Brother HL3170CDW Colour Laser Printer
Quicklinx: 8P2MWS00 Mfr#: HL3170CDWZU1
  • Windows 8 (32/64 bits)
Built with performance in mind, the efficient and speedy HL-3170CDW makes it simple to create standout, professional-looking documents.
This flexible colour printer is ideal for small but busy spaces. Optional high-yield colour toner cartridges, double-sided functionality and low energy consumption can help to reduce your total print costs, while the fast print speeds (22ppm) and easy-to-operate backlit LCD screen control guarantee quick and impressive results.
To make it easy to stay connected wherever you are in the office, the compact HL-3170CDW features both wired and wireless technology. Plus you can also send documents to print direct from your mobile device.
  • Blazing fast printing
    Fast color and black print speeds up to 23 ppm to help improve your productivity.
  • Automatic two-sided printing
    Automatic duplex for two-sided printing to help save paper.
  • Flexible connectivity
    Easy to install on your wired or wireless network or print locally via USB: from your computer.
  • High-impact business printing
    Produce crisp black and high-impact color business documents at up to 600 x 2400 dpi resolution using Brother's digital LED print technology.
  • Versatile paper handling
    250-sheet capacity paper tray adjustable for letter or legal and a straight-through paper path via manual feed slot for envelope printing.
  • Mobile device printing
    Wireless printing from your mobile device via: AirPrint, Google Cloud Print, Brother iPrint&Scan, Cortado Workplace and Wi-Fi Direct.
  • Help control your color printing costs
    Use the secure function lock feature to set color page counts or restrict color printing for up to 25 users.
  • Help lower your operating costs
    High capacity color toners available to help lower your cost per copy.
  • Deep sleep mode
    Deep sleep mode to conserve energy when printer is not being used.
Brother HL-3170CDW - printer - colour - LED
Printer Type
Workgroup printer - LED - colour
18.1 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 116 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 22 ppm - B/W , Up to 22 ppm - colour , Up to 7 ipm - B/W duplex , Up to 7 ipm - colour duplex
Max Resolution (B&W)
2400 x 600 dpi
Max Resolution (Colour)
2400 x 600 dpi
Automatic Duplexing
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
333 MHz
RAM Installed (Max)
128 MB
Language Simulation
PCL 6, BR-Script3
Media Type
Plain paper, bond paper, recycled paper, glossy paper
Total Media Capacity
250 sheets
Media Handling
250-sheet input tray, 1-sheet multipurpose tray
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
300 - 1500 pages
Print server
Linux, Microsoft Windows XP Home Edition, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Apple MacOS X 10.6.8, Microsoft Windows Server 2012, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Microsoft Windows XP Professional (32/64 bits)
Microsoft Certification
Compatible with Windows 7
1-year warranty
41 cm x 46.5 cm x 24 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wireless
AirPrint Enabled
2400 x 600 dpi
2400 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
16 sec
First Print Out Time Colour
16 sec
Language Simulation
PCL 6, BR-Script3
Media Handling
333 MHz
RAM
RAM Installed (Max)
128 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 116 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm)
Media Weight
60 g/m² - 163 g/m²
250 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , 1 x manual - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Output Trays Capacity
100 sheets
Duty Cycle
30000 pages
300 - 1500 pages
Print server
Remote Management Protocol
SNMP, SNMP 3, IPP, HTTP, HTTPS, TFTP, IPPS
Security Protocols & Features
Kerberos, SSL, WEP, TLS, WPA, WPA2, 802.1x, TKIP, AES
1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow)
Power supply - internal
380 Watt
Power Consumption Stand by / Sleep
60 Watt
Limited warranty - 1 year
Sound Emission (Idle)
33 dBA
Sound Emission (Operating)
53 dBA
41 cm
46.5 cm
24 cm
18.1 kg
Width (Shipping)
59.7 cm
Depth (Shipping)
52.1 cm
Height (Shipping)
36.4 cm
Weight (Shipping)
21.5 kg
8P2M Brother TN241BK Toner Cartridge Black In Stock £52.04
8P2M Brother TN245C Toner Cartridge Cyan In Stock £73.22
