The HL-L9200CDWT is ideal for the bigger, more demanding office. It offers impressive connectivity - with wired and wireless networking, direct USB connection, and support for the full suite of Brother apps allowing printing and sharing from smartphones and tablets. You can also connect directly to the cloud.
It's efficient and economical too, with print speeds up to a fantastic 30ppm, plus two-sided printing and super-high-yield toners - delivering even higher levels of value and productivity. In fact, the HL-L9200CDWT offers our best ever total cost of ownership for a printer in its class. And despite its advanced features, it's easy to use and manage. Meaning everybody can get first class, professional quality colour prints, first time, every time.
Fast, high-quality business printing
With print speeds up to 32ppm in both color and black and up to 2400 x 600dpi resolution, you no longer have to wait for high-impact business documents. -
800-sheet paper capacity
The Brother HL-L9200CDWT features dual paper trays that are adjustable for letter or legal size paper. Plus, a 50-sheet capacity multi-purpose tray for printing letterhead and custom paper sizes up to legal size. -
Flexible connectivity
Featuring built-in wireless 802.11b/g/n and Ethernet network interfaces to easily setup and share on your wireless or wired network or print locally via USB from your computer -
Easily print two-sided documents
Using the duplex printing feature, you can help reduce your printing costs and produce professional two-sided documents, presentations and brochures. -
1.8" color TouchScreen display
Offers intuitive menu navigation, shortcuts, and printing from popular cloud services. -
Help control your printing costs
Use the Secure Function Lock feature to set page counts or restrict printing on a per user or group basis. -
Walk-up printing
Features a front-access USB Direct Interface to directly print from your USB flash memory drive.
- Brother HL-L9200CDWT - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 28.3 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 215.9 mm x 355.6 mm
- Print Speed
- Up to 30 ppm - B/W - A4 (210 x 297 mm) , Up to 30 ppm - colour - A4 (210 x 297 mm) , Up to 14 spm - B/W duplex - A4 (210 x 297 mm) , Up to 14 spm - colour duplex - A4 (210 x 297 mm) , Up to 32 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 32 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 14 spm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 14 spm - colour duplex - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 2400 x 600 dpi
- Max Resolution (Colour)
- 2400 x 600 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- RAM Installed (Max)
- 128 MB (384 MB) - DDR2 SDRAM - SO-DIMM 144-pin
- Language Simulation
- PCL 6, XPS, BR-Script3, PDF 1.7
- Media Type
- Envelopes, labels, plain paper, bond paper, recycled paper, thick paper, thin paper, glossy paper
- Total Media Capacity
- 800 sheets
- Media Handling
- 250-sheet input tray, 500-sheet input tray, 50-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 75000 pages
- Recommended Monthly Volume
- 1000 - 5000 pages
- Networking
- Print server
- Printer Features
- AirStation OneTouch Secure System (AOSS)
- System Requirements
- Linux, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32-bit versions), Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008 x64 Edition, Microsoft Windows Server 2008 R2 x64 Edition, Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 64-bit Edition, Windows 8 32-bit Edition, Microsoft Windows Server 2008 32-bit, Microsoft Windows XP 32-bit, Microsoft Windows Server 2012 x64 Edition, Windows 8.1 32-bit Edition, Windows 8.1 64-bit Edition, Apple OS X 10.9 Mavericks, Microsoft Windows Server 2012 R2 x64 Edition, Microsoft Windows 7 32-bit Edition
- 41 cm x 49.5 cm x 44.5 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Touch screen
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 2400 x 600 dpi
- 2400 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 15 sec
- First Print Out Time Colour
- 15 sec
- Printer Features
- Media Handling
RAM
- 128 MB / 384 MB (max)
- Technology / Form Factor
- Slots Qty
- 1
- Empty Slots
- 1
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 800 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , 1 x automatic - 50 sheets - 215.9 x 355.6 mm weight: 60 g/m² - 163 g/m² , 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m²
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 75000 pages
- 1000 - 5000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, TFTP, IPPS
- Kerberos, SSL, LEAP, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, TKIP, AES, WPS
- Connections
- 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - up to 6000 pages , 1 x toner cartridge (cyan) - up to 6000 pages , 1 x toner cartridge (magenta) - up to 6000 pages , 1 x toner cartridge (yellow) - up to 6000 pages
- Frequency Required
- 50/60 Hz
- 540 Watt
- Power Consumption Stand by
- 65 Watt
- Software Included
- Drivers & Utilities
- OS Required
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
- Sound Emission (Idle)
- 27.3 dBA
- Sound Emission (Operating)
- 55.1 dBA
- Sound Emission (Quiet Mode)
- 50.8 dBA
- 41 cm
- 49.5 cm
- 44.5 cm
- 28.3 kg
- Width (Shipping)
- 81 cm
- Depth (Shipping)
- 59.7 cm
- Height (Shipping)
- 88.7 cm
- Weight (Shipping)
- 39.5 kg
