The new HL-L8350CDW will help even the smallest office increase productivity by allowing staff to create crisp, clear professional colour prints at a fraction of the price.
Improved print speeds deliver best in class performance of up to 30ppm, colour or mono, with first page out speeds of less than 10 seconds. Super-high-yield toners drive down costs and increase time between cartridge changes, while every request connects perfectly thanks to on board Wi-Fi for network sharing and Wi-Fi Direct for flawless mobile and tablet connectivity on-the-go.
Fast, high-quality business printing
With print speeds up to 32 ppm in both color and black and up to 2400 x 600 dpi resolution, you no longer have to wait for high-impact business documents. -
Easily print two-sided documents
Using the duplex printing feature, you can help reduce your printing costs and produce professional two-sided documents, presentations and brochures. -
Flexible connectivity
Featuring built-in wireless 802.11 b/g/n and Ethernet network interfaces to easily setup and share on your wireless or wired network or print locally via USB from your computer. -
Versatile paper handling
The HL-L8350CDW offers a 250-sheet capacity paper tray that is adjustable for letter or legal size paper and a 50-sheet capacity multi-purpose tray for printing letterhead and custom paper sizes. -
Cost-efficient printing
Spend less time replacing supplies and help reduce operating costs by using high-yield replacement toner cartridges. -
Help control your printing costs
Use the secure function lock feature to set page counts or restrict printing on a per user or group basis (supports up to 100 users). -
Walk-up printing
Features a front-access USB direct interface to directly print from your USB flash memory drive. -
Advanced security features
Provides a wide-range of security features including: secure print, secure function lock, SSL, enterprise security (802.1x) and more.
- Brother HL-L8350CDW - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 21.9 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 215.9 mm x 355.6 mm
- Print Speed
- Up to 30 ppm - B/W - A4 (210 x 297 mm) , Up to 30 ppm - colour - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 2400 x 600 dpi
- Max Resolution (Colour)
- 2400 x 600 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Processor
- 400 MHz
- RAM Installed (Max)
- 128 MB (384 MB)
- Language Simulation
- PCL 6, XPS, BR-Script3, PDF 1.7
- Media Type
- Envelopes, labels, plain paper, bond paper, recycled paper, thick paper, thin paper, glossy paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 250-sheet input tray, 50-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 60000 pages
- Recommended Monthly Volume
- 750 - 4000 pages
- Networking
- Print server
- System Requirements
- Linux, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32-bit versions), Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008 x64 Edition, Microsoft Windows Server 2008 R2 x64 Edition, Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 64-bit Edition, Windows 8 32-bit Edition, Microsoft Windows Server 2008 32-bit, Microsoft Windows XP 32-bit, Microsoft Windows Server 2012 x64 Edition, Windows 8.1 32-bit Edition, Windows 8.1 64-bit Edition, Apple OS X 10.9 Mavericks, Microsoft Windows Server 2012 R2 x64 Edition, Microsoft Windows 7 32-bit Edition
- Microsoft Certification
- Compatible with Windows 7
- 41 cm x 48.6 cm x 31.3 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 2400 x 600 dpi
- 2400 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 10 sec
- First Print Out Time Colour
- 10 sec
- Media Handling
- Processor
- 400 MHz
RAM
- 128 MB / 384 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 300 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , 1 x automatic - 50 sheets - 215.9 x 355.6 mm weight: 60 g/m² - 163 g/m²
- Max Media Capacity
- 800 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 60000 pages
- 750 - 4000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, TFTP, IPPS
- Kerberos, SSL, LEAP, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, TKIP, AES, WPS
- Connections
- 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - up to 2500 pages , 1 x toner cartridge (cyan) - up to 1500 pages , 1 x toner cartridge (magenta) - up to 1500 pages , 1 x toner cartridge (yellow) - up to 1500 pages
- Frequency Required
- 50/60 Hz
- 540 Watt
- Power Consumption Stand by
- 65 Watt
- Power Consumption Sleep
- 7.5 Watt
- Software Included
- Drivers & Utilities
- OS Required
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
- Sound Emission (Idle)
- 27.9 dBA
- Sound Emission (Operating)
- 53.5 dBA
- Sound Emission (Quiet Mode)
- 50.6 dBA
- 41 cm
- 48.6 cm
- 31.3 cm
- 21.9 kg
- Width (Shipping)
- 60 cm
- Depth (Shipping)
- 52.4 cm
- Height (Shipping)
- 51.3 cm
- Weight (Shipping)
- 25.5 kg
