HL-L8260CDW
Simple and easy to use wireless colour laser printer.
Key Features
- Fast print speeds of up to 31ppm colour and mono
- Paper input of up to 300 sheets
- Maximum paper input of up to 1050 sheets
- Automatic 2-Sided Printing
- Optional high-yield replacement cartridges 6500 black 4000 page cyan magenta and yellow toner cartridges
- Built-in Ethernet 10Base-T/100Base-TX /1000Base-T
Increase productivity levels
- Productivity is increased significantly thanks to the fast print speeds of up to 31ppm in colour and mono.
- Maximise your efficiency with built-in wireless IEEE 802.11b/g/n and ethernet 10Base-T/100Base-TX/1000Base-T.
- Easily print from your mobile device using Brother’s iPrint&Scan Brother print service plugin for Android Google Cloud Print 2.0 Mopria and AirPrint
Meeting security challenges
Modern businesses demand the highest levels of security. With Secure Function Lock 3.0 IPsec 802.1x and Secure Print you can be confident that your documents are safe
Flexible and low running costs
- Designed for flexible printing requirements the HL-L8260CDW includes a black 3000 page toner and cyan magenta and yellow 1800 page toner and can take an optional 6500 page black and 4000 page cyan magenta and yellow page toners to lower your running costs even further.
- Great paper handling options with a standard paper capacity of up to 300 sheets expandable to 1050 sheets.
Better reliability
Built to perform for longer and meet the demands of high output work environments, Brother's color laser range has been totally remodeled with robust build quality that's even more resilient and hardwearing. -
Eco-friendly
Brother's latest color laser range is compliant with a number of environmental standards. As a result, not only does it help your business work more efficiently, it is also more energy efficient, reducing impact on the environment and lowering your costs at the same time.
- Brother HL-L8260CDW - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 21.8 kg
- Localisation
- United Kingdom
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 31 ppm - B/W - A4 (210 x 297 mm) , Up to 31 ppm - colour - A4 (210 x 297 mm) , Up to 33 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 33 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 14 spm - B/W duplex - A4 (210 x 297 mm) , Up to 14 spm - colour duplex - A4 (210 x 297 mm) , Up to 14 spm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 14 spm - colour duplex - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 2400 x 600 dpi
- Max Resolution (Colour)
- 2400 x 600 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Processor
- 800 MHz
- RAM Installed (Max)
- 256 MB
- Language Simulation
- PostScript 3, PCL 6, XPS, PDF 1.7
- Media Type
- Envelopes, labels, plain paper, recycled paper, thick paper, paper, thin paper, glossy paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 250-sheet input tray, 50-sheet multipurpose tray
- Recommended Monthly Volume
- 3000 pages
- Networking
- Print server
- System Requirements
- Linux, Android, Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Apple iOS, Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Apple MacOS X 10.10, Windows 10 (32/64 bits), Windows Phone, Apple MacOS X 10.11, Apple macOS 10.12
- 41 cm x 48.6 cm x 31.3 cm
- Printer Type
- Localisation
- United Kingdom
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 2400 x 600 dpi
- 2400 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 15 sec
- First Print Out Time Colour
- 15 sec
- Fonts Included
- 66 x scalable PostScript , 66 x scalable PCL , 12 x bitmapped PCL , 16 x barcode
- Media Handling
- Processor
- 800 MHz
RAM
- 256 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 300 sheets
- Media Feeders
- Input tray: 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Bypass tray: 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 3000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, TFTP, IPPS
- Kerberos, SSL, LEAP, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, TKIP, AES, TTLS, PEAP
- Connections
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - up to 3000 pages , 1 x toner cartridge (cyan) - up to 1800 pages , 1 x toner cartridge (magenta) - up to 1800 pages , 1 x toner cartridge (yellow) - up to 1800 pages , 1 x waste toner collector - up to 50000 pages - Brother WT320CL , 1 x drum - up to 50000 pages 3 pages per job , 1 x transmission belt - up to 130000 pages 3 pages per job
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 580 Watt
- Power Consumption Stand by
- 70 Watt
- Power Consumption Sleep
- 10 Watt
- OS Required
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
- Sound Emission (Operating)
- 49 dBA
- Sound Emission (Quiet Mode)
- 44 dBA
- 41 cm
- 48.6 cm
- 31.3 cm
- 21.8 kg
- Width (Shipping)
- 61.7 cm
- Depth (Shipping)
- 53.3 cm
- Height (Shipping)
- 52.1 cm
- Weight (Shipping)
- 25.4 kg
Brother Waste Toner Pack | In Stock | £14.36 |
