Brother HL-L8360CDW Colour Laser Printer
Quicklinx: CTP6WS00 Mfr#: HLL8360CDWZU1
Type: Printer
Functionality: Printer
Wireless Capability: Wired, Wireless
Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
15 In Stock
£271.83 ex VAT
£326.19 inc VAT
HL-L8360CDW
Wireless colour laser printer with intuitive security functions.
Key Features
  • Fast print speeds of up to 31ppm colour and mono
  • Paper input of up to 300 sheets
  • Maximum paper input of up to 2380 sheets
  • Automatic 2-Sided Printing
  • Optional Super high-yield replacement cartridges 9000 black 6500 cyan magenta and yellow toner cartridge
  • Built-in Ethernet 10Base-T/100Base-TX /1000Base-T
  • Integrated NFC Reader
  • Intuitive 6.8cm colour touchscreen
Increase productivity levels
  • Productivity is increased significantly thanks to the fast print speeds of up to 31ppm in colour and mono.
  • Maximise your efficiency with built-in wireless IEEE 802.11b/g/n andethernet 10Base-T/100Base-TX/1000Base-T.
  • Easily print from your mobile device using Brother’s iPrint&Scan Brother print service plugin for Android Google Cloud Print 2.0 Mopria and AirPrint.
  • Outstanding paper handling options with a standard paper capacity of 300 sheets expandable to 2380.
Meeting security challenges
Modern businesses demand the highest levels of security. With Secure Function Lock 3.0 Active Directory Authentication Internet Protocol Security (IPsec) 802.1x and Secure Print you can be confident that your documents are safe and secure near field communication (NFC) functionality.
Flexible and low running costs
Designed for flexible printing requirements the HL-L8360CDW includes a 3000 page black and 1800 page cyan magenta and yellow toners and can take an optional high yield 6500 page black and 4000 page cyan magenta and yellow page toners to lower your running costs even further. Together with a further cost saving of taking super high-yield replacement cartridges of 9000 black 6500 cyan magenta and yellow toner cartridge.
  • Fast, high-quality business printing
    With print speeds up to 33 pages per minute in both color and black and up to 2400 x 600 dpi class resolution, you no longer have to wait for high-impact business documents.
  • Low cost printing
    Spend less time replacing supplies and help reduce operating costs by using Brother genuine super high-yield 6500-page replacement toner cartridges.
  • Flexible network connectivity
    Built-in wireless 802.11b/g/n and Gigabit Ethernet network interfaces to easily setup and share on your wireless or wired network.
  • Convenient mobile device printing
    Print from your mobile device via AirPrint, Mopria, Brother iPrint&Scan, Wi-Fi Direct, and NFC.
  • Easily print two-sided documents
    Use the automatic duplex print feature to help reduce your printing costs and produce professional two-sided documents, presentations, brochures, and booklets.
Brother HL-L8360CDW - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
21.9 kg
United Kingdom
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 31 ppm - B/W - A4 (210 x 297 mm) , Up to 31 ppm - colour - A4 (210 x 297 mm) , Up to 33 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 33 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 14 spm - B/W duplex - A4 (210 x 297 mm) , Up to 14 spm - colour duplex - A4 (210 x 297 mm) , Up to 14 spm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 14 spm - colour duplex - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
2400 x 600 dpi
Max Resolution (Colour)
2400 x 600 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
Preview Screen Size
2.7"
800 MHz
RAM Installed (Max)
512 MB
Language Simulation
PostScript 3, PCL 6, XPS, PDF 1.7
Media Type
Envelopes, labels, plain paper, recycled paper, thick paper, paper, thin paper, glossy paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Recommended Monthly Volume
4000 pages
Print server
44.1 cm x 48.6 cm x 31.3 cm
Printer Type
United Kingdom
Printer
Print Speed
Built-in Devices
Touch screen
Preview Screen Size
2.7"
Wireless
AirPrint Enabled
2400 x 600 dpi
2400 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
15 sec
First Print Out Time Colour
15 sec
Language Simulation
Fonts Included
66 x scalable PostScript , 66 x scalable PCL , 12 x bitmapped PCL , 16 x barcode
Media Handling
800 MHz
RAM
RAM Installed (Max)
512 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 163 g/m²
300 sheets
Media Feeders
Input tray: 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Bypass tray: 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Max Sheets in Multi-Part Form
2380
Output Trays Capacity
150 sheets
Duty Cycle
4000 pages
Print server
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, TFTP, IPPS
Security Protocols & Features
Kerberos, SSL, LEAP, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, TKIP, AES, TTLS, PEAP
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 3000 pages , 1 x toner cartridge (cyan) - up to 1800 pages , 1 x toner cartridge (magenta) - up to 1800 pages , 1 x toner cartridge (yellow) - up to 1800 pages , 1 x waste toner collector - up to 50000 pages - Brother WT320CL , 1 x drum - up to 50000 pages 3 pages per job , 1 x transmission belt - up to 130000 pages 3 pages per job
Power supply - internal
Frequency Required
50/60 Hz
580 Watt
Power Consumption Stand by
70 Watt
Power Consumption Sleep
10 Watt
Environmental Standards
Blue Angel
ENERGY STAR
Nordic Swan Ecolabel
Limited warranty - 2 years , Limited warranty - 1 year - on-site
10 °C
32 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
49 dBA
Sound Emission (Quiet Mode)
44 dBA
44.1 cm
48.6 cm
31.3 cm
21.9 kg
Width (Shipping)
61.7 cm
Depth (Shipping)
55.8 cm
Height (Shipping)
52.1 cm
Weight (Shipping)
25.9 kg
CTP6 Brother Waste Toner Pack In Stock £15.41
Type: Printer
Wireless Capability: Wireless
Brand: Brother
