7 cm
Weight (Shipping)
13 kg
C2S6 Brother TN-3430 Black Standard Yield Toner In Stock £60.28
C2S6 Brother TN-3480 Tonert 8000 Pages In Stock £102.53
C2S6 Brother HLL6400/MFCL6900DW/T Drum Unit 30K In Stock £121.33
Type: Printer
Wireless Capability: Wired
Technology: Laser
Max Paper Size: A4 (210 x 297 mm)
Brand: Brother
