Brother HL-L8260CDW Colour Laser Printer
Quicklinx: CTP7WS00 Mfr#: HLL8260CDWZU1
Type: Printer
Functionality: Printer
Wireless Capability: Wired, Wireless
Max Paper Size: Legal (216 x 356 mm), A4 (210 x 297 mm)
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
More than 50 In Stock
£218.37 ex VAT
£262.04 inc VAT
HL-L8260CDW
Simple and easy to use wireless colour laser printer.
Key Features
  • Fast print speeds of up to 31ppm colour and mono
  • Paper input of up to 300 sheets
  • Maximum paper input of up to 1050 sheets
  • Automatic 2-Sided Printing
  • Optional high-yield replacement cartridges 6500 black 4000 page cyan magenta and yellow toner cartridges
  • Built-in Ethernet 10Base-T/100Base-TX /1000Base-T
Increase productivity levels
  • Productivity is increased significantly thanks to the fast print speeds of up to 31ppm in colour and mono.
  • Maximise your efficiency with built-in wireless IEEE 802.11b/g/n and ethernet 10Base-T/100Base-TX/1000Base-T.
  • Easily print from your mobile device using Brother’s iPrint&Scan Brother print service plugin for Android Google Cloud Print 2.0 Mopria and AirPrint
Meeting security challenges
Modern businesses demand the highest levels of security. With Secure Function Lock 3.0 IPsec 802.1x and Secure Print you can be confident that your documents are safe
Flexible and low running costs
  • Designed for flexible printing requirements the HL-L8260CDW includes a black 3000 page toner and cyan magenta and yellow 1800 page toner and can take an optional 6500 page black and 4000 page cyan magenta and yellow page toners to lower your running costs even further.
  • Great paper handling options with a standard paper capacity of up to 300 sheets expandable to 1050 sheets.
  • Better reliability
    Built to perform for longer and meet the demands of high output work environments, Brother's color laser range has been totally remodeled with robust build quality that's even more resilient and hardwearing.
  • Eco-friendly
    Brother's latest color laser range is compliant with a number of environmental standards. As a result, not only does it help your business work more efficiently, it is also more energy efficient, reducing impact on the environment and lowering your costs at the same time.
Brother HL-L8260CDW - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
21.8 kg
United Kingdom
Media Size Class
A4/Legal
Max Media Size
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 31 ppm - B/W - A4 (210 x 297 mm) , Up to 31 ppm - colour - A4 (210 x 297 mm) , Up to 33 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 33 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 14 spm - B/W duplex - A4 (210 x 297 mm) , Up to 14 spm - colour duplex - A4 (210 x 297 mm) , Up to 14 spm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 14 spm - colour duplex - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
2400 x 600 dpi
Max Resolution (Colour)
2400 x 600 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
800 MHz
RAM Installed (Max)
256 MB
Language Simulation
PostScript 3, PCL 6, XPS, PDF 1.7
Media Type
Envelopes, labels, plain paper, recycled paper, thick paper, paper, thin paper, glossy paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Recommended Monthly Volume
3000 pages
Print server
Linux, Android, Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Apple iOS, Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Apple MacOS X 10.10, Windows 10 (32/64 bits), Windows Phone, Apple MacOS X 10.11, Apple macOS 10.12
41 cm x 48.6 cm x 31.3 cm
Printer Type
United Kingdom
Printer
Print Speed
Built-in Devices
Status LCD
Wireless
AirPrint Enabled
2400 x 600 dpi
2400 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
15 sec
First Print Out Time Colour
15 sec
Language Simulation
Fonts Included
66 x scalable PostScript , 66 x scalable PCL , 12 x bitmapped PCL , 16 x barcode
Media Handling
800 MHz
RAM
RAM Installed (Max)
256 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 163 g/m²
300 sheets
Media Feeders
Input tray: 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Bypass tray: 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Output Trays Capacity
150 sheets
Duty Cycle
3000 pages
Print server
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, TFTP, IPPS
Security Protocols & Features
Kerberos, SSL, LEAP, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, TKIP, AES, TTLS, PEAP
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 3000 pages , 1 x toner cartridge (cyan) - up to 1800 pages , 1 x toner cartridge (magenta) - up to 1800 pages , 1 x toner cartridge (yellow) - up to 1800 pages , 1 x waste toner collector - up to 50000 pages - Brother WT320CL , 1 x drum - up to 50000 pages 3 pages per job , 1 x transmission belt - up to 130000 pages 3 pages per job
Power supply - internal
Frequency Required
50/60 Hz
580 Watt
Power Consumption Stand by
70 Watt
Power Consumption Sleep
10 Watt
10 °C
32 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
49 dBA
Sound Emission (Quiet Mode)
44 dBA
41 cm
48.6 cm
31.3 cm
21.8 kg
Width (Shipping)
61.7 cm
Depth (Shipping)
53.3 cm
Height (Shipping)
52.1 cm
Weight (Shipping)
25.4 kg
CTP7 Brother Waste Toner Pack In Stock £14.53
Type: Printer
Wireless Capability: Wireless
Max Paper Size: A4 (210 x 297 mm)
Brand: Brother
