Brother HL-L9310CDW Colour Laser Printer
Quicklinx: CTP2WS00 Mfr#: HLL9310CDWZU1
Type: Printer
Functionality: Printer
Wireless Capability: Wired, Wireless
Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
£467.00 ex VAT
£560.40 inc VAT
HL-L9310CDW
Professional colour laser printing that can grow asyour business grows.
Built for demanding office environments the HL-L9310CDW is designed to be robust and packed full of business features.
With security a key requirement in today’s offices this model features built-in NFC connectivity to ensure that all your documents are safe and secure. Together with the advanced paper handling capabilities you no longer need to regularly spend time refilling paper trays.
Key Features
  • Fast print speeds of up to 31ppm colour and mono
  • Paper input of up to 300 sheets
  • Maximum paper input of up to 2380 sheets
  • Automatic 2-Sided Printing
  • Optional ultra high-yield replacement cartridges 9000 blackcyan magenta and yellow toner cartridges
  • Built-in Ethernet 10Base- T/100Base- TX/1000Base-T
  • Integrated NFC Reader
  • Intuitive 6.8cm colour touchscreen
Increase productivity levels
  • Productivity is increased significantly thanks to the fast print speeds of up to 31ppm in colour and mono.
  • Maximise your efficiency with built-in wireless IEEE 802.11b/g/n and ethernet 10Base-T/100Base-TX/1000Base-T.
  • Easily print from your mobile device using Brother’s iPrint&Scan Brother print service plugin for Android Google Cloud Print 2.0 Mopria and AirPrint.
  • Outstanding paper handling options with a standard paper capacity of 300 sheets expandable to 2380 sheets.
Meeting security challenges
Modern businesses demand the highest levels of security. With Secure Function Lock 3.0 Active Directory Authentication IPsec 802.1x and Secure Print you can be confident that your documents are safe
Flexible and low running costs
Designed for high volume printing environments the HL-L9310CDW includes a 6500 page black cyan magenta and yellow toners and can take optional ultra high-yield cartridges of 9000 page black cyan magenta and yellow toners to lower your running costs even further.
Brother HL-L9310CDW - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
22.2 kg
United Kingdom
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 31 ppm - B/W - A4 (210 x 297 mm) , Up to 31 ppm - colour - A4 (210 x 297 mm) , Up to 33 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 33 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 14 spm - B/W duplex - A4 (210 x 297 mm) , Up to 14 spm - colour duplex - A4 (210 x 297 mm) , Up to 14 spm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 14 spm - colour duplex - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
2400 x 600 dpi
Max Resolution (Colour)
2400 x 600 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
Preview Screen Size
2.7"
800 MHz
RAM Installed (Max)
1 GB
Language Simulation
PostScript 3, PCL 6, XPS, PDF 1.7
Media Type
Envelopes, labels, plain paper, recycled paper, thick paper, paper, thin paper, glossy paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Recommended Monthly Volume
6000 pages
Print server
AC 230V
44.1 cm x 48.6 cm x 31.3 cm
Printer Type
United Kingdom
Printer
Print Speed
Built-in Devices
Touch screen
Preview Screen Size
2.7"
Wireless
AirPrint Enabled
2400 x 600 dpi
2400 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
15 sec
First Print Out Time Colour
15 sec
Language Simulation
Fonts Included
66 x scalable PostScript , 66 x scalable PCL , 12 x bitmapped PCL , 16 x barcode
Media Handling
800 MHz
RAM
RAM Installed (Max)
1 GB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 163 g/m²
300 sheets
Media Feeders
Input tray: 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Bypass tray: 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Output Trays Capacity
150 sheets
Duty Cycle
6000 pages
Print server
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, TFTP, IPPS
Security Protocols & Features
Kerberos, SSL, LEAP, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, TKIP, AES, TTLS, PEAP
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 6500 pages , 1 x toner cartridge (cyan) - up to 6500 pages , 1 x toner cartridge (magenta) - up to 6500 pages , 1 x toner cartridge (yellow) - up to 6500 pages
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
580 Watt
Power Consumption Stand by
70 Watt
Power Consumption Sleep
10 Watt
Environmental Standards
Blue Angel
ENERGY STAR
Nordic Swan Ecolabel
Limited warranty - 2 years , Limited warranty - 1 year - on-site
10 °C
32 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
49 dBA
Sound Emission (Quiet Mode)
44 dBA
44.1 cm
48.6 cm
31.3 cm
22.2 kg
Width (Shipping)
64.2 cm
Depth (Shipping)
60.3 cm
Height (Shipping)
57.8 cm
Weight (Shipping)
26.8 kg
Type: Printer
Wireless Capability: Wireless
Brand: Brother
Price Range Ex VAT: 300 - 500
