Built with performance in mind, the efficient and speedy HL-3170CDW makes it simple to create standout, professional-looking documents.
This flexible colour printer is ideal for small but busy spaces. Optional high-yield colour toner cartridges, double-sided functionality and low energy consumption can help to reduce your total print costs, while the fast print speeds (22ppm) and easy-to-operate backlit LCD screen control guarantee quick and impressive results.
To make it easy to stay connected wherever you are in the office, the compact HL-3170CDW features both wired and wireless technology. Plus you can also send documents to print direct from your mobile device.
Blazing fast printing
Fast color and black print speeds up to 23 ppm to help improve your productivity. -
Automatic two-sided printing
Automatic duplex for two-sided printing to help save paper. -
Flexible connectivity
Easy to install on your wired or wireless network or print locally via USB: from your computer. -
High-impact business printing
Produce crisp black and high-impact color business documents at up to 600 x 2400 dpi resolution using Brother's digital LED print technology. -
Versatile paper handling
250-sheet capacity paper tray adjustable for letter or legal and a straight-through paper path via manual feed slot for envelope printing. -
Mobile device printing
Wireless printing from your mobile device via: AirPrint, Google Cloud Print, Brother iPrint&Scan, Cortado Workplace and Wi-Fi Direct. -
Help control your color printing costs
Use the secure function lock feature to set color page counts or restrict color printing for up to 25 users. -
Help lower your operating costs
High capacity color toners available to help lower your cost per copy. -
Deep sleep mode
Deep sleep mode to conserve energy when printer is not being used.
- Brother HL-3170CDW - printer - colour - LED
- Printer Type
- Workgroup printer - LED - colour
- 18.1 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 116 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 22 ppm - B/W , Up to 22 ppm - colour , Up to 7 ipm - B/W duplex , Up to 7 ipm - colour duplex
- Max Resolution (B&W)
- 2400 x 600 dpi
- Max Resolution (Colour)
- 2400 x 600 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Processor
- 333 MHz
- RAM Installed (Max)
- 128 MB
- Language Simulation
- PCL 6, BR-Script3
- Media Type
- Plain paper, bond paper, recycled paper, glossy paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet input tray, 1-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 300 - 1500 pages
- Networking
- Print server
- System Requirements
- Linux, Microsoft Windows XP Home Edition, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Apple MacOS X 10.6.8, Microsoft Windows Server 2012, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Microsoft Windows XP Professional (32/64 bits)
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 41 cm x 46.5 cm x 24 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 2400 x 600 dpi
- 2400 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 16 sec
- First Print Out Time Colour
- 16 sec
- PCL 6, BR-Script3
- Media Handling
- Processor
- 333 MHz
RAM
- 128 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 116 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 250 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , 1 x manual - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
- Output Trays Capacity
- 100 sheets
Duty Cycle
- 30000 pages
- 300 - 1500 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP, SNMP 3, IPP, HTTP, HTTPS, TFTP, IPPS
- Kerberos, SSL, WEP, TLS, WPA, WPA2, 802.1x, TKIP, AES
- Connections
- 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow)
- Power Device
- Power supply - internal
- 380 Watt
- Power Consumption Stand by / Sleep
- 60 Watt
- OS Required
- Limited warranty - 1 year
- Sound Emission (Idle)
- 33 dBA
- Sound Emission (Operating)
- 53 dBA
- 41 cm
- 46.5 cm
- 24 cm
- 18.1 kg
- Width (Shipping)
- 59.7 cm
- Depth (Shipping)
- 52.1 cm
- Height (Shipping)
- 36.4 cm
- Weight (Shipping)
- 21.5 kg
Brother TN241BK Toner Cartridge Black | In Stock | £48.30 |
Brother TN245C Toner Cartridge Cyan | In Stock | £67.91 |
Brother Drum Unit yield 15k | In Stock | £72.88 |
