The reliable Brother HL-L3270CDW colour laser printer, is quiet and compact - ideal for the busy home or small office.
Designed to be desktop friendly, this robust printer, is fast, yet quiet, enabling you to carry on working, while the document is being printed. This model, also has a larger than average paper input, so that you don't need to worry about refilling the paper tray.
Fast printing keeps you moving
Delivering increased efficiency with quick print speeds up to 25 pages per minute. -
Print professional documents in black and color
Print high-quality business documents in sharp black and rich, vivid color. -
Versatile paper handling increases productivity
The 250-sheet capacity paper tray adjusts for letter or legal paper to help minimize paper refills. Plus, automatic duplex (2-sided) printing to help save on paper costs. -
Dependable, durable and compact design
Sturdy and robust construction ensures your printer works as hard as you do; compact design is ideal for smaller spaces.
- Brother HL-L3270CDW - printer - colour - LED
- Printer Type
- Workgroup printer - LED - colour
- 18.3 kg
- Localisation
- United Kingdom, Ireland
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 116 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 25 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 25 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 24 ppm - B/W - A4 (210 x 297 mm) , Up to 24 ppm - colour - A4 (210 x 297 mm) , Up to 8 spm - B/W duplex - A4 (210 x 297 mm) , Up to 8 spm - colour duplex - A4 (210 x 297 mm) , Up to 8 spm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 8 spm - colour duplex - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 2400 x 600 dpi
- Max Resolution (Colour)
- 2400 x 600 dpi
- Max Resolution Class (B&W)
- 2400 x 600 dpi
- Max Resolution Class (Colour)
- 2400 x 600 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN, Wi-Fi(n), NFC
- AirPrint Enabled
- Preview Screen Size
- 2.7"
- RAM Installed (Max)
- 256 MB
- Language Simulation
- PCL 6, XPS, BR-Script3, PDF 1.7
- Barcodes
- Code 93, Code 39, GS1 DataBar, UPC-A, UPC-E, Interleaved 2 of 5, Postnet, FIM, Code 128B, Code 128C, Code 128A, EAN-128, EAN-8, EAN-13, MSI
- Media Type
- Envelopes, labels, plain paper, bond paper, recycled paper, thick paper, thin paper, glossy paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet input tray, 1-sheet manual tray
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 300 - 1500 pages
- Networking
- Print server
- System Requirements
- Linux, Android, Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Apple iOS, Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits), Windows Phone, Apple MacOS X 10.11, Microsoft Windows Server 2016, Apple macOS 10.12, Windows 10 in S mode, Apple macOS 10.13
- 2-year warranty
- 43.9 cm x 46.1 cm x 25.2 cm
- Printer Type
- Localisation
Printer
- Print Speed
- Built-in Devices
- Touch screen
- 2.7"
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 2400 x 600 dpi
- 2400 x 600 dpi
- 2400 x 600 dpi
- 2400 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 14 sec
- First Print Out Time Colour
- 14 sec
- Fonts Included
- 73 x scalable PCL , 12 x bitmapped PCL , 66 x scalable PostScript
- Barcodes
- Media Handling
RAM
- 256 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 116 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm)
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 250 sheets
- Media Feeders
- Input tray: 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Bypass tray: 1 x manual - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray: 1 - 150 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 30000 pages
- 300 - 1500 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, TFTP, IPPS
- Kerberos, SSL, LEAP, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, TKIP, AES, WPS
- Connections
- 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages ISO/IEC 19752 , 1 x toner cartridge (cyan) - up to 1000 pages ISO/IEC 19752 , 1 x toner cartridge (magenta) - up to 1000 pages ISO/IEC 19752 , 1 x toner cartridge (yellow) - up to 1000 pages ISO/IEC 19752 , 1 x waste toner collector - up to 50000 pages 5 pages per job - Brother WT223CL , 1 x drum - up to 18000 pages 1 page per job - Brother DR243CL , 1 x transmission belt - up to 50000 pages 2 pages per job - Brother BU223CL
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 430 Watt
- Power Consumption Stand by
- 65 Watt
- Power Consumption Sleep
- 9.1 Watt
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- Nordic Swan Ecolabel
- Limited warranty - 2 years , Limited warranty - 1 year - on-site
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
- Sound Emission (Operating)
- 47 dBA
- Sound Emission (Quiet Mode)
- 43 dBA
- 43.9 cm
- 46.1 cm
- 25.2 cm
- 18.3 kg
- Width (Shipping)
- 58.9 cm
- Depth (Shipping)
- 53.2 cm
- Height (Shipping)
- 37.2 cm
- Weight (Shipping)
- 22.1 kg
Brother TN243BK Toner Black | In Stock | £38.71 |
