Brother HL-L3270CDW Colour Laser Printer
Quicklinx: F7K2WS00 Mfr#: HLL3270CDWZU1
Type: Printer
Functionality: Printer
Wireless Capability: Wired, Wireless
Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
£204.08 ex VAT
£244.89 inc VAT
The reliable Brother HL-L3270CDW colour laser printer, is quiet and compact - ideal for the busy home or small office.
Designed to be desktop friendly, this robust printer, is fast, yet quiet, enabling you to carry on working, while the document is being printed. This model, also has a larger than average paper input, so that you don't need to worry about refilling the paper tray.
  • Fast printing keeps you moving
    Delivering increased efficiency with quick print speeds up to 25 pages per minute.
  • Print professional documents in black and color
    Print high-quality business documents in sharp black and rich, vivid color.
  • Versatile paper handling increases productivity
    The 250-sheet capacity paper tray adjusts for letter or legal paper to help minimize paper refills. Plus, automatic duplex (2-sided) printing to help save on paper costs.
  • Dependable, durable and compact design
    Sturdy and robust construction ensures your printer works as hard as you do; compact design is ideal for smaller spaces.
Brother HL-L3270CDW - printer - colour - LED
Printer Type
Workgroup printer - LED - colour
18.3 kg
United Kingdom, Ireland
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 116 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 25 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 25 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 24 ppm - B/W - A4 (210 x 297 mm) , Up to 24 ppm - colour - A4 (210 x 297 mm) , Up to 8 spm - B/W duplex - A4 (210 x 297 mm) , Up to 8 spm - colour duplex - A4 (210 x 297 mm) , Up to 8 spm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 8 spm - colour duplex - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
2400 x 600 dpi
Max Resolution (Colour)
2400 x 600 dpi
Max Resolution Class (B&W)
2400 x 600 dpi
Max Resolution Class (Colour)
2400 x 600 dpi
Automatic Duplexing
USB 2.0, LAN, Wi-Fi(n), NFC
AirPrint Enabled
Preview Screen Size
2.7"
RAM Installed (Max)
256 MB
Language Simulation
PCL 6, XPS, BR-Script3, PDF 1.7
Barcodes
Code 93, Code 39, GS1 DataBar, UPC-A, UPC-E, Interleaved 2 of 5, Postnet, FIM, Code 128B, Code 128C, Code 128A, EAN-128, EAN-8, EAN-13, MSI
Media Type
Envelopes, labels, plain paper, bond paper, recycled paper, thick paper, thin paper, glossy paper
Total Media Capacity
250 sheets
Media Handling
250-sheet input tray, 1-sheet manual tray
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
300 - 1500 pages
Print server
Linux, Android, Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Apple iOS, Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition, Windows 10 (32/64 bits), Windows Phone, Apple MacOS X 10.11, Microsoft Windows Server 2016, Apple macOS 10.12, Windows 10 in S mode, Apple macOS 10.13
43.9 cm x 46.1 cm x 25.2 cm
Printer Type
Printer
Print Speed
Built-in Devices
Touch screen
Preview Screen Size
2.7"
Wireless
AirPrint Enabled
2400 x 600 dpi
2400 x 600 dpi
2400 x 600 dpi
2400 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
14 sec
First Print Out Time Colour
14 sec
Language Simulation
Fonts Included
73 x scalable PCL , 12 x bitmapped PCL , 66 x scalable PostScript
Barcodes
Media Handling
RAM
RAM Installed (Max)
256 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 116 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 163 g/m²
250 sheets
Media Feeders
Input tray: 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Bypass tray: 1 x manual - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray: 1 - 150 sheets
Output Trays Capacity
150 sheets
Duty Cycle
30000 pages
300 - 1500 pages
Print server
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, TFTP, IPPS
Security Protocols & Features
Kerberos, SSL, LEAP, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, TKIP, AES, WPS
1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x toner cartridge (black) - up to 1000 pages ISO/IEC 19752 , 1 x toner cartridge (cyan) - up to 1000 pages ISO/IEC 19752 , 1 x toner cartridge (magenta) - up to 1000 pages ISO/IEC 19752 , 1 x toner cartridge (yellow) - up to 1000 pages ISO/IEC 19752 , 1 x waste toner collector - up to 50000 pages 5 pages per job - Brother WT223CL , 1 x drum - up to 18000 pages 1 page per job - Brother DR243CL , 1 x transmission belt - up to 50000 pages 2 pages per job - Brother BU223CL
Power supply - internal
Frequency Required
50/60 Hz
430 Watt
Power Consumption Stand by
65 Watt
Power Consumption Sleep
9.1 Watt
Environmental Standards
Blue Angel
ENERGY STAR
Nordic Swan Ecolabel
Limited warranty - 2 years , Limited warranty - 1 year - on-site
10 °C
32 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
47 dBA
Sound Emission (Quiet Mode)
43 dBA
43.9 cm
46.1 cm
25.2 cm
18.3 kg
Width (Shipping)
58.9 cm
Depth (Shipping)
53.2 cm
Height (Shipping)
37.2 cm
Weight (Shipping)
22.1 kg
F7K2 Brother TN243BK Toner Black In Stock £39.01
Type: Printer
Wireless Capability: Wireless
Brand: Brother
