The Brother HL-L5000D monochrome laser printer is ideal for small offices that need a printer with a Parallel interface for wide application compatibility. It features reliable, fast printing up to 42 ppm and cost-efficient output thanks to a high-yield replacement toner cartridge. Plus, automatic two-sided printing helps save paper. Built-in parallel and USB interfaces provide flexible local connectivity and PCL6 and BR-Script3 emulations enable comprehensive application compatibility. Use the 250-sheet capacity paper tray for letter or legal-size documents, and print on envelopes and alternative media types from the 50-sheet capacity multi-purpose tray. For fewer refills, you can expand the paper capacity to 1,340 sheets with optional add-on trays.
Fast, high-quality printing
With a print speed of up to 42 pages per minute, this printer is ideal for busy offices. Plus, it offers up to 1200 x 1200 dpi resolution for crisp, clear text and excellent graphics. -
Flexible paper handling
Easily handle your print jobs via an adjustable 250-sheet capacity paper tray and 50-sheet capacity multi-purpose tray. -
Cost efficient output
Help reduce running costs due to an 8,000-page high-yield replacement toner cartridge. -
Automatic two-sided printing
Use the duplex feature to produce professional brochures, documents and booklets. This feature can help save money and cut your paper usage by up to 50%.
- Brother HL-L5000D - printer - B/W - laser
- Printer Type
- Personal printer - laser - B/W
- 10.7 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 42 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 40 ppm - B/W - A4 (210 x 297 mm) , Up to 20 ppm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 20 ppm - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- Parallel, USB 2.0
- Processor
- Cortex-A9 800 MHz
- RAM Installed (Max)
- 128 MB
- Language Simulation
- PCL 6, XPS, BR-Script3, IBM ProPrinter XL, EPSON FX-850, PDF 1.7
- Media Type
- Envelopes, labels, plain paper, bond paper, recycled paper, thick paper, thin paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 250-sheet input tray, 50-sheet multipurpose tray
- System Requirements
- Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Microsoft Windows XP (32-bit) SP3, Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Microsoft Windows Server 2012 R2 x64 Edition, Apple MacOS X 10.10, Windows 10 (32/64 bits), Apple MacOS X 10.11
- 37.3 cm x 38.8 cm x 25.5 cm
- Printer Type
- Personal printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- Parallel, USB 2.0
- 1200 x 1200 dpi
- First Print Out Time B/W
- 7.2 sec
- Media Handling
- Processor
- Cortex-A9 800 MHz
RAM
- 128 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
- Media Weight
- 60 g/m² - 200 g/m²
- 300 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , 1 x automatic - 50 sheets - 215.9 x 355.6 mm weight: 60 g/m² - 200 g/m²
- Output Trays Capacity
- 150 sheets
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x parallel
- Nordic Swan
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 640 watt
- Power Consumption Stand by
- 32 watt
- Power Consumption Sleep
- 6.5 watt
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
- Sound Emission (Idle)
- 34 dBA
- Sound Emission (Operating)
- 52 dBA
- Sound Emission (Quiet Mode)
- 50 dBA
- 37.3 cm
- 38.8 cm
- 25.5 cm
- 10.7 kg
- Width (Shipping)
- 48.5 cm
- Depth (Shipping)
- 45 cm
- Height (Shipping)
- 37.7 cm
- Weight (Shipping)
- 13 kg
Brother TN-3430 Black Standard Yield Toner | In Stock | £62.81 |
Brother TN-3480 Tonert 8000 Pages | In Stock | £107.29 |
Brother HLL6400/MFCL6900DW/T Drum Unit 30K | In Stock | £125.81 |
