Brother HL-L9310CDW Colour Laser Printer
Quicklinx: CTP2WS00 Mfr#: HLL9310CDWZU1
Type: Printer
Functionality: Printer
Wireless Capability: Wireless, Wired
Max Paper Size: Legal (216 x 356 mm), A4 (210 x 297 mm)
£487.61 ex VAT
£585.13 inc VAT
HL-L9310CDW
Professional colour laser printing that can grow asyour business grows.
Built for demanding office environments the HL-L9310CDW is designed to be robust and packed full of business features.
With security a key requirement in today’s offices this model features built-in NFC connectivity to ensure that all your documents are safe and secure. Together with the advanced paper handling capabilities you no longer need to regularly spend time refilling paper trays.
Key Features
  • Fast print speeds of up to 31ppm colour and mono
  • Paper input of up to 300 sheets
  • Maximum paper input of up to 2380 sheets
  • Automatic 2-Sided Printing
  • Optional ultra high-yield replacement cartridges 9000 blackcyan magenta and yellow toner cartridges
  • Built-in Ethernet 10Base- T/100Base- TX/1000Base-T
  • Integrated NFC Reader
  • Intuitive 6.8cm colour touchscreen
Increase productivity levels
  • Productivity is increased significantly thanks to the fast print speeds of up to 31ppm in colour and mono.
  • Maximise your efficiency with built-in wireless IEEE 802.11b/g/n and ethernet 10Base-T/100Base-TX/1000Base-T.
  • Easily print from your mobile device using Brother’s iPrint&Scan Brother print service plugin for Android Google Cloud Print 2.0 Mopria and AirPrint.
  • Outstanding paper handling options with a standard paper capacity of 300 sheets expandable to 2380 sheets.
Meeting security challenges
Modern businesses demand the highest levels of security. With Secure Function Lock 3.0 Active Directory Authentication IPsec 802.1x and Secure Print you can be confident that your documents are safe
Flexible and low running costs
Designed for high volume printing environments the HL-L9310CDW includes a 6500 page black cyan magenta and yellow toners and can take optional ultra high-yield cartridges of 9000 page black cyan magenta and yellow toners to lower your running costs even further.
  • Efficient connectivity
    With a wide range of connectivity options including Gigabit Ethernet, NFC, USB 2.0, USB host, and Wi-Fi, the Brother HL-L9310CDW ensures seamless integration into any work environment. Mobile printing capabilities with Apple AirPrint make it easy to print from anywhere.
  • High-quality printing
    Achieve professional, high-resolution color and B/W prints with a maximum resolution of 2400 x 600 DPI. Automatic duplexing adds to the printer's efficiency, allowing for double-sided printing without manual intervention.
  • Robust media handling
    Designed to accommodate a variety of media sizes including A4, Legal, and more, with a total media capacity of 300 sheets. The printer supports a range of media types such as envelopes, plain paper, and recycled paper, making it versatile for all printing needs.
  • Secure and reliable
    Equipped with advanced security protocols including AES, SSL, TKIP, TLS, WEP, WPA-PSK, and WPA2-PSK to protect sensitive information. The recommended monthly volume of 6000 pages ensures reliability for high-demand printing tasks.
  • User-friendly operation
    The HL-L9310CDW features an 800 MHz processor for swift processing of print jobs and supports language simulations like PCL 6 and PDF 1.7 for compatibility with a variety of document types. Sound emission during operation is kept to a minimal 49 dBA, ensuring a quiet work environment.
Brother HL-L9310CDW - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
22.2 kg
United Kingdom
Media Size Class
A4/Legal
Max Media Size
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 31 ppm - B/W - A4 (210 x 297 mm) , Up to 31 ppm - colour - A4 (210 x 297 mm) , Up to 33 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 33 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 14 spm - B/W duplex - A4 (210 x 297 mm) , Up to 14 spm - colour duplex - A4 (210 x 297 mm) , Up to 14 spm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 14 spm - colour duplex - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
2400 x 600 dpi
Max Resolution (Colour)
2400 x 600 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
Preview Screen Size
2.7"
800 MHz
RAM Installed (Max)
1 GB
Language Simulation
PostScript 3, PCL 6, XPS, PDF 1.7
Media Type
Envelopes, labels, plain paper, recycled paper, thick paper, paper, thin paper, glossy paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Recommended Monthly Volume
6000 pages
Print server
44.1 cm x 48.6 cm x 31.3 cm
Printer Type
United Kingdom
Printer
Print Speed
Built-in Devices
Touch screen
Preview Screen Size
2.7"
Wireless
AirPrint Enabled
2400 x 600 dpi
2400 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
15 sec
First Print Out Time Colour
15 sec
Language Simulation
Fonts Included
66 x scalable PostScript , 66 x scalable PCL , 12 x bitmapped PCL , 16 x barcode
Media Handling
800 MHz
RAM
RAM Installed (Max)
1 GB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 163 g/m²
300 sheets
Media Feeders
Input tray: 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Bypass tray: 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Output Trays Capacity
150 sheets
Duty Cycle
6000 pages
Print server
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, TFTP, IPPS
Security Protocols & Features
Kerberos, SSL, LEAP, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, TKIP, AES, TTLS, PEAP
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 6500 pages , 1 x toner cartridge (cyan) - up to 6500 pages , 1 x toner cartridge (magenta) - up to 6500 pages , 1 x toner cartridge (yellow) - up to 6500 pages
Power supply - internal
Frequency Required
50/60 Hz
580 Watt
Power Consumption Stand by
70 Watt
Power Consumption Sleep
10 Watt
Environmental Standards
Blue Angel
ENERGY STAR
Nordic Swan Ecolabel
Limited warranty - 2 years , Limited warranty - 1 year - on-site
10 °C
32 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
49 dBA
Sound Emission (Quiet Mode)
44 dBA
44.1 cm
48.6 cm
31.3 cm
22.2 kg
Width (Shipping)
64.2 cm
Depth (Shipping)
60.3 cm
Height (Shipping)
57.8 cm
Weight (Shipping)
26.8 kg
CTP2 Brother Waste Toner Pack In Stock £14.36
Type: Printer
Wireless Capability: Wired
Max Paper Size: A4 (210 x 297 mm)
Brand: Brother
