Brother HLL5000D Mono Laser Printer
Quicklinx: C2S3WS00 Mfr#: HLL5000DZU1
Type: Printer
Functionality: Printer
Wireless Capability: Wired
Technology: Laser
Max Paper Size: Legal (216 x 356 mm), A4 (210 x 297 mm)
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
£158.10 ex VAT
£189.72 inc VAT
The Brother HL-L5000D monochrome laser printer is ideal for small offices that need a printer with a Parallel interface for wide application compatibility. It features reliable, fast printing up to 42 ppm and cost-efficient output thanks to a high-yield replacement toner cartridge. Plus, automatic two-sided printing helps save paper. Built-in parallel and USB interfaces provide flexible local connectivity and PCL6 and BR-Script3 emulations enable comprehensive application compatibility. Use the 250-sheet capacity paper tray for letter or legal-size documents, and print on envelopes and alternative media types from the 50-sheet capacity multi-purpose tray. For fewer refills, you can expand the paper capacity to 1,340 sheets with optional add-on trays.
  • Fast, high-quality printing
    With a print speed of up to 42 pages per minute, this printer is ideal for busy offices. Plus, it offers up to 1200 x 1200 dpi resolution for crisp, clear text and excellent graphics.
  • Flexible paper handling
    Easily handle your print jobs via an adjustable 250-sheet capacity paper tray and 50-sheet capacity multi-purpose tray.
  • Cost efficient output
    Help reduce running costs due to an 8,000-page high-yield replacement toner cartridge.
  • Automatic two-sided printing
    Use the duplex feature to produce professional brochures, documents and booklets. This feature can help save money and cut your paper usage by up to 50%.
Brother HL-L5000D - printer - B/W - laser
Printer Type
Personal printer - laser - B/W
10.7 kg
Media Size Class
A4/Legal
Max Media Size
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 42 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 40 ppm - B/W - A4 (210 x 297 mm) , Up to 20 ppm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 20 ppm - B/W duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
Parallel, USB 2.0
Cortex-A9 800 MHz
RAM Installed (Max)
128 MB
Language Simulation
PCL 6, XPS, BR-Script3, IBM ProPrinter XL, EPSON FX-850, PDF 1.7
Media Type
Envelopes, labels, plain paper, bond paper, recycled paper, thick paper, thin paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Microsoft Windows XP (32-bit) SP3, Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Microsoft Windows Server 2012 R2 x64 Edition, Apple MacOS X 10.10, Windows 10 (32/64 bits), Apple MacOS X 10.11
37.3 cm x 38.8 cm x 25.5 cm
Printer Type
Personal printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Status LCD
Wired
Parallel, USB 2.0
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
7.2 sec
Language Simulation
Media Handling
Cortex-A9 800 MHz
RAM
RAM Installed (Max)
128 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
Media Weight
60 g/m² - 200 g/m²
300 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , 1 x automatic - 50 sheets - 215.9 x 355.6 mm weight: 60 g/m² - 200 g/m²
Output Trays Capacity
150 sheets
1 x USB 2.0 - 4 pin USB Type B , 1 x parallel
Nordic Swan
Power supply - internal
Frequency Required
50/60 Hz
640 Watt
Power Consumption Stand by
32 Watt
Power Consumption Sleep
6.5 Watt
Environmental Standards
Blue Angel
ENERGY STAR
10 °C
32 °C
20 - 80% (non-condensing)
Sound Emission (Idle)
34 dBA
Sound Emission (Operating)
52 dBA
Sound Emission (Quiet Mode)
50 dBA
37.3 cm
38.8 cm
25.5 cm
10.7 kg
Width (Shipping)
48.5 cm
Depth (Shipping)
45 cm
Height (Shipping)
37.7 cm
Weight (Shipping)
13 kg
C2S3 Brother TN-3430 Black Standard Yield Toner In Stock £59.83
C2S3 Brother TN-3480 Tonert 8000 Pages In Stock £102.77
C2S3 Brother HLL6400/MFCL6900DW/T Drum Unit 30K In Stock £120.18
Type: Printer
Technology: Laser
Max Paper Size: A4 (210 x 297 mm)
Brand: Brother
